blue1994
Create a user interface
Hi, i would like to create a user interface.
I want to make the user interface as if we save the data, after that we also can browse the file, such as select the file from destop, then we choose the file which we want.
Thanks.
ian_jmp
Re: Create a user interface
Without further details about your intended UI, maybe 'PickFile()' will do? Do 'Help > Scripting Index' then search for this to get more details and see a couple of examples. Note that using 'SaveFlag = 1' allows you to have a prompt to save a new file, rather than open an existing file.
ian_jmp
