Paul_J
Arbitrary Recode Script
I have a character variable with an unknown number of levels.  The levels have long text names and I'd like to recode them into something shorter, such as just 1, 2, 3, etc...
I understand how to use Match to recode a given set of levels to other specific values, but would like to ask how to do this if the initial set is unknown.  That is, for each new data file the variable to recoded may have a different number of different entries.
Thanks!
Re: Arbitrary Recode Script
Here is a small piece of JSL that gives an example of creating a numerical value from the character values found in a column
dt = Open( "$SAMPLE_DATA/Animals.jmp" );
dt = New Column( "Animal Category",
	formula(
		If( Row() == 1,
			Summarize( bygroup = by( :species ) )
		Loc( bygroup, :species )[1];
6 REPLIES 6
	formula(
		If( Row() == 1,
Paul_J
That worked great!   Thanks very much!
Paul_J
Seems I spoke to soon ... that code is creating the desired new variable, but now all my code after that does not work.  In particular I tried to move the new variable, then exclude some rows.  My move and exclude worked fine before, but now the new variable becomes excluded and hidden?
Is there something that needs to be re-set or turned off?  (By the way, I'm using Version 12)
Thanks!
Paul_J
PS., Seems somehow dt is being assigned that new column.  The original data table is no longer referenced by dt.  Is that right?
oops,
the New Column statement should be
dt << New Column(.................
Paul_J
A-ha!  I thought that "dt =" was unusual.  Turned out I got around it by writing "dt2 = ".  Likely a bit inefficient but it worked.  I've since changed it to "dt <<" and it works great as well.
Thanks Again!
