%3CLINGO-SUB%20id%3D%22lingo-sub-696392%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EPlease%20consider%20automating%20the%20process%20of%20blocking%20a%20split%20plot%20design.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-696392%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3EWhat%20inspired%20this%20wish%20list%20request%3F%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EOften%20times%20a%20split%20plot%20design%20cannot%20be%20completed%20in%20a%20single%20experimental%20session.%26nbsp%3B%20Multiple%20sessions%20over%20multiple%20days%20are%20required%20(examples%3A%26nbsp%3B%20firing%20of%20a%20ceramic%2C%20melt%20tanks%2C%20acid%20baths%2C%20or%20other%20hard%20to%20change%20factors%20with%20time%20and%20cost%20change-overs).%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWhat%20is%20the%20improvement%20you%20would%20like%20to%20see%3F%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EConsider%20adding%20an%20option%20for%20blocking%20(Days%20or%20other%20periods%2C%20batches%20of%20raw%20material...)%20for%20split%20plot%20design%20when%20factors%20in%20the%20design%20are%20identified%20as%20hard-to-change.%3C%2FP%3E%3CP%3E%3CSTRONG%3Ewhy%20is%20this%20idea%20important%3F%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EEase%20of%20use.%26nbsp%3B%20Blocking%20of%20a%20split%20plot%20can%20be%20done%20but%20is%20not%20intuitive%3B%20requires%20one%20to%20know%20how%20to%20manipulate%2Ftrick%20the%20software%20by%20using%20a%20categorical%20factor%20and%20doing%20some%20manipulation%20of%20the%20resulting%20design.%26nbsp%3B%20Current%20version%20of%20jmp%20is%2017.1%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-696392%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EDesign%20of%20Experiments%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Please consider automating the process of blocking a split plot design.
Often times a split plot design cannot be completed in a single experimental session.  Multiple sessions over multiple days are required (examples:  firing of a ceramic, melt tanks, acid baths, or other hard to change factors with time and cost change-overs).
Consider adding an option for blocking (Days or other periods, batches of raw material...) for split plot design when factors in the design are identified as hard-to-change.
why is this idea important?
Ease of use.  Blocking of a split plot can be done but is not intuitive; requires one to know how to manipulate/trick the software by using a categorical factor and doing some manipulation of the resulting design.  Current version of jmp is 17.1
