BookmarkSubscribeRSS Feed
MuttonChops
Community Trekker
Mar 30, 2017
Banging my head over a simple table stack issue
Hi, I've been working on this simple bit for too long and I must just be overlooking something.  The log says, 'Scriptable[]' when I execute the script but it won't seem to create the table.  I'll include my script below and the log.  Am i missing something?
dt = dtFXPE3_Concat << Stack(
			columns(
				:First.RFGenDel60MHz.Range,
				:Last.RFGenDel2MHz.Range,
				:Last.RFGenDel60MHz.Range,
				:First.RFGenDel2MHz.HitCountBelow,
				:First.RFGenDel60MHz.HitCountBelow,
				:Last.RFGenDel2MHz.HitCountBelow,
				:Last.RFGenDel60MHz.HitCountBelow
			Source Label Column( "Label" ),
			Stacked Data Column( "Data" ),
			Output Table( "FXP-dtE3_Stacked" )
From the log:
dtstacked = dtFXPE3_Concat << Stack(
			columns(
			Output Table( "FXP-dtE3_Stacked", invisible )
Scriptable[]
Jun 22, 2012
Solution
Re: Banging my head over a simple table stack issue
I can not replicate your findings.  I suggest that you shutdown and restart JMP to see if that helps.  What JMP version are you using?
I have attached the simple data table that I used for testing your code snipette
Jun 22, 2012
Solution
MuttonChops
Community Trekker
Mar 30, 2017
txnelson - I restarted a couple of times with no luck.  However, a PC reboot seemed to solve the issue.  How bizarre.  Thanks for your help!
MuttonChops
Community Trekker
Mar 30, 2017
Oh, and I'm using JMP Pro V13.0.0
Jun 22, 2012
I strongly suggest that you download the free upgrade for JMP Pro 13.2.1.  There are some funky hickups in 13.0.0 that have been fixed with 13.2.1
