Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
Hi @mgerusdurand, thank you for submitting this request! I was hoping you could check out this blog post discussing how you can accomplish this in JMP. Let me know if that helps at all and if I understood your request. That is just a workaround, but I was hoping you could tell me more about your use case? As the blog post discusses, is there a reason your data has to be in one graph?
This blog is showing broken axis indeed but I agree with the author that this is 2 side by side graphs with different scales and that is not what I would like.
In fact we have stability data from day 0 to day 90 but without data between day 14 and day 90 let say. In this case, to be able to see all my curve, I if I want to see all my data point separately I need to get a huge X axis. This is not ideal when incorporated the graph in a word report for example. Si I would like to be able just to hide X axis segment between 14 and 90 days.
