Broken axis in graph builder
Hello,
Having the possibility to choose range shown on Y axis in graph builder would be great!
when you have data on a wide range it is not nice to have them flattened because you have to show all data on Y.
Thanks in advance,
Marie
6 Comments
Hi @mgerusdurand, thank you for your suggestion! We have captured your request and will take it under consideration.
Status changed to: Needs Info
Hi @mgerusdurand, thank you for submitting this request! I was hoping you could check out this blog post discussing how you can accomplish this in JMP. Let me know if that helps at all and if I understood your request. That is just a workaround, but I was hoping you could tell me more about your use case? As the blog post discusses, is there a reason your data has to be in one graph?
mgerusdurand
Level IV
Hi @Sarah-Sylvestre ,
This blog is showing broken axis indeed but I agree with the author that this is 2 side by side graphs with different scales and that is not what I would like.
In fact we have stability data from day 0 to day 90 but without data between day 14 and day 90 let say. In this case, to be able to see all my curve, I if I want to see all my data point separately I need to get a huge X axis. This is not ideal when incorporated the graph in a word report for example. Si I would like to be able just to hide X axis segment between 14 and 90 days.
Hope this help
Thank you for the additional info!
hogi
Level XIII
another wish with the same topic:
Add easily configurable axis breaks to the Graph Builder
workarounds to get some task done: cool.
plots which look like workarounds: not so cool.
Options for axis breaks in Origin:
https://www.originlab.com/doc/Origin-Help/AxesRef-Breaks
