ENTHU
Community Trekker
Error with is missing inside for loop
I have written a small piece of code which fills a cell with value in previous cell if the current cell is empty.I have a for loop to look at all rows of a column.Following is the part of code I have written.The code runs fine when I run the code part by part(I have several lines of code before and after this part).But when I run the code as a whole it breaks at this point with the erroe -
Name Unresolved: test bench in access or evaluation of 'test bench' , :test bench/*###*/
Are there any mistakes in the code?
For( i = 2, i <= N Rows( dt ), i++,
	If( Is Missing( :test bench[i] ),
		:test bench[i] = :test bench[i - 1]
Re: Error with is missing inside for loop
try changing all of your references to :test bench, to dt:test bench
and see if that fixes anything
