The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
Learning Center
Videos, activities, learning paths, and articles to help you learn and grow your curiosity about JMP. From novice to advanced JMP users, the Learning Library has content for everyone.
Featured Items
Latest Posts
  • Unit Tests: Automated JSL Testing
    Software development practitioners use the term unit to refer to the smallest testable component of a software product and the phrase unit testing to refer to the process of validating that a unit operates as expected. Over the past twenty years, these practitioners have become increasingly interested in automated unit testing and the phrase unit testing framework has come to refer to the mechanis...
    gail_massari gail_massari
    Learning Center |
    Mar 5, 2025 8:14 AM
    116 views | 0 replies
  • JMP for Mixed Models - Book Chapter 1
    This summary is excerpted from JMP for Mixed Models by Ruth Hummel, Elizabeth Claassen, and Russell Wolfinger. Copyright 2021, SAS Institute Inc., Cary, NC, USA. All Rights Reserved. Reproduced with permission of SAS Institute Inc., Cary, NC.   Download Chapter 1 to learn more.    Mixed models are now the mainstream method of choice for analyzing experimental data. Why? They are arguably the mos...
    Learning Center |
    Mar 5, 2025 5:59 AM
    557 views | 0 replies
  • Tips and Tricks 2024 (JMP 18)
    Here are some Tips and Tricks for using JMP more effectively!   Drilling Down into Data Create Graphlets and use graphs to filter on additional graphs! (view in My Videos) Capturing Data Selections Capture data selections that have been made interactively to filter and create new variables for analysis. Name Selection in Column and creating a formula that uses row states interactively are shown. (...
    Laura_Higgins Laura_Higgins
    Learning Center |
    Feb 27, 2025 10:12 AM
    1704 views | 3 replies
  • Essentials of Designing Experiments
    Essentials of Designing Experiments   (view in My Videos)   JMP has powerful, world-class design of experiments (DOE) capabilities. See how to use the DOE platforms to make the most of your experiments. This topic may cover Custom Design, Screening Design, Full Factorial Design, Response Surface Design, and using Easy DOE to streamline your DOE workflow.
    Learning Center |
    Feb 21, 2025 1:46 PM
    250 views | 0 replies
  • Formulas and the Formula Editor
    Make and edit formulas in JMP   (view in My Videos)   See how to use JMP's powerful, easy-to-use Formula Editor to create columns with values computed by a formula and store the formula as part of column information. Learn how to build formulas that are simple assignments of numeric, character or row state constants, or complex evaluations based on conditional clauses. See how formulas are linked ...
    Learning Center |
    Feb 21, 2025 1:32 PM
    279 views | 0 replies
  • Unlocking the Power of Graph Builder 2024
    (view in My Videos) Unlocking the Power of Graph Builder 2024 (JMP 18, 2024) Graph Builder is JMP's drag and drop graphing platform. Many types of graphs can be made in Graph Builder. This video covers the basics of Graph Builder and goes through several examples.    (view in My Videos)   Resources Documentation on Graphing in JMPDetails on making MapsDetails on Parallel Plots (Sankey) This is par...
    Learning Center |
    Jan 14, 2025 3:19 PM
    1962 views | 2 replies
  • Detection and Remedies for Regression Model Assumptions Violations
    This series of videos consist of the material presented at the workshop The Heartbreak of Violated Assumptions (Healing a Broken Regression).   Part 1: Review of Linear Model and Assumptions (4:11) Part 2: Detecting Violations of Assumptions (16:03) Part 3: Remedies for Violations of Assumptions (20:49)
    Di_Michelson Di_Michelson
    Learning Center |
    Nov 20, 2024 1:45 PM
    430 views | 0 replies
  • Fitting Nonlinear Regression Models in JMP
    This series of videos consist of the material presented at the workshop Off the Straight and Narrow: Fitting Nonlinear Regression Models in JMP. Part 1: Example of a Nonlinear Model (1:56) Part 2: Demonstration - Using the Nonlinear Platform in JMP (8:00) Part 3: Demonstration - Using the Fit Curve Platform in JMP (8:08) Part 4: Nonlinear Least Squares (9:35) Part 5: Loss Functions in the Nonlinea...
    Learning Center |
    Nov 12, 2024 5:27 AM
    586 views | 0 replies
  • Oversampling in predictive modeling
    This video is a supplement to the Predictive Modeling using JMP Pro course. It shows an example of how oversampling for classification works, both undersampling from the majority target level and oversampling from the minority level. It also demonstrates how to adjust the predicted probabilities for the sampling.  You might also be interested in the Imbalanced Classification Add-In, which was disc...
    Learning Center |
    Nov 11, 2024 11:07 AM
    1313 views | 2 replies
  • From Excel to JMP: Importing, Consolidating and Maximizing the Value of Excel Data (JMP 18, 2024)
    See how to import Excel files and use the Excel Import Wizard. The Excel Import Wizard is part of JMP and helps get Excel data into the right format for analysis.     Part 1: Introduction to the Excel Import Wizard We need to get data into the right structure for analysis in JMP, and the Excel Wizard will help us accomplish this. JMP has a structured row/column approach to data, where columns repr...
    Learning Center |
    Jun 25, 2024 9:35 AM
    1910 views | 0 replies
  • Using Formulas and the Formula Editor
    See how to make and edit formulas in JMP   See how to use JMP's powerful, easy-to-use Formula Editor to create columns with values computed by a formula and store the formula as part of column information. Learn how to build formulas that are simple assignments of numeric, character or row state constants, or complex evaluations based on conditional clauses. See how formulas are linked to, or de...
    brady_brady brady_brady
    Learning Center |
    Jun 20, 2024 7:24 AM
    3390 views | 2 replies
  • Videos of solutions to capstone practices from Statistical Decisions using ANOVA and Regression
    This series of videos contain solutions to the capstone practices from Statistical Decisions using ANOVA and Regression. The course data can be found at Statistical Decisions Using ANOVA and Regression Course - JMP User Community. These capstone practices are in Lesson 5. 1. ATC Panel Layout (4:45)  2. Drug Stability (4:27)  3. Concrete Strength (5:06)  4. Carbohydrate Reduction/Dietary Change (5:...
