BookmarkSubscribeRSS Feed
neelam
May 13, 2013
Creating Subset of a subset
I wanted to create a subset from a subset both created using filters, I tried searching everywhere but didn't find what I was looking for (didn't understand many ).
I would be grateful if you could help.
I am using JMP 9.02
//this is my data table
Open("C:\DTR\DITR.jmp",
//I want to select rows with BRT and JML in stations column
Add Filter(columns(:Stations), Where(:Stations == "BRT","JML"),Mode( Select( 0 ), Include( 1 ) ) ));
//and then create a subset "Regions" from the selection
subset(output table name( "regions" ),Selected Rows( 1 ), selected columns( 0 ));
// (I cannot get it to work past this segment)
//I want to filter and create a subset form the subset "regions" created above
"regions"<< Add Filter(columns(:Months), Where(:Months == "January"), Mode( Select( 0 ), Include( 1 ) )) ;
//save the new subset as "months_regions"
subset(output table name( "months_regions" ),Selected Rows( 1 ), selected columns( 0 ));
//and apply a model to the new data table created after second subset
New Window("subset - Fit Least Squares", Fit Model(Y(:DTR), Effects(:Station Name,:Year, :Station Name * :Year), Personality(Standard Least Squares), Emphasis(Effect Leverage),   Run(:DTR << {Lack of Fit(0), Plot Actual by Predicted(1), Plot Residual by Predicted(1),   Plot Effect Leverage(1)})))
ms
Jun 23, 2011
Solution
Re: Creating Subset of a subset
Here's an example that may help you with the jsl syntax.
dt << data Filter( add filter( columns( :age ), Where( :age == {12, 13} ) ), Mode( Select( 1 ) ) );
sub1 = dt << subset( output table name( "regions" ), Selected Rows( 1 ), selected columns( 0 ) );
sub1 << data Filter( add filter( columns( :sex ), Where( :sex == "F" ) ), Mode( Select( 1 ) ) );
sub2 = sub1 << subset( output table name( "months_regions" ), Selected Rows( 1 ), selected columns( 0 ) );
sub2 << Fit Model( Y( :weight ), Effects( :height ), Personality( Standard Least Squares ), Run );
However, with data filters it's possible to filter after several critera in one step, making the intermediate subset redundant.
dt << Data Filter(
  Add Filter( columns( :age, :sex ), Where( :age == {12, 13} ), Where( :sex == "F" ) )
ms
Jun 23, 2011
Solution
dt << Data Filter(
neelam
May 13, 2013
Thank you MS, that solved it.
