Good evening,
Would you have an example of a bullet graph created with JMP? I've found many examples from other platforms but I couldn't find anything done with JMP.
Thank you for your help,
Olivia
Graph builder can produce bullet graph like effect if you set two bar chart nested.
Thank you very much for your response. Would you happen to have an example using the graph builder? I cannot get it to nest two bars and a target :/
Olivia
Try the example script below, although I am not sure if the result is anywhere near what you want. The trick seem to be to add all the columns twice and exclude the target variable from the bar chart and the other two variables from the "target chart", here represented by a box plot. Variable exclusion (X or Y) are found in the contextual menu (right click).
dt = Open( "$ENGLISH_SAMPLE_DATA/Big Class.jmp" );
dt << New Column( "target", Numeric, Continuous, <<Set Each Value( 100 ) );
Graph Builder(
Size( 500, 300 ),
Variables(
X( :height ),
X( :target, Position( 1 ) ),
X( :weight, Position( 1 ) ),
Group Y( :age )
Elements(
Bar( X( 1 ), X( 3 ), Legend( 2 ), Bar Style( "Bullet" ), Summary Statistic( "Mean" ) ),
Box Plot( X( 2 ), Legend( 4 ), Box Style( "Solid" ) )
Dispatch( {},"400",
ScaleBox,
{Legend Model( 2, Properties( 1, {Transparency( 0.5 )} ) ),
Legend Model( 4, Properties( 0, {Fill Color( 0 )} ) )}
