Creating a Custom Platform
How we can create  custom platform in JMP/JSL?
for example we have 2 numeric columns in table (X and Y).
Any simple jsl example to create a Y vs X chart without using existing platform in JMP.
Thanks
Ram
Re: Creating a Custom Platform
There are a lot of sample scripts that are shipped with JMP that illustrate what you are asking.  You can get to the sample scripts by going to:
Help==>Sample Data
A window will pop up and one of the buttons on it is ""Open the Sample Scripts Directory"
After you open it up, I suggest you look at
utilStudentTDistribution.JSL
It's a simple script that generates it's own graphical output based upon user input.
