%3CLINGO-SUB%20id%3D%22lingo-sub-696392%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EVeuillez%20envisager%20d'automatiser%20le%20processus%20de%20blocage%20d'une%20conception%20de%20parcelle%20divis%C3%A9e.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-696392%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3EQu'est-ce%20qui%20a%20inspir%C3%A9%20cette%20demande%20de%20liste%20de%20souhaits%26nbsp%3B%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3ESouvent%2C%20une%20conception%20en%20parcelles%20divis%C3%A9es%20ne%20peut%20pas%20%C3%AAtre%20r%C3%A9alis%C3%A9e%20en%20une%20seule%20session%20exp%C3%A9rimentale.Plusieurs%20sessions%20sur%20plusieurs%20jours%20sont%20n%C3%A9cessaires%20(exemples%26nbsp%3B%3A%20cuisson%20d'une%20c%C3%A9ramique%2C%20cuves%20de%20fusion%2C%20bains%20d'acide%20ou%20autres%20facteurs%20difficiles%20%C3%A0%20modifier%20en%20raison%20des%20changements%20de%20temps%20et%20de%20co%C3%BBts).%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EQuelle%20est%20l%E2%80%99am%C3%A9lioration%20que%20vous%20souhaiteriez%20voir%20%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EEnvisagez%20d'ajouter%20une%20option%20de%20blocage%20(jours%20ou%20autres%20p%C3%A9riodes%2C%20lots%20de%20mati%C3%A8res%20premi%C3%A8res...)%20pour%20la%20conception%20de%20parcelles%20fractionn%C3%A9es%20lorsque%20les%20facteurs%20de%20la%20conception%20sont%20identifi%C3%A9s%20comme%20difficiles%20%C3%A0%20modifier.%3C%2FP%3E%3CP%3E%3CSTRONG%3Epourquoi%20cette%20id%C3%A9e%20est-elle%20importante%20%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EFacilit%C3%A9%20d'utilisation.Le%20blocage%20d'un%20trac%C3%A9%20fractionn%C3%A9%20peut%20%C3%AAtre%20effectu%C3%A9%20mais%20n'est%20pas%20intuitif%26nbsp%3B%3B%20n%C3%A9cessite%20de%20savoir%20comment%20manipuler%2Ftromper%20le%20logiciel%20en%20utilisant%20un%20facteur%20cat%C3%A9goriel%20et%20en%20manipulant%20la%20conception%20r%C3%A9sultante.La%20version%20actuelle%20de%20jmp%20est%2017.1%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-696392%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EConception%20d'exp%C3%A9riences%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Please consider automating the process of blocking a split plot design.
Often times a split plot design cannot be completed in a single experimental session.  Multiple sessions over multiple days are required (examples:  firing of a ceramic, melt tanks, acid baths, or other hard to change factors with time and cost change-overs).
Consider adding an option for blocking (Days or other periods, batches of raw material...) for split plot design when factors in the design are identified as hard-to-change.
why is this idea important?
Ease of use.  Blocking of a split plot can be done but is not intuitive; requires one to know how to manipulate/trick the software by using a categorical factor and doing some manipulation of the resulting design.  Current version of jmp is 17.1
