Our World Statistics Day conversations have been a great reminder of how much statistics can inform our lives. Do you have an example of how statistics has made a difference in your life? Share your story with the Community!
Ksrzg01
Gathering the cumulative sum from evaluated column
Hi everyone,
I'm trying to create a column which evaluates it's previous row and adds the zscore to it and then takes the maximum between this evaluation and 0. I've tried moving the lag formula around the Cumulative Sum equation but have not had any luck. It is only taking the value of zscore regardless of the previous row. Any help on how to resolve this would be greatly appreciated!
dt = Open("Big Class.jmp");
dt << New Column( "zscore", Formula((:weight - Col Mean( :weight, :sex )) / Col Std Dev( :weight, :sex )));
dt << Sort( By( :sex), Order( Ascending), Replace Table );
dt << New Column( "S_Hi", Formula( If( :sex == Lag( :sex ), Max( 0, :zscore + Lag( Col Cumulative Sum( :S_Hi ) ) ), Max( 0, :zscore ) ) ) )
Re: Gathering the cumulative sum from evaluated column
I think that Jim's solution is based on your original script but I don't think you want to use a separate cumulative sum. The following script is not correct because I am still not quite sure what you want but it is simpler and perhaps closer to the real solution:
dt << Sort( By( :sex ), Order( Ascending ), Replace Table );
dt << New Column( "Z Score", Formula( (:weight - Col Mean( :weight, :sex )) / Col Std Dev( :weight, :sex ) ) );
	Formula( If( :sex == Lag( :sex ), Max( 0, :zscore + Lag( :S_Hi ) ), Max( 0, :zscore ) ) )
Here is how I would approach this
	Formula(
		If(row()==1,cum=0);
			x=Max( 0, :zscore + cum ),
			x=Max( 0, :zscore )
		cum=cum+x;
		x;
Ksrzg01
Thanks for the help Nelson, but unfortunately the Max value never kicks in. When applied, the 40th row is alread a 5E+10 value. In essense I just want to get the sum of all previous values in the column and add them to the zscore at that row.
Ksrzg01
Hey Mark, this worked out perfectly. Thanks for the feedback!
Article Labels
