BookmarkSubscribeRSS Feed
Change default marker size
ram
Contributor
Jun 5, 2017
I am not able to change default marker size using variable!
it works if there is absolute number, but passing that number via variable does not work. Any solution?
Preferences(
Add Color Theme({"MY Default", "Qualitative", MY_Default_Color}),
Categorical Color Theme( "MY Default"),
Continuous Color Theme( "MY Default" ),
Graph Marker size(var),
