TWE
TWE
Alarm graph matrix
I have a query which reads values of 11 variables (11 columns)  and add a row each timestamp. Now I would like to generate a visualization which looks like the pic below, green color should mean the values are in spec and red out of spec... . I could not find a way to create this alarm graph/matrix with a graph builder. I appriciate any ideas to realize this.
Thanks,
ian_jmp
Re: Alarm graph matrix
Probably the simplest way would be to use Bubble Plot (run the script in the attached table):
With a bit more work you could alternatively use shape files in Graph Builder.
DavidLeber
Another simple solution would be to use a Graph Builder heat map - there's a great example of this in the Sample Data for Graph Builder.
It's also possible to make the graph colors discrete, if that's what you want:
ian_jmp
TWE
TWE
Thank you, this will work!
DavidLeber
TWE
TWE
Thank you this could work!
