javier_guzman0
Community Trekker
Capturing mouse clicks on non Graph objects with JSL
I have been reading a lot on the mousetrap() and handle() functions, but these seem to be reserved for Graph Box objects. I was wondering If I could add a "On click" event to any graphical element in a window? For example, in the following code:
GuiWindow = New Window( "SMS1" );
theBox = Table Box(
	String Col Box( "State", {"Florida", "Texas", "Main", "California"} ),
	Number Col Box( "Width", {45, 66, 88, 13} ),
	Number Col Box( "Length", {67, 34, 1, 78} ),
	Number Col Box( "Depth", {13, 65, 32, 56} )
GuiWindow << Append( theBox );
Can I add a mouse trap or similar 'on click' behavior to a table box? So if the user where to click on anywhere inthe table, can it do something like Write("Hello World"); ?
pmroz
Re: Capturing mouse clicks on non Graph objects with JSL
For a tablebox you can make it selectable and add a row change function.  See the example below.
Summarize( a = by( age ), c = count, sumHt = Sum( Height ),
    meanHt = Mean( Height ), minHt = Min( Height ),
    maxHt = Max( Height )
sr = New Window( "Summary Results",
    tb = Table Box(
        String Col Box( "Age", a ),
        Number Col Box( "Count", c ),
        Number Col Box( "Sum", sumHt ),
        Plot Col Box( "Sum", sumHt),
        Number Col Box( "Mean", meanHt ),
        Number Col Box( "Min", minHt ),
        Number Col Box( "Max", maxHt )
tb << set shade alternate rows(1) << set row borders(1) << set column borders(1);
tb << Set Selectable Rows(1);
tb << set row change function(
    Function( {this},
row_list = this << get selected rows;
        if (nrows(row_list) > 0,
one_row = row_list[1];
            print("Row selected: " || char(one_row));
msharp
What you want is the mouse box function.
theBox = Table Box(
	MouseBox(
		theBox,
		<<SetClickEnable( 1 ),
		<<SetClick( Function( {this, clickpt, event}, If( event == "Pressed", Write( "Hello World" ) ) ) )
