  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Graph Builder: Line - possibility to add breaks (💚)
☑ cool new feature
☑ could help many users!
☑ removes a „bug“
☐ nice to have
☐ nobody needs it
#myTop10_2024
For Line Graphs in Graph Builder, there is a cool feature row order.
If it's selected, the line doesn't connect data points from left to right in the graph - but along the order in which they appear in the data table.
Instead of this graph:
the user gets this graph:
Much better ...
But unfortunately, there are those nasty jumps "back" to the next curve.
Of course, for simple graphs, you can use a column (here "Station") as an overlay to produce 3 separate curves, without the zigzag.
But already with slightly more complicated graphs like this one here: Graph Builder. Combine Smoother and Line - how? the user reaches the limits of current Graph Builder (v17, v18).
  1.  With sorted data in the data table, a step from right to left indicates a new curve.
    So, with row order enabled, there could be an additional option to draw lines  "only left -> right".
    If this option is enabled, line for steps from higher to lower values will disappear -> the jump back-lines are gone : )
  2. Fallback:  Rows with missing y value could be used to add a break in line graphs (even somewhere in the center of the graph - cool, right?)
    ... if there was an option: *)
Why is this idea important?
a tiny change of the program - a  tremendous improvement for the users:
dt =Open( "$SAMPLE_DATA/Functional Data/Weekly Weather Data.jmp" );
dt << New Column( "group",Character,"Nominal",Formula( Substr( :STATION, 8, 1 ) ));
Graph Builder(
	Size( 523, 407 ),
	Summary Statistic( "Median" ),
	Graph Spacing( 4 ),
	Variables( X( :DATE ), Y( :TAVG ), Overlay( :group ), Color( :group ) ),
	Elements( Line( X, Y, Legend( 31 ), Row order( 1 ) ) ),
	Local Data Filter(
		Add Filter(
			columns( :STATION ),
			Where( :STATION == {"USW00003195", "USW00003868", "USW00003949"} ),
			Display( :STATION, N Items( 15 ) )
19 Comments
hogi
Level XIII
Option (2) is already available in Jmp:
Nevertheless, option (1) is still the preferred solution - can solve the issues of the backward jumps without the need to add auxiliary rows to the data table:
Craige_Hales
Interesting idea - if the X (or Y) order decreases, start a new line
hogi
Level XIII
Thanks @Craige_Hales
With some luck, a developer will find the wish and likes it ...
hogi
Level XIII
@mia_stephens , easy to implement - could help a lot.
Till the new feature is available...
I just uploaded a new version of QuickSelect Toolbar .
It has a new function:
The idea:
Add dummy rows between every block of data - to add a break in the line plot.
It adds the new lines at the end of the table and uses a numeric column for sorting. Unfortunately, sorting a table is forbidden if reports are open (!)
-> will benefit from Sort data table + add rows + concatenate -- make it possible
But I hope that
will come first ...
BHarris
Level VII
In this case you can just create a new column (variable) for whatever's different between the lines, then drop that variable into Overlay, which breaks the lines correctly.
hogi
Level XIII
I never have free Overlay Dropzones ; )
This is a very common use case in our company.
Here is an example with Weather data - in this case, the Overlay is used for the Smoother:
Sarah-Sylvestre
Level V
hogi
Level XIII
Hi @Sarah-Sylvestre , "removing the zig-zag" lines cold be combined with other options to facilitate the formatting of plots in Graph Builder:
(view in My Videos)
hogi
Level XIII
#DACH2024
XanGregg
Another work-around, in case it's useful. Assigning the backwards line segments their own legend color item with width 0.
dt = Open( "$SAMPLE_DATA/Functional Data/Weekly Weather Data.jmp" );
dt << New Column( "group", Character, "Nominal", Formula( Substr( :STATION, 8, 1 ) ) );
dt << New Column( "cgroup", Character, "Nominal",
	Formula( If( Row() == 1 | Lag( :DATE ) > :DATE, "break", Substr( :STATION, 8, 1 ) ) )
Graph Builder(
	Size( 523, 448 ),
	Graph Spacing( 4 ),
	Variables( X( :DATE ), Y( :TAVG ), Overlay( :group, Overlay Encoding( "None" ) ), Color( :cgroup ) ),
	Local Data Filter(
		Add Filter( columns( :STATION ),
			Where(
				:STATION == {"USW00012924", "USW00013733", "USW00013877", "USW00014751", "USW00014922", "USW00024024"}
	SendToReport(
		Dispatch( {}, "400", ScaleBox,
			{Legend Model( 31, Properties( 3, {Line Width( 0 )}, Item ID( "break", 1 ) ) )}
		Dispatch( {}, "400", LegendBox, {Legend Position( {31, [0, 1, 2, -1, -4, -4, -4]} )} )
