%3CLINGO-SUB%20id%3D%22lingo-sub-249081%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EImproving%20Equivalence%20Tests%20in%20Fit%20Y%20by%20X%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-249081%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ESuggestion%20would%20be%20to%20allow%20an%20automatic%20solve%20for%20the%20difference%20value%20that%20gives%20equivalence%20for%20a%20given%20alpha.%3C%2FP%3E%3CP%3EIn%20the%20example%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.jmp.com%2Fsupport%2Fhelp%2Fen%2F15.0%2Fjmp%2Fexample-of-an-equivalence-test.shtml%23%22%20target%3D%22_self%22%20rel%3D%22noopener%20noreferrer%22%3Eexample-of-an-equivalence-test%3C%2FA%3E%20there%20would%20be%20an%20option%20to%20solve%20for%20the%20difference%20value%20that%20predicts%20equivalence%20for%20a%20given%20alpha%20value%20(it%20addition%20to%20the%20current%20option%20for%20supplying%20a%20specific%20difference).%20%26nbsp%3B%20Many%20times%20this%20difference%20value%20is%20specified%20inconsistently%20among%20a%20given%20department%20or%20functional%20group%20(often%20with%20many%20differing%20opinions).%26nbsp%3B%20So%2C%20instead%20of%20running%20multiple%20differences%20to%20show%20the%20p-values%20for%20equivalence%20it%20would%20be%20%3CEM%3E%3CSTRONG%3Every%3C%2FSTRONG%3E%3C%2FEM%3E%20convenient%20to%20solve%20for%20the%20difference%20that%20would%20predict%20equivalence%20given%20an%20alpha%20value.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-249081%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EStatistics%20and%20Analytics%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EUser%20Interface%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-392849%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Improving%20Equivalence%20Tests%20in%20Fit%20Y%20by%20X%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-392849%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EI%20agree%20that%20a%20back-solver%20would%20be%20handy%20but%20it%20goes%20against%20the%20intent%20of%20an%20equivalence%20test%20which%20is%20to%20specify%20a%20practical%20difference%20threshold%26nbsp%3B%3CEM%3Ebefore%3C%2FEM%3E%20running%20the%20experiment.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3EThis%20is%20kind%20of%20like%20cherry-picking%20the%20practical%20difference%20to%20%22pass.%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-250299%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Improving%20Equivalence%20Tests%20in%20Fit%20Y%20by%20X%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-250299%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EIf%20you%20have%20an%20alpha%3D.05%2C%20a%2090%25%20confidence%20interval%20on%20the%20difference%20in%20means%20between%202%20groups%20will%20align%20with%20the%20boundary%20difference%20value%20you%20specify.%20Within%20the%20Fit%20Y%20by%20X%20platform%20you%20can%20change%20the%20alpha%20level%20to%20say%20.10%20and%20use%20the%20appropriate%20t-test%20for%20making%20that%20comparison%20in%20the%20Big%20Class%20data%20set.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EIn%20general%20though%2C%20it's%20not%20a%20good%20practice%20to%20get%20the%20confidence%20interval%20then%20determine%20whether%20or%20not%20that%20difference%20level%20is%20meaningful.%20I%20can't%20tell%20from%20your%20thread%20whether%20this%20debate%20occurs%20before%20or%20after%20the%20data%20occurs%3B%20naturally%20we%20want%20that%20agreed%20upon%20in%20advance%20so%20that%20when%20the%20data%20comes%20back%20the%20group%20can%20be%20held%20accountable%20to%20the%20preselected%20threshold.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Improving Equivalence Tests in Fit Y by X
Suggestion would be to allow an automatic solve for the difference value that gives equivalence for a given alpha.
In the example example-of-an-equivalence-test there would be an option to solve for the difference value that predicts equivalence for a given alpha value (it addition to the current option for supplying a specific difference).   Many times this difference value is specified inconsistently among a given department or functional group (often with many differing opinions).  So, instead of running multiple differences to show the p-values for equivalence it would be very convenient to solve for the difference that would predict equivalence given an alpha value.
2 Comments
jszarka
Level V
If you have an alpha=.05, a 90% confidence interval on the difference in means between 2 groups will align with the boundary difference value you specify. Within the Fit Y by X platform you can change the alpha level to say .10 and use the appropriate t-test for making that comparison in the Big Class data set.
In general though, it's not a good practice to get the confidence interval then determine whether or not that difference level is meaningful. I can't tell from your thread whether this debate occurs before or after the data occurs; naturally we want that agreed upon in advance so that when the data comes back the group can be held accountable to the preselected threshold.
I agree that a back-solver would be handy but it goes against the intent of an equivalence test which is to specify a practical difference threshold before running the experiment.
This is kind of like cherry-picking the practical difference to "pass."
