uday_guntupalli
Level VIII
Display Box Help
All,
     I have a simple display box I am trying to build, however I would like to be able to use Tabs instead of H list Box that I have shown below. Any help is appreciated.
Close All(DataTables,"No Save");
Dist1 =
Expr(
          Platform(dt,Distribution(Continuous Distribution( Column( :weight ) ),Nominal Distribution( Column( :age ) )));
Biv =
Expr(
             Platform(dt,Bivariate( Y( :weight ), X( :height ), Fit Line ));
NW1 = New Window("Test",
                                 OB1 = Outline Box("Inputs",
                                                     VL1 = V List Box(
TP1 = Tab Page Box(Title("Alpha"),Dist1);
TP2 = Tab Page Box(Title("Beta"),Biv);
TB  = Tab Box("MyTest",VL2 = V List Box(HL1 = H List Box()));
HL1 << Append(TP1);
HL1 << Append(TP2);
VL1 << Append(TB);
Best
Uday
pmroz
Re: Display Box Help
Sounds like you want a tab box inside another tab box.  Will this do?
NW1 = New Window( "Test",
	OB1 = Outline Box( "Inputs",
		tb = tab box("My Test",
			tab box("Alpha", Dist1,
					 "Beta", Biv),
pmroz
Would this be easier?
Dist1 = Expr(
	Platform(	dt,
		Distribution( Continuous Distribution( Column( :weight ) ),
Biv = Expr(Platform( dt, Bivariate( Y( :weight ), X( :height ), Fit Line ) ) );
		tb = tab box("Alpha", Dist1,
					 "Beta", Biv
uday_guntupalli
Level VIII
@pmroz
         Thank you for your response. I am trying to create a parent-child display box where under a tab box titled "MyTest" for e.g., I would have "Aplha" and "Beta". By using the approach you have recommended, is there a way to achieve that ?
Best
Uday
pmroz
					 "Beta", Biv),
