%3CLINGO-SUB%20id%3D%22lingo-sub-781753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGraph%20Builder%3A%20habilite%20el%20dimensionamiento%20de%20puntos%20teniendo%20en%20cuenta%20los%20ejes%20con%20la%20zona%20de%20colocaci%C3%B3n%20de%20tama%C3%B1o%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-781753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%C2%BFQu%C3%A9%20inspir%C3%B3%20esta%20solicitud%20de%20lista%20de%20deseos%3F%3C%2FSTRONG%3E%20A%20menudo%2C%20la%20variable%20que%20se%20coloca%20en%20la%20zona%20de%20colocaci%C3%B3n%20de%20%22Tama%C3%B1o%22%20del%20Constructor%20de%20gr%C3%A1ficos%20tiene%20las%20mismas%20unidades%20que%20los%20ejes%20X%20e%20Y%20(por%20ejemplo%2C%20cent%C3%ADmetros)%2C%20por%20lo%20que%20desde%20el%20punto%20de%20vista%20de%20la%20representaci%C3%B3n%20gr%C3%A1fica%20tiene%20sentido%20que%20el%20marcador%20se%20dibuje%20para%20que%20coincida%20con%20el%20tama%C3%B1o%20de%20esas%20unidades%20(ejemplo%20a%20continuaci%C3%B3n).%20Esto%20facilitar%C3%ADa%20enormemente%20las%20visualizaciones%20topogr%C3%A1ficas%20y%20de%20mapeo%20de%20superficies%20b%C3%A1sicas%20dentro%20del%20Constructor%20de%20gr%C3%A1ficos.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3E%C2%BFQu%C3%A9%20mejora%20le%20gustar%C3%ADa%20ver%3F%3C%2FSTRONG%3E%20Me%20gustar%C3%ADa%20que%20el%20cuadro%20%22Configuraci%C3%B3n%20de%20tama%C3%B1o...%22%20(haga%20clic%20con%20el%20bot%C3%B3n%20derecho%20en%20la%20leyenda)%20tuviera%20una%20casilla%20de%20verificaci%C3%B3n%20%22Igualar%20escala%20de%20ejes%22.%20(ejemplo%20a%20continuaci%C3%B3n)%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3E%C2%BFPor%20qu%C3%A9%20es%20importante%20esta%20idea%3F%3C%2FSTRONG%3E%20Permitir%C3%A1%20la%20visualizaci%C3%B3n%20a%20escala%20de%20regiones%20de%20formas%20simples%20en%20ejes%20donde%20las%20variables%20X%2C%20Y%20y%20Size%20tienen%20las%20mismas%20unidades.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E-----%3C%2FP%3E%3CP%3EEjemplo%3A%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3ESupongamos%20que%20tengo%20un%20conjunto%20de%20datos%20de%20defectos%20encontrados%20en%20una%20superficie%20de%20productos%20manufacturados%20que%20se%20ve%20as%C3%AD%3A%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CTABLE%20border%3D%221%22%3E%3CTBODY%3E%3CTR%3E%3CTD%3ESN%3C%2FTD%3E%3CTD%3EX(cm)%3C%2FTD%3E%3CTD%3EY(cm)%3C%2FTD%3E%3CTD%3EDi%C3%A1metro%20(cm)%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0001%3C%2FTD%3E%3CTD%3E2.3%3C%2FTD%3E%3CTD%3E1.15%3C%2FTD%3E%3CTD%3E0%2C04%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0001%3C%2FTD%3E%3CTD%3E2.7%3C%2FTD%3E%3CTD%3E0%2C44%3C%2FTD%3E%3CTD%3E0%2C12%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0001%3C%2FTD%3E%3CTD%3E1.5%3C%2FTD%3E%3CTD%3E2.6%3C%2FTD%3E%3CTD%3E0%2C35%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0002%3C%2FTD%3E%3CTD%3E5.4%3C%2FTD%3E%3CTD%3E1.9%3C%2FTD%3E%3CTD%3E0%2C17%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0002%3C%2FTD%3E%3CTD%3E3.1%3C%2FTD%3E%3CTD%3E4.1%3C%2FTD%3E%3CTD%3E0%2C59%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%20%3C%2FP%3E%3CP%3ECon%20la%20idea%20anterior%2C%20para%20visualizar%20los%20defectos%20en%20Graph%20Builder%2C%20el%20usuario%20crear%C3%ADa%20un%20filtro%20de%20datos%20local%20para%20SN%2C%20luego%20trazar%C3%ADa%20puntos%20con%20X(cm)-%26gt%3BX%2C%20Y(cm)-%26gt%3BY%20y%20Di%C3%A1metro(cm)-%26gt%3BTama%C3%B1o%2C%20luego%20har%C3%ADa%20clic%20en%20%22Coincidir%20con%20escala%20de%20ejes%22%20en%20el%20cuadro%20de%20di%C3%A1logo%20%22Configuraci%C3%B3n%20de%20tama%C3%B1o...%22.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3ELos%20puntos%20circulares%20predeterminados%20se%20dibujar%C3%ADan%20como%20%C3%B3valos%20con%20los%20semiejes%20mayor%2Fmenor%20de%20longitud%20_Di%C3%A1metro(cm)_%20a%20lo%20largo%20de%20cada%20eje.%20Otros%20tipos%20de%20marcadores%20se%20escalar%C3%ADan%20de%20manera%20similar%2C%20pero%20esto%20ser%C3%ADa%20m%C3%A1s%20%C3%BAtil%20para%20los%20marcadores%20circulares%2Fcuadrados.