  • See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Broken axis in graph builder
Hello,
Having the possibility to choose range shown on Y axis in graph builder would be great!
when you have data on a wide range it is not nice to have them flattened because you have to show all data on Y.
Thanks in advance,
Marie
6 Comments
Hi @mgerusdurand, thank you for your suggestion! We have captured your request and will take it under consideration.
Status changed to: Needs Info
Hi @mgerusdurand, thank you for submitting this request! I was hoping you could check out this blog post discussing how you can accomplish this in JMP. Let me know if that helps at all and if I understood your request. That is just a workaround, but I was hoping you could tell me more about your use case? As the blog post discusses, is there a reason your data has to be in one graph?
mgerusdurand
Level IV
Hi @Sarah-Sylvestre ,
This blog is showing broken axis indeed but I agree with the author that this is 2 side by side graphs with different scales and that is not what I would like.
In fact we have stability data from day 0 to day 90 but without data between day 14 and day 90 let say. In this case, to be able to see all my curve, I if I want to see all my data point separately I need to get a huge X axis. This is not ideal when incorporated the graph in a word report for example. Si I would like to be able just to hide X axis segment between 14 and 90 days.
Hope this help
Thank you for the additional info!
hogi
Level XIII
another wish with the same topic:
Add easily configurable axis breaks to the Graph Builder
workarounds to get some task done: cool.
plots which look like workarounds: not so cool.
Options for axis breaks in Origin:
https://www.originlab.com/doc/Origin-Help/AxesRef-Breaks
