ENTHU
Change the text color of a single cell of a table.
I have a table in which last row is the result of calculation from all the previous rows.Is there a way to change the font style/color of the cells in the last row?
Thanks
Re: Change the text color of a single cell of a table.
Data table font and font color are set in preferences and are not changeable on a cell basis. You might be able to get the display specifics you want if you moved the data table into a JMP Journal and use a Table Box() to display the data, then you may be able to use Conditional Formatting to make the changes you want.