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EJMP%20versi%C3%B3n%2017%2B%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-781753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EExploraci%C3%B3n%20y%20visualizaci%C3%B3n%20de%20datos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-782090%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ERe%3A%20Graph%20Builder%3A%20habilite%20el%20dimensionamiento%20de%20puntos%20teniendo%20en%20cuenta%20los%20ejes%20con%20la%20zona%20de%20colocaci%C3%B3n%20de%20tama%C3%B1o%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-782090%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3ENo%20estoy%20seguro%20de%20si%20tambi%C3%A9n%20deber%C3%ADa%20haber%20una%20opci%C3%B3n%20para%20forzar%20la%20escala%20para%20que%20siga%20solo%20un%20eje%20(vertical%2Fhorizontal)%20o%20ambos%20al%20mismo%20tiempo%20(de%20manera%20predeterminada%2C%20deber%C3%ADa%20seguir%20ambos).%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EEnlace%20a%20la%20discusi%C3%B3n%20original%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2FMaking-Graph-Builder-s-quot-Size-quot-scale-to-axes%2Fm-p%2F781682%23U781682%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-forum-thread%20lia-fa-icon%20lia-fa-forum%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3EC%C3%B3mo%20hacer%20que%20el%20%22Tama%C3%B1o%22%20de%20Graph%20Builder%20se%20escale%20a%20los%20ejes%3C%2FA%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-797651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Graph%20Builder%3A%20Habilite%20el%20dimensionamiento%20de%20puntos%20teniendo%20en%20cuenta%20los%20ejes%20con%20la%20zona%20de%20colocaci%C3%B3n%20de%20tama%C3%B1o.%20Estado%20cambiado%20a%3A%20Reconocido%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-797651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EInteresante%20idea%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F12313%22%20target%3D%22_blank%22%3E%40BHarris%3C%2FA%3E%20%2C%20%C2%A1gracias%20por%20publicar!%3C%2FP%3E%3C%2FLINGO-BODY%3E
Graph Builder: Enable axes-aware sizing of dots with Size drop-zone
What inspired this wish list request?   Often the variable being dropped in the Graph Builder "Size" drop-zone has the same units as the X and Y axes (e.g. centimeters), so from a plotting standpoint it makes sense that the marker be drawn to match the size of those units (example below).  This would make basic surface-mapping/topographical visualizations within Graph Builder very easy.
What is the improvement you would like to see?  I would like the "Size Settings..."  (right-click the legend) box to have a "Match Axes Scale" checkbox.  (example below)
Why is this idea important?  This will enable scaled visualization of simple-shaped regions on axes where the X, Y, and Size variables all have the same units.
Example:
Suppose I have a dataset of flaws found on a surface of manufactured products that looks like this:
SNX(cm)Y(cm)Diameter(cm)
00012.31.150.04
00012.70.440.12
00011.52.60.35
00025.41.90.17
00023.14.10.59
With the idea above, to visualize the defects in Graph Builder the user would create a Local-Data-Filter for SN, then plot points with X(cm)->X, Y(cm)->Y, and Diameter(cm)->Size, then click "Match Axes Scale" in the "Size settings..." dialog.
The default circular points would be drawn as ovals with the semi-major/minor axes of length _Diameter(cm)_ along each axis.  Other marker types would be scaled similarly, but this would be most useful for circle/square markers.
JMP v17+
2 Comments
jthi
I'm not sure if there should also be an option for force the scaling to follow only one axis (vertical/horizontal) or both of them at the same time (by default it should follow both).
Link to original discussion: Making Graph Builder's "Size" scale to axes
mia_stephens
Interesting idea @BHarris , thank you for posting!
