I need to apply a formula to many columns. What is the best way to script this?
For example, I want to apply this formula to each column of the Football.jmp table:
New Column( "Height Rank from mean",
Numeric,
"Continuous",
Format( "Best", 12 ),
Formula( Col Rank( Abs( Col Mean( :Height ) - :Height ) ) )
I've tried a few things - none great. I could either select the columns by hand, or use a dialog. Thank you!
One way is to make a list with the desired column names and loop over that list, making a new formula column with each iteration:
dt = Data Table("Football.jmp");
cols = dt << get column names(Numeric); //List of all numeric columns
// uncomment row below to select columns by hand instead
// cols= dt<<get selected columns;
For(i = 1, i <= N Items(cols), i++,
F = Eval Expr(Col Rank(Abs(Col Mean(Expr(cols[i])) - Expr(cols[i]))));
dt << New Column(cols[i] << get name || " Rank from mean",
Numeric,
"Continuous",
Format("Best", 12),
Formula(Name Expr(F))
Numeric,
"Continuous",
Format("Best", 12),
