%3CLINGO-SUB%20id%3D%22lingo-sub-781753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EG%C3%A9n%C3%A9rateur%20de%20graphiques%26nbsp%3B%3A%20activez%20le%20dimensionnement%20des%20points%20en%20fonction%20des%20axes%20avec%20la%20zone%20de%20d%C3%A9p%C3%B4t%20Taille%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-781753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3EQu'est-ce%20qui%20a%20inspir%C3%A9%20cette%20demande%20de%20liste%20de%20souhaits%20%3F%3C%2FSTRONG%3E%20Souvent%2C%20la%20variable%20d%C3%A9pos%C3%A9e%20dans%20la%20zone%20de%20d%C3%A9p%C3%B4t%20%C2%AB%20Taille%20%C2%BB%20de%20Graph%20Builder%20a%20les%20m%C3%AAmes%20unit%C3%A9s%20que%20les%20axes%20X%20et%20Y%20(par%20exemple%2C%20les%20centim%C3%A8tres)%2C%20donc%20du%20point%20de%20vue%20du%20tra%C3%A7age%2C%20il%20est%20logique%20que%20le%20marqueur%20soit%20dessin%C3%A9%20pour%20correspondre%20%C3%A0%20la%20taille%20de%20ces%20unit%C3%A9s%20(exemple%20ci-dessous).%20Cela%20rendrait%20les%20visualisations%20topographiques%2Fcartographies%20de%20surface%20de%20base%20dans%20Graph%20Builder%20tr%C3%A8s%20faciles.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EQuelle%20am%C3%A9lioration%20souhaiteriez-vous%20voir%20%3F%3C%2FSTRONG%3E%20Je%20souhaiterais%20que%20la%20case%20%C2%AB%20Param%C3%A8tres%20de%20taille...%20%C2%BB%20(clic%20droit%20sur%20la%20l%C3%A9gende)%20contienne%20une%20case%20%C3%A0%20cocher%20%C2%AB%20Faire%20correspondre%20l'%C3%A9chelle%20des%20axes%20%C2%BB.%20(exemple%20ci-dessous)%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EPourquoi%20cette%20id%C3%A9e%20est-elle%20importante%20%3F%3C%2FSTRONG%3E%20Elle%20permettra%20une%20visualisation%20%C3%A0%20l'%C3%A9chelle%20de%20r%C3%A9gions%20de%20forme%20simple%20sur%20des%20axes%20o%C3%B9%20les%20variables%20X%2C%20Y%20et%20Size%20ont%20toutes%20les%20m%C3%AAmes%20unit%C3%A9s.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E-----%3C%2FP%3E%3CP%3EExemple%3A%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3ESupposons%20que%20j'ai%20un%20ensemble%20de%20donn%C3%A9es%20de%20d%C3%A9fauts%20trouv%C3%A9s%20sur%20une%20surface%20de%20produits%20manufactur%C3%A9s%20qui%20ressemble%20%C3%A0%20ceci%26nbsp%3B%3A%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CTABLE%20border%3D%221%22%3E%3CTBODY%3E%3CTR%3E%3CTD%3ESN%3C%2FTD%3E%3CTD%3EX(cm)%3C%2FTD%3E%3CTD%3EOui(cm)%3C%2FTD%3E%3CTD%3EDiam%C3%A8tre%20(cm)%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0001%3C%2FTD%3E%3CTD%3E2.3%3C%2FTD%3E%3CTD%3E1.15%3C%2FTD%3E%3CTD%3E0%2C04%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0001%3C%2FTD%3E%3CTD%3E2.7%3C%2FTD%3E%3CTD%3E0%2C44%3C%2FTD%3E%3CTD%3E0%2C12%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0001%3C%2FTD%3E%3CTD%3E1%2C5%3C%2FTD%3E%3CTD%3E2.6%3C%2FTD%3E%3CTD%3E0%2C35%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0002%3C%2FTD%3E%3CTD%3E5.4%3C%2FTD%3E%3CTD%3E1.9%3C%2FTD%3E%3CTD%3E0%2C17%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0002%3C%2FTD%3E%3CTD%3E3.1%3C%2FTD%3E%3CTD%3E4.1%3C%2FTD%3E%3CTD%3E0%2C59%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%20%3C%2FP%3E%3CP%3EAvec%20l'id%C3%A9e%20ci-dessus%2C%20pour%20visualiser%20les%20d%C3%A9fauts%20dans%20Graph%20Builder%2C%20l'utilisateur%20cr%C3%A9erait%20un%20filtre%20de%20donn%C3%A9es%20locales%20pour%20SN%2C%20puis%20tracerait%20des%20points%20avec%20X(cm)-%26gt%3BX%2C%20Y(cm)-%26gt%3BY%20et%20Diam%C3%A8tre(cm)-%26gt%3BTaille%2C%20puis%20cliquerait%20sur%20%C2%AB%26nbsp%3BFaire%20correspondre%20l'%C3%A9chelle%20des%20axes%26nbsp%3B%C2%BB%20dans%20la%20bo%C3%AEte%20de%20dialogue%20%C2%AB%26nbsp%3BParam%C3%A8tres%20de%20taille...%26nbsp%3B%C2%BB.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3ELes%20points%20circulaires%20par%20d%C3%A9faut%20seraient%20dessin%C3%A9s%20sous%20forme%20d'ovales%20avec%20les%20axes%20semi-majeurs%2Fmineurs%20de%20longueur%20_Diam%C3%A8tre(cm)_%20le%20long%20de%20chaque%20axe.