%3CLINGO-SUB%20id%3D%22lingo-sub-781753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGraph%20Builder%3A%20abilita%20il%20dimensionamento%20dei%20punti%20in%20base%20agli%20assi%20con%20la%20zona%20di%20rilascio%20delle%20dimensioni%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-781753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3ECosa%20ha%20ispirato%20questa%20richiesta%20di%20lista%20dei%20desideri%3F%3C%2FSTRONG%3E%20Spesso%20la%20variabile%20che%20viene%20rilasciata%20nella%20zona%20di%20rilascio%20%22Dimensioni%22%20di%20Graph%20Builder%20ha%20le%20stesse%20unit%C3%A0%20degli%20assi%20X%20e%20Y%20(ad%20esempio%20centimetri)%2C%20quindi%20dal%20punto%20di%20vista%20del%20tracciamento%20ha%20senso%20che%20il%20marcatore%20venga%20disegnato%20in%20modo%20che%20corrisponda%20alle%20dimensioni%20di%20tali%20unit%C3%A0%20(esempio%20di%20seguito).%20Ci%C3%B2%20renderebbe%20molto%20semplici%20le%20visualizzazioni%20di%20base%20di%20mappatura%20delle%20superfici%2Ftopografiche%20in%20Graph%20Builder.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EQuale%20miglioramento%20vorresti%20vedere%3F%3C%2FSTRONG%3E%20Vorrei%20che%20la%20casella%20%22Impostazioni%20dimensioni...%22%20(clicca%20con%20il%20tasto%20destro%20sulla%20legenda)%20avesse%20una%20casella%20di%20controllo%20%22Corrispondenza%20scala%20assi%22.%20(esempio%20sotto)%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EPerch%C3%A9%20questa%20idea%20%C3%A8%20importante%3F%3C%2FSTRONG%3E%20Ci%C3%B2%20consentir%C3%A0%20la%20visualizzazione%20in%20scala%20di%20regioni%20di%20forma%20semplice%20su%20assi%20in%20cui%20le%20variabili%20X%2C%20Y%20e%20Size%20hanno%20tutte%20le%20stesse%20unit%C3%A0.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E-----%3C%2FP%3E%3CP%3EEsempio%3A%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3ESupponiamo%20di%20avere%20un%20set%20di%20dati%20di%20difetti%20rilevati%20sulla%20superficie%20di%20prodotti%20fabbricati%20che%20si%20presenta%20in%20questo%20modo%3A%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CTABLE%20border%3D%221%22%3E%3CTBODY%3E%3CTR%3E%3CTD%3ESN%3C%2FTD%3E%3CTD%3EX(centimetro)%3C%2FTD%3E%3CTD%3EY(cm)%3C%2FTD%3E%3CTD%3EDiametro%20(cm)%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0001%3C%2FTD%3E%3CTD%3E2.3%3C%2FTD%3E%3CTD%3E1.15%3C%2FTD%3E%3CTD%3E0%2C04%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0001%3C%2FTD%3E%3CTD%3E2.7%3C%2FTD%3E%3CTD%3E0%2C44%3C%2FTD%3E%3CTD%3E0%2C12%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0001%3C%2FTD%3E%3CTD%3E1.5%3C%2FTD%3E%3CTD%3E2.6%3C%2FTD%3E%3CTD%3E0%2C35%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0002%3C%2FTD%3E%3CTD%3E5.4%3C%2FTD%3E%3CTD%3E1.9%3C%2FTD%3E%3CTD%3E0%2C17%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E0002%3C%2FTD%3E%3CTD%3E3.1%3C%2FTD%3E%3CTD%3E4.1%3C%2FTD%3E%3CTD%3E0%2C59%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%20%3C%2FP%3E%3CP%3ECon%20l'idea%20di%20cui%20sopra%2C%20per%20visualizzare%20i%20difetti%20in%20Graph%20Builder%20l'utente%20dovrebbe%20creare%20un%20filtro%20dati%20locale%20per%20SN%2C%20quindi%20tracciare%20i%20punti%20con%20X(cm)-%26gt%3BX%2C%20Y(cm)-%26gt%3BY%20e%20Diametro(cm)-%26gt%3BDimensione%2C%20quindi%20fare%20clic%20su%20%22Corrispondenza%20scala%20assi%22%20nella%20finestra%20di%20dialogo%20%22Impostazioni%20dimensioni...%22.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EI%20punti%20circolari%20predefiniti%20verrebbero%20disegnati%20come%20ovali%20con%20i%20semiassi%20maggiori%2Fminori%20di%20lunghezza%20_Diametro(cm)_%20lungo%20ogni%20asse.%20Altri%20tipi%20di%20marcatori%20verrebbero%20scalati%20in%20modo%20simile%2C%20ma%20questo%20sarebbe%20pi%C3%B9%20utile%20per%20i%20marcatori%20cerchio%2Fquadrato.