Often times a split plot design cannot be completed in a single experimental session. Multiple sessions over multiple days are required (examples: firing of a ceramic, melt tanks, acid baths, or other hard to change factors with time and cost change-overs).
Consider adding an option for blocking (Days or other periods, batches of raw material...) for split plot design when factors in the design are identified as hard-to-change.
why is this idea important?
Ease of use. Blocking of a split plot can be done but is not intuitive; requires one to know how to manipulate/trick the software by using a categorical factor and doing some manipulation of the resulting design. Current version of jmp is 17.1
