rightmirec
Mar 6, 2017
Clustering Twitter Accounts By Common Followers in JMP
I am looking to see if I can use JMP Pro to run a cluster analysis on approximately 40 social accounts and their followers. Ideally, I'd like to cluster the 40 accounts based on common followers. So far, I have sourced follower handles using FollowerWonk, and have them set up in a spreadsheet where each column represents a parent account (one of the 40), and their followers' handles are listed below them.
I have tried a basic hierarchal cluster, but the output was a black box. I'm a little lost on if JMP can even be used for this, so any help would be much appreciated.
Currently my data is formatted as follows:
Parent Account 1  Parent Account 2
@follower1  @follower2
@follower2  @follower3
Peter_Bartell
Jun 5, 2014
Re: Clustering Twitter Accounts By Common Followers in JMP
Maybe if you share the analysis report we can provide some insight on what it may be telling you. There's no fundamental reason why you can't use this approach. You may also want to look at latent class analysis as well?
rightmirec
Mar 6, 2017
Thank you so much for the quick response. I think my first error was running the cluster with the parent accounts as the column header, that left me with a dendrogram that looke like a black box.
However, when I transposed my dataset (attached), I got a slightly more coherent analysis. I am still having trouble interpreting exactly what it means though.
rightmirec
Mar 6, 2017
Sorry, transposed dataset attached.
