%3CLINGO-SUB%20id%3D%22lingo-sub-696392%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBitte%20erw%C3%A4gen%20Sie%20die%20Automatisierung%20des%20Prozesses%20zum%20Blockieren%20eines%20Split-Plot-Designs.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-696392%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3EWas%20hat%20diese%20Wunschlistenanfrage%20inspiriert%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EOftmals%20kann%20ein%20Split-Plot-Design%20nicht%20in%20einer%20einzigen%20Versuchssitzung%20fertiggestellt%20werden.Es%20sind%20mehrere%20Sitzungen%20%C3%BCber%20mehrere%20Tage%20hinweg%20erforderlich%20(Beispiele%3A%20Brennen%20einer%20Keramik%2C%20Schmelztanks%2C%20S%C3%A4ureb%C3%A4der%20oder%20andere%20schwer%20ver%C3%A4nderbare%20Faktoren%20bei%20Zeit-%20und%20Kosten%C3%A4nderungen).%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWelche%20Verbesserung%20w%C3%BCrden%20Sie%20sich%20w%C3%BCnschen%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EErw%C3%A4gen%20Sie%20das%20Hinzuf%C3%BCgen%20einer%20Option%20zum%20Blockieren%20(Tage%20oder%20andere%20Zeitr%C3%A4ume%2C%20Rohmaterialchargen%20...)%20f%C3%BCr%20den%20Split-Plot-Entwurf%2C%20wenn%20festgestellt%20wird%2C%20dass%20Faktoren%20im%20Entwurf%20schwer%20zu%20%C3%A4ndern%20sind.%3C%2FP%3E%3CP%3E%3CSTRONG%3EWarum%20ist%20diese%20Idee%20wichtig%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EBenutzerfreundlichkeit.Das%20Blockieren%20eines%20geteilten%20Plots%20ist%20zwar%20m%C3%B6glich%2C%20aber%20nicht%20intuitiv.%20erfordert%2C%20dass%20man%20wei%C3%9F%2C%20wie%20man%20die%20Software%20manipuliert%2Faustrickst%2C%20indem%20man%20einen%20kategorialen%20Faktor%20verwendet%20und%20das%20resultierende%20Design%20manipuliert.Die%20aktuelle%20Version%20von%20jmp%20ist%2017.1%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-696392%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EVersuchsplanung%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Please consider automating the process of blocking a split plot design.
Often times a split plot design cannot be completed in a single experimental session.  Multiple sessions over multiple days are required (examples:  firing of a ceramic, melt tanks, acid baths, or other hard to change factors with time and cost change-overs).
Consider adding an option for blocking (Days or other periods, batches of raw material...) for split plot design when factors in the design are identified as hard-to-change.
why is this idea important?
Ease of use.  Blocking of a split plot can be done but is not intuitive; requires one to know how to manipulate/trick the software by using a categorical factor and doing some manipulation of the resulting design.  Current version of jmp is 17.1
