STEFHOLZ
Automated table comparison
I need to compare tables in my script.
comparison = Data Table( "Table1" ) << Compare Data Tables(
	Compare with( Data Table( "Table2" ) ),
	show window(0),
	limit(1),
	Compare Data
Is it possible to access the comparison object to automatically check if both tables have the same data?
Thanks for the help
Cheers
Craige_Hales
Staff (Retired)
Re: Automated table comparison
The Compare Data Tables object has an interface you can use:
Help->Scripting IndexHelp->Scripting Index
Craige
All of the JMP Platforms' output is accessible to JSL. Take a look in the Scripting Guide in the section on Display Trees, to get an idea on how to do it
Help==>Books==>Scripting Guide
Craige_Hales
Staff (Retired)
Craige
