  • Donโ€™t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder: Line - possibility to add breaks (๐Ÿ’š)
โ˜‘ cool new feature
โ˜‘ could help many users!
โ˜‘ removes a โ€žbugโ€œ
โ˜ nice to have
โ˜ nobody needs it
#myTop10_2024
For Line Graphs in Graph Builder, there is a cool feature row order.
If it's selected, the line doesn't connect data points from left to right in the graph - but along the order in which they appear in the data table.
Instead of this graph:
the user gets this graph:
Much better ...
But unfortunately, there are those nasty jumps "back" to the next curve.
Of course, for simple graphs, you can use a column (here "Station") as an overlay to produce 3 separate curves, without the zigzag.
But already with slightly more complicated graphs like this one here: Graph Builder. Combine Smoother and Line - how? the user reaches the limits of current Graph Builder (v17, v18).
  1.  With sorted data in the data table, a step from right to left indicates a new curve.
    So, with row order enabled, there could be an additional option to draw lines  "only left -> right".
    If this option is enabled, line for steps from higher to lower values will disappear -> the jump back-lines are gone : )
  2. Fallback:  Rows with missing y value could be used to add a break in line graphs (even somewhere in the center of the graph - cool, right?)
    ... if there was an option: *)
Why is this idea important?
a tiny change of the program - a  tremendous improvement for the users:
dt =Open( "$SAMPLE_DATA/Functional Data/Weekly Weather Data.jmp" );
dt << New Column( "group",Character,"Nominal",Formula( Substr( :STATION, 8, 1 ) ));
Graph Builder(
	Size( 523, 407 ),
	Summary Statistic( "Median" ),
	Graph Spacing( 4 ),
	Variables( X( :DATE ), Y( :TAVG ), Overlay( :group ), Color( :group ) ),
	Elements( Line( X, Y, Legend( 31 ), Row order( 1 ) ) ),
	Local Data Filter(
		Add Filter(
			columns( :STATION ),
			Where( :STATION == {"USW00003195", "USW00003868", "USW00003949"} ),
			Display( :STATION, N Items( 15 ) )
19 Comments
hogi
Level XIII
Option (2) is already available in Jmp:
Nevertheless, option (1) is still the preferred solution - can solve the issues of the backward jumps without the need to add auxiliary rows to the data table:
Craige_Hales
Interesting idea - if the X (or Y) order decreases, start a new line
hogi
Level XIII
Thanks @Craige_Hales
With some luck, a developer will find the wish and likes it ...
hogi
Level XIII
@mia_stephens , easy to implement - could help a lot.
Till the new feature is available...
I just uploaded a new version of QuickSelect Toolbar .
It has a new function:
The idea:
Add dummy rows between every block of data - to add a break in the line plot.
It adds the new lines at the end of the table and uses a numeric column for sorting. Unfortunately, sorting a table is forbidden if reports are open (!)
-> will benefit from Sort data table + add rows + concatenate -- make it possible
But I hope that
will come first ...
BHarris
Level VII
In this case you can just create a new column (variable) for whatever's different between the lines, then drop that variable into Overlay, which breaks the lines correctly.
hogi
Level XIII
I never have free Overlay Dropzones ; )
This is a very common use case in our company.
Here is an example with Weather data - in this case, the Overlay is used for the Smoother:
Sarah-Sylvestre
Level V
hogi
Level XIII
Hi @Sarah-Sylvestre , "removing the zig-zag" lines cold be combined with other options to facilitate the formatting of plots in Graph Builder:
(view in My Videos)
hogi
Level XIII
#DACH2024
XanGregg
Another work-around, in case it's useful. Assigning the backwards line segments their own legend color item with width 0.
dt = Open( "$SAMPLE_DATA/Functional Data/Weekly Weather Data.jmp" );
dt << New Column( "group", Character, "Nominal", Formula( Substr( :STATION, 8, 1 ) ) );
dt << New Column( "cgroup", Character, "Nominal",
	Formula( If( Row() == 1 | Lag( :DATE ) > :DATE, "break", Substr( :STATION, 8, 1 ) ) )
Graph Builder(
	Size( 523, 448 ),
	Graph Spacing( 4 ),
	Variables( X( :DATE ), Y( :TAVG ), Overlay( :group, Overlay Encoding( "None" ) ), Color( :cgroup ) ),
	Local Data Filter(
		Add Filter( columns( :STATION ),
			Where(
				:STATION == {"USW00012924", "USW00013733", "USW00013877", "USW00014751", "USW00014922", "USW00024024"}
	SendToReport(
		Dispatch( {}, "400", ScaleBox,
			{Legend Model( 31, Properties( 3, {Line Width( 0 )}, Item ID( "break", 1 ) ) )}
		Dispatch( {}, "400", LegendBox, {Legend Position( {31, [0, 1, 2, -1, -4, -4, -4]} )} )