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EVersione%20JMP%20v17%2B%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-781753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EEsplorazione%20e%20visualizzazione%20dei%20dati%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-782090%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ERe%3A%20Graph%20Builder%3A%20Abilita%20il%20dimensionamento%20dei%20punti%20in%20base%20agli%20assi%20con%20la%20zona%20di%20rilascio%20delle%20dimensioni%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-782090%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3ENon%20sono%20sicuro%20se%20dovrebbe%20esserci%20anche%20un'opzione%20per%20forzare%20il%20ridimensionamento%20in%20modo%20che%20segua%20solo%20un%20asse%20(verticale%2Forizzontale)%20o%20entrambi%20contemporaneamente%20(per%20impostazione%20predefinita%20dovrebbe%20seguirli%20entrambi).%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3ECollegamento%20alla%20discussione%20originale%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2FMaking-Graph-Builder-s-quot-Size-quot-scale-to-axes%2Fm-p%2F781682%23U781682%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-forum-thread%20lia-fa-icon%20lia-fa-forum%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3ERendere%20la%20scala%20%22Dimensione%22%20di%20Graph%20Builder%20adattata%20agli%20assi%3C%2FA%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-797651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Graph%20Builder%3A%20Abilita%20il%20dimensionamento%20dei%20punti%20in%20base%20agli%20assi%20con%20la%20zona%20di%20rilascio%20delle%20dimensioni%20-%20Stato%20modificato%20in%3A%20Riconosciuto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-797651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIdea%20interessante%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F12313%22%20target%3D%22_blank%22%3E%40BHarris%3C%2FA%3E%20%2C%20grazie%20per%20averla%20pubblicata!%3C%2FP%3E%3C%2FLINGO-BODY%3E
Graph Builder: Enable axes-aware sizing of dots with Size drop-zone
What inspired this wish list request?   Often the variable being dropped in the Graph Builder "Size" drop-zone has the same units as the X and Y axes (e.g. centimeters), so from a plotting standpoint it makes sense that the marker be drawn to match the size of those units (example below).  This would make basic surface-mapping/topographical visualizations within Graph Builder very easy.
What is the improvement you would like to see?  I would like the "Size Settings..."  (right-click the legend) box to have a "Match Axes Scale" checkbox.  (example below)
Why is this idea important?  This will enable scaled visualization of simple-shaped regions on axes where the X, Y, and Size variables all have the same units.
Example:
Suppose I have a dataset of flaws found on a surface of manufactured products that looks like this:
SNX(cm)Y(cm)Diameter(cm)
00012.31.150.04
00012.70.440.12
00011.52.60.35
00025.41.90.17
00023.14.10.59
With the idea above, to visualize the defects in Graph Builder the user would create a Local-Data-Filter for SN, then plot points with X(cm)->X, Y(cm)->Y, and Diameter(cm)->Size, then click "Match Axes Scale" in the "Size settings..." dialog.
The default circular points would be drawn as ovals with the semi-major/minor axes of length _Diameter(cm)_ along each axis.  Other marker types would be scaled similarly, but this would be most useful for circle/square markers.
JMP v17+
2 Comments
jthi
I'm not sure if there should also be an option for force the scaling to follow only one axis (vertical/horizontal) or both of them at the same time (by default it should follow both).
Link to original discussion: Making Graph Builder's "Size" scale to axes
mia_stephens
Interesting idea @BHarris , thank you for posting!
