BookmarkSubscribe
robin_preston_d
Bar Chart fill color
Good day to all.
I cannot for the life of me work out how to make a 100 % stacked bar chart. Attached is the "normal" stacked bar chart output from GraphBuilder in JMPP but how does one convert to the raltive proportion, adding up to 100 %?
Any ideas will be greatly appreciated
XanGregg
Re: Bar Chart fill color
The Mosaic element does that automatically. To get the effect in a regular stacked bar chart, you have to compute the proportions and stack those. Here is a script where I did so with inline transformations:
Open("$SAMPLE_DATA/Big Class.jmp");
Graph Builder(
	Variables(
		X( :age ),
		Y(
			Transform Column(
				"proportion",
				Formula( Col Sum( :height, :age, :sex ) / Col Sum( :height, :age ) )
		Overlay( :sex )
	Elements( Bar( X, Y, Bar Style( "Stacked" ) ) ),
In "Col Sum( :height, :age, :sex )", the variables after the first are BY variables. Use Col Number() if you just want the counts instead of the sums.