%20D'autres%20types%20de%20marqueurs%20seraient%20mis%20%C3%A0%20l'%C3%A9chelle%20de%20la%20m%C3%AAme%20mani%C3%A8re%2C%20mais%20cela%20serait%20particuli%C3%A8rement%20utile%20pour%20les%20marqueurs%20de%20cercle%2Fcarr%C3%A9.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EJMP%20v17%2B%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-781753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EExploration%20et%20visualisation%20des%20donn%C3%A9es%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-782090%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ERe%3A%20Graph%20Builder%26nbsp%3B%3A%20activer%20le%20dimensionnement%20des%20points%20en%20fonction%20des%20axes%20avec%20la%20zone%20de%20d%C3%A9p%C3%B4t%20Taille%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-782090%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EJe%20ne%20sais%20pas%20s'il%20devrait%20%C3%A9galement%20y%20avoir%20une%20option%20pour%20forcer%20la%20mise%20%C3%A0%20l'%C3%A9chelle%20%C3%A0%20suivre%20un%20seul%20axe%20(vertical%2Fhorizontal)%20ou%20les%20deux%20en%20m%C3%AAme%20temps%20(par%20d%C3%A9faut%2C%20elle%20devrait%20suivre%20les%20deux).%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3ELien%20vers%20la%20discussion%20d'origine%26nbsp%3B%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2FMaking-Graph-Builder-s-quot-Size-quot-scale-to-axes%2Fm-p%2F781682%23U781682%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-forum-thread%20lia-fa-icon%20lia-fa-forum%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3EAdapter%20la%20%C2%AB%26nbsp%3Btaille%26nbsp%3B%C2%BB%20de%20Graph%20Builder%20aux%20axes%3C%2FA%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-797651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Graph%20Builder%20%3A%20Activer%20le%20dimensionnement%20des%20points%20en%20fonction%20des%20axes%20avec%20la%20zone%20de%20d%C3%A9p%C3%B4t%20Taille%20-%20Statut%20modifi%C3%A9%20en%20%3A%20Reconnu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-797651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EId%C3%A9e%20int%C3%A9ressante%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F12313%22%20target%3D%22_blank%22%3E%40BHarris%3C%2FA%3E%20%2C%20merci%20pour%20la%20publication%26nbsp%3B!%3C%2FP%3E%3C%2FLINGO-BODY%3E
Graph Builder: Enable axes-aware sizing of dots with Size drop-zone
What inspired this wish list request?   Often the variable being dropped in the Graph Builder "Size" drop-zone has the same units as the X and Y axes (e.g. centimeters), so from a plotting standpoint it makes sense that the marker be drawn to match the size of those units (example below).  This would make basic surface-mapping/topographical visualizations within Graph Builder very easy.
What is the improvement you would like to see?  I would like the "Size Settings..."  (right-click the legend) box to have a "Match Axes Scale" checkbox.  (example below)
Why is this idea important?  This will enable scaled visualization of simple-shaped regions on axes where the X, Y, and Size variables all have the same units.
Example:
Suppose I have a dataset of flaws found on a surface of manufactured products that looks like this:
SNX(cm)Y(cm)Diameter(cm)
00012.31.150.04
00012.70.440.12
00011.52.60.35
00025.41.90.17
00023.14.10.59
With the idea above, to visualize the defects in Graph Builder the user would create a Local-Data-Filter for SN, then plot points with X(cm)->X, Y(cm)->Y, and Diameter(cm)->Size, then click "Match Axes Scale" in the "Size settings..." dialog.
The default circular points would be drawn as ovals with the semi-major/minor axes of length _Diameter(cm)_ along each axis.  Other marker types would be scaled similarly, but this would be most useful for circle/square markers.
JMP v17+
2 Comments
jthi
I'm not sure if there should also be an option for force the scaling to follow only one axis (vertical/horizontal) or both of them at the same time (by default it should follow both).
Link to original discussion: Making Graph Builder's "Size" scale to axes
mia_stephens
Interesting idea @BHarris , thank you for posting!
