See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
Contour Plot
Samboat
Please, I humbly ask for help on how to make a contour plot of the type I have attached. Contour plot_JMP.jpg
Thierry_S
Re: Contour Plot
It is difficult to provide a valid answer without knowing the type and format of your data table. Could you share either the actual data (if it is not confidential) or a mock table showing how your data is organized and formatted.
Best,
TS
Thierry R. Sornasse
Re: Contour Plot
Graph Builder(
	Size( 400, 832 ),
	Variables( X( :weight ), Y( :height ), Group X( :sex ), Group Y( :age ) ),
	Elements( Contour( X, Y, Legend( 5 ) ) )
DragAndDrop height and weight first, then sex and age...may make it easier.DragAndDrop height and weight first, then sex and age...may make it easier.
Thierry_S
Re: Contour Plot
Of note: I believe that the original post was about plotting X, Y, and Z values as contours, hence the Frequency field should be used as well
Best,
TS
Thierry R. Sornasse
Thierry_S
Re: Contour Plot
The best option is to use the Contour Plot platform under the Graph menu with your data organized as X, Y, and Z columns
Contour Plot(
	X( :X, :Y ),
	Y( :Z ),
	Show Data Points( 0 ),
	Fill Areas( 1 ),
	Label Contours( 0 ),
	Transform( "None" ),
	Color Theme( "Jet" ),
	Specify Contours( Min( -100 ), Max( 150 ), N( 6 ) ),
OUPUT:
Where Z = X + Y (as an example)
Best,
TS
Thierry R. Sornasse
