  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Improving Equivalence Tests in Fit Y by X
Suggestion would be to allow an automatic solve for the difference value that gives equivalence for a given alpha.
In the example example-of-an-equivalence-test there would be an option to solve for the difference value that predicts equivalence for a given alpha value (it addition to the current option for supplying a specific difference).   Many times this difference value is specified inconsistently among a given department or functional group (often with many differing opinions).  So, instead of running multiple differences to show the p-values for equivalence it would be very convenient to solve for the difference that would predict equivalence given an alpha value.
2 Comments
jszarka
Level V
If you have an alpha=.05, a 90% confidence interval on the difference in means between 2 groups will align with the boundary difference value you specify. Within the Fit Y by X platform you can change the alpha level to say .10 and use the appropriate t-test for making that comparison in the Big Class data set.
In general though, it's not a good practice to get the confidence interval then determine whether or not that difference level is meaningful. I can't tell from your thread whether this debate occurs before or after the data occurs; naturally we want that agreed upon in advance so that when the data comes back the group can be held accountable to the preselected threshold.
I agree that a back-solver would be handy but it goes against the intent of an equivalence test which is to specify a practical difference threshold before running the experiment.
This is kind of like cherry-picking the practical difference to "pass."
