%3CLINGO-SUB%20id%3D%22lingo-sub-249081%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EVerbesserte%20%C3%84quivalenztests%20in%20Fit%20Y%20nach%20X%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-249081%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EDer%20Vorschlag%20w%C3%A4re%2C%20eine%20automatische%20L%C3%B6sung%20f%C3%BCr%20den%20Differenzwert%20zuzulassen%2C%20der%20die%20%C3%84quivalenz%20f%C3%BCr%20ein%20bestimmtes%20Alpha%20ergibt.%3C%2FP%3E%3CP%3EIm%20Beispiel%3CA%20href%3D%22https%3A%2F%2Fwww.jmp.com%2Fsupport%2Fhelp%2Fen%2F15.0%2Fjmp%2Fexample-of-an-equivalence-test.shtml%23%22%20target%3D%22_self%22%20rel%3D%22noopener%20noreferrer%22%3E%20Beispiel-eines-%C3%84quivalenztests%3C%2FA%3E%20Es%20g%C3%A4be%20eine%20Option%20zum%20Aufl%C3%B6sen%20nach%20dem%20Differenzwert%2C%20der%20die%20%C3%84quivalenz%20f%C3%BCr%20einen%20bestimmten%20Alpha-Wert%20vorhersagt%20(zus%C3%A4tzlich%20zu%20der%20aktuellen%20Option%20zum%20Bereitstellen%20einer%20bestimmten%20Differenz).%20Oft%20wird%20dieser%20Differenzwert%20innerhalb%20einer%20bestimmten%20Abteilung%20oder%20Funktionsgruppe%20uneinheitlich%20angegeben%20(oft%20mit%20vielen%20unterschiedlichen%20Meinungen).Anstatt%20also%20mehrere%20Differenzen%20auszuf%C3%BChren%2C%20um%20die%20p-Werte%20f%C3%BCr%20die%20%C3%84quivalenz%20anzuzeigen%2C%20w%C3%A4re%20dies%20der%20Fall%3CEM%3E%3CSTRONG%3E%20sehr%3C%2FSTRONG%3E%3C%2FEM%3E%20bequem%20nach%20der%20Differenz%20aufzul%C3%B6sen%2C%20die%20bei%20einem%20gegebenen%20Alpha-Wert%20die%20%C3%84quivalenz%20vorhersagen%20w%C3%BCrde.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-249081%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EStatistik%20und%20Analytik%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EBenutzeroberfl%C3%A4che%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-392849%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20%C3%84quivalenztests%20in%20Fit%20Y%20by%20X%20verbessern%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-392849%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EIch%20stimme%20zu%2C%20dass%20ein%20Backsolver%20praktisch%20w%C3%A4re%2C%20aber%20es%20widerspricht%20der%20Absicht%20eines%20%C3%84quivalenztests%2C%20der%20eine%20praktische%20Differenzschwelle%20angeben%20soll%3CEM%3E%20Vor%3C%2FEM%3E%20Ausf%C3%BChren%20des%20Experiments.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3EDas%20ist%20so%20etwas%20wie%20das%20Rosinenpicken%20des%20praktischen%20Unterschieds%20zu%20%E2%80%9Ebestanden%E2%80%9C.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-250299%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20%C3%84quivalenztests%20in%20Fit%20Y%20by%20X%20verbessern%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-250299%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EWenn%20Sie%20Alpha%20%3D%200%2C05%20haben%2C%20wird%20ein%20Konfidenzintervall%20von%2090%26nbsp%3B%25%20f%C3%BCr%20die%20Differenz%20der%20Mittelwerte%20zwischen%20zwei%20Gruppen%20mit%20dem%20von%20Ihnen%20angegebenen%20Grenzdifferenzwert%20%C3%BCbereinstimmen.%20Innerhalb%20der%20Fit%20Y%20by%20X-Plattform%20k%C3%B6nnen%20Sie%20das%20Alpha-Level%20beispielsweise%20auf%200%2C10%20%C3%A4ndern%20und%20den%20entsprechenden%20t-Test%20verwenden%2C%20um%20diesen%20Vergleich%20im%20Big%20Class-Datensatz%20durchzuf%C3%BChren.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EIm%20Allgemeinen%20ist%20es%20jedoch%20keine%20gute%20Praxis%2C%20das%20Konfidenzintervall%20zu%20ermitteln%20und%20dann%20zu%20bestimmen%2C%20ob%20dieses%20Differenzniveau%20aussagekr%C3%A4ftig%20ist%20oder%20nicht.%20Ich%20kann%20Ihrem%20Thread%20nicht%20entnehmen%2C%20ob%20diese%20Debatte%20vor%20oder%20nach%20den%20Daten%20stattfindet.%20Nat%C3%BCrlich%20wollen%20wir%2C%20dass%20dies%20im%20Voraus%20vereinbart%20wird%2C%20damit%20die%20Gruppe%2C%20wenn%20die%20Daten%20zur%C3%BCckkommen%2C%20f%C3%BCr%20den%20vorgew%C3%A4hlten%20Schwellenwert%20zur%20Rechenschaft%20gezogen%20werden%20kann.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Improving Equivalence Tests in Fit Y by X
Suggestion would be to allow an automatic solve for the difference value that gives equivalence for a given alpha.
In the example example-of-an-equivalence-test there would be an option to solve for the difference value that predicts equivalence for a given alpha value (it addition to the current option for supplying a specific difference).   Many times this difference value is specified inconsistently among a given department or functional group (often with many differing opinions).  So, instead of running multiple differences to show the p-values for equivalence it would be very convenient to solve for the difference that would predict equivalence given an alpha value.
2 Comments
jszarka
Level V
If you have an alpha=.05, a 90% confidence interval on the difference in means between 2 groups will align with the boundary difference value you specify. Within the Fit Y by X platform you can change the alpha level to say .10 and use the appropriate t-test for making that comparison in the Big Class data set.
In general though, it's not a good practice to get the confidence interval then determine whether or not that difference level is meaningful. I can't tell from your thread whether this debate occurs before or after the data occurs; naturally we want that agreed upon in advance so that when the data comes back the group can be held accountable to the preselected threshold.
I agree that a back-solver would be handy but it goes against the intent of an equivalence test which is to specify a practical difference threshold before running the experiment.
This is kind of like cherry-picking the practical difference to "pass."