    Learning Center |
    Feb 20, 2024 6:34 AM
    1037 views | 0 replies
  • How can I create and save customized interactive drill-down graphs in JMP?
    In JMP,  you can add a thumbnail of a graph or an image of  elements on a  graph built using Graph Builder.  These thumbnail, customized, interactive graphs are called graphlets.  You can also nest graphlets. Start by creating a graph in Graph Builder.  This is your baseline graph. Copy the script by saving it to your clipboard using SAVE SCRIPT > TO CLIPBOARD,  and then paste it as a graphlet int...
    Learning Center |
    Feb 8, 2024 9:14 AM
    1110 views | 2 replies
  • Quality Digest - Principles of Graphing Data - Resources
    The attached PDF file and JMP journal were used in the Quality Digest webinar Principles of Graphing Data.
    Learning Center |
    Nov 13, 2023 1:45 PM
    1257 views | 0 replies
  • Design of Experiments Introduction Kit
    ryandewitt ryandewitt
    Learning Center |
    Sep 19, 2023 1:09 AM
    23298 views | 3 replies
  • How do I Connect to OSIsoft PI Server?
    To import from the OSIsoft Pi Server, you must have the PI Web Server deployed and running and the PI Asset Framework installed and configured.   See how to open the JMP OSIsoft PI interface introduced in JMP 17, connect to the server by identifying the server url, authenticate if necessary, set the server name and database to which you want to connect, and then identify the Attributes (tags) you ...
    yasmine_hajar yasmine_hajar
    Learning Center |
    Aug 4, 2023 9:52 AM
    2092 views | 1 replies
  • How Can I use JMP for Statistical Process Control (SPC) in the Chemical Inudstry?
    Using data for a process where multiple materials are feeding in from different streams and then going through a reactor, see how to monitor process stability, get an alarm when the process is out of spec and uncover which parameter(s) relate to the problem.  This workflow includes using: -control charts -process screening and  -model driven multivariate control chart      (view in My Videos)     ...
    Learning Center |
    Jul 14, 2023 8:58 AM
    1506 views | 0 replies
  • How Can I use JMP for Statistical Process Control (SPC) for Semiconductors?
    (view in My Videos)   JMP is useful for SPC in all industries, including this example for semiconductors.    See how to: Understand process shifts and add alarmsScreening multiple parameters for stability (Process Screening)Filter to find important factors (Predictor Screening) and determine their capabilityMonitor multiple parameters in one control chart through Model Driven Multivariate Control ...
    Learning Center |
    Jul 6, 2023 10:47 AM
    2272 views | 0 replies
  • How Can I Use Statistical Process Control in the Pharmaceutical Industry? (Updated with JMP 18)
    JMP is useful for statistical process control in a wide variety of industries. This example demonstrates the workflow of how to: Create an individual Control Chart that gives an overview of dissolution rate value as a function of lotsScreen through multiple parameters to check for stabilityPerform a Process Capability Analysis to examine the capability of coating parameters Use the Measurement Sys...
    Learning Center |
    Jun 29, 2023 12:48 PM
    1438 views | 0 replies
  • Building and Understanding Predictive Models
    Building and Understanding Predictive Models    Whether you call it model fitting, data mining or machine learning, JMP Pro has tools for you. JMP Pro makes it easy to build a variety of models all at once in Model Screening, and determine the best type of model for your problem, easily compare different models, and organize models and output models in C, Python, Javascript, SQL, and SAS.  Discove...
    Learning Center |
    Jun 28, 2023 5:01 PM
    1732 views | 0 replies
  • Automating Your Analysis Workflow
    The JMP Scripting Language (JSL) will give you the tools you need to make using JMP even more productive. This topic may cover saving scripts to journals and data tables, combining scripts to automate repetitive actions, and creating repeatable and reproducible analyses using the Enhanced Log and Workflow Builder.  (view in My Videos) This is part of the Get Goin...
    Learning Center |
    Jun 28, 2023 4:42 PM
    2384 views | 0 replies
  • Quality Control for the Competitive Edge
    Learn how JMP can help you achieve quality control using control charts to assess a specific process. The robust statistical analysis and data visualization in JMP let you immediately spot trends and outliers in huge data sets about your products. This topic may cover Measurement Systems Analysis, Control Chart Builder, Process Screening and Process Capabi...
    Learning Center |
    Jun 28, 2023 4:31 PM
    860 views | 0 replies
  • Boosting Product Reliability
    In any manufacturing endeavor, product reliability strongly influences business success. Reliability tools in JMP help you prevent failure and improve warranty performance. By revealing trends and outliers in your data and model predictions, JMP helps you find important design vulnerabilities, pinpoint defects in materials or processes, and then determine how to reduc...
    Learning Center |
    Jun 28, 2023 4:17 PM
    986 views | 0 replies
  • How do I Create a Semiconductor Wafer Heat Map?
    In a wafer heat map graphic, each rectangular chip on the wafer is represented with a color that is associated with a property or parameter value of the chip. Heat maps are used to visualize the impact of the die’s location on any continuous or categorical variable of interest. Analyzing the wafer heat map gives an insight on the impact of the chip’s coordinates on its future performance as a semi...
    Learning Center |
    Jun 27, 2023 8:06 AM
    4047 views | 0 replies
