%3CLINGO-SUB%20id%3D%22lingo-sub-249081%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EMejorar%20las%20pruebas%20de%20equivalencia%20en%20el%20ajuste%20Y%20por%20X%3C%2FLINGO-SUB%3E%0A%20%20%3CLINGO-BODY%20id%3D%22lingo-body-249081%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%20%20%20%3CP%3EUna%20sugerencia%20ser%C3%ADa%20permitir%20una%20soluci%C3%B3n%20autom%C3%A1tica%20para%20el%20valor%20de%20diferencia%20que%20d%C3%A9%20equivalencia%20para%20un%20alfa%20dado.%3C%2FP%3E%0A%20%20%20%3CP%3EEn%20el%20%3CA%20href%3D%22https%3A%2F%2Fwww.jmp.com%2Fsupport%2Fhelp%2Fen%2F15.0%2Fjmp%2Fexample-of-an-equivalence-test.shtml%23%22%20target%3D%22_self%22%20rel%3D%22noopener%20noreferrer%22%3Eejemplo%20de%20una%20prueba%20de%20equivalencia%2C%3C%2FA%3E%20habr%C3%ADa%20una%20opci%C3%B3n%20para%20calcular%20el%20valor%20de%20la%20diferencia%20que%20predice%20la%20equivalencia%20para%20un%20valor%20alfa%20dado%20(adem%C3%A1s%20de%20la%20opci%C3%B3n%20actual%20para%20proporcionar%20una%20diferencia%20espec%C3%ADfica).%20Con%20frecuencia%2C%20este%20valor%20de%20diferencia%20se%20especifica%20de%20forma%20inconsistente%20entre%20un%20departamento%20o%20grupo%20funcional%20determinado%20(a%20menudo%20con%20opiniones%20divergentes).%20Por%20lo%20tanto%2C%20en%20lugar%20de%20ejecutar%20m%C3%BAltiples%20diferencias%20para%20mostrar%20los%20valores%20p%20de%20equivalencia%2C%20ser%C3%ADa%20%3CEM%3E%3CSTRONG%3Emuy%3C%2FSTRONG%3E%3C%2FEM%3E%20conveniente%20calcular%20la%20diferencia%20que%20predecir%C3%ADa%20la%20equivalencia%20dado%20un%20valor%20alfa.%3C%2FP%3E%0A%20%20%3C%2FLINGO-BODY%3E%0A%20%20%3CLINGO-LABS%20id%3D%22lingo-labs-249081%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%20%20%20%3CLINGO-LABEL%3EExploraci%C3%B3n%20y%20visualizaci%C3%B3n%20de%20datos%3C%2FLINGO-LABEL%3E%0A%20%20%3C%2FLINGO-LABS%3E%0A%20%0A%3CLINGO-SUB%20id%3D%22lingo-sub-392849%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Mejorar%20las%20pruebas%20de%20equivalencia%20en%20Fit%20Y%20by%20X%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-392849%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EEstoy%20de%20acuerdo%20en%20que%20un%20back-solver%20ser%C3%ADa%20%C3%BAtil%2C%20pero%20va%20en%20contra%20de%20la%20intenci%C3%B3n%20de%20una%20prueba%20de%20equivalencia%20que%20es%20especificar%20un%20umbral%20de%20diferencia%20pr%C3%A1ctico%3CEM%3E%20antes%3C%2FEM%3E%20ejecutando%20el%20experimento.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3EEsto%20es%20como%20elegir%20la%20diferencia%20pr%C3%A1ctica%20de%20%22aprobar%22.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-250299%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Mejorar%20las%20pruebas%20de%20equivalencia%20en%20Fit%20Y%20by%20X%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-250299%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ESi%20tiene%20un%20alfa%20%3D%200%2C05%2C%20un%20intervalo%20de%20confianza%20del%2090%20%25%20en%20la%20diferencia%20de%20medias%20entre%202%20grupos%20se%20alinear%C3%A1%20con%20el%20valor%20de%20diferencia%20l%C3%ADmite%20que%20especifique.%20Dentro%20de%20la%20plataforma%20Fit%20Y%20by%20X%2C%20puede%20cambiar%20el%20nivel%20alfa%20para%20decir%20.10%20y%20usar%20la%20prueba%20t%20apropiada%20para%20hacer%20esa%20comparaci%C3%B3n%20en%20el%20conjunto%20de%20datos%20de%20Big%20Class.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ESin%20embargo%2C%20en%20general%2C%20no%20es%20una%20buena%20pr%C3%A1ctica%20obtener%20el%20intervalo%20de%20confianza%20y%20luego%20determinar%20si%20ese%20nivel%20de%20diferencia%20es%20significativo%20o%20no.%20No%20puedo%20decir%20por%20su%20hilo%20si%20este%20debate%20ocurre%20antes%20o%20despu%C3%A9s%20de%20que%20ocurran%20los%20datos%3B%20naturalmente%2C%20queremos%20que%20se%20acuerde%20de%20antemano%20para%20que%20cuando%20los%20datos%20regresen%2C%20el%20grupo%20pueda%20rendir%20cuentas%20hasta%20el%20umbral%20preseleccionado.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Improving Equivalence Tests in Fit Y by X
Suggestion would be to allow an automatic solve for the difference value that gives equivalence for a given alpha.
In the example example-of-an-equivalence-test there would be an option to solve for the difference value that predicts equivalence for a given alpha value (it addition to the current option for supplying a specific difference).   Many times this difference value is specified inconsistently among a given department or functional group (often with many differing opinions).  So, instead of running multiple differences to show the p-values for equivalence it would be very convenient to solve for the difference that would predict equivalence given an alpha value.
2 Comments
jszarka
Level V
If you have an alpha=.05, a 90% confidence interval on the difference in means between 2 groups will align with the boundary difference value you specify. Within the Fit Y by X platform you can change the alpha level to say .10 and use the appropriate t-test for making that comparison in the Big Class data set.
In general though, it's not a good practice to get the confidence interval then determine whether or not that difference level is meaningful. I can't tell from your thread whether this debate occurs before or after the data occurs; naturally we want that agreed upon in advance so that when the data comes back the group can be held accountable to the preselected threshold.
I agree that a back-solver would be handy but it goes against the intent of an equivalence test which is to specify a practical difference threshold before running the experiment.
This is kind of like cherry-picking the practical difference to "pass."
