JMP Tips
Change Multiple Columns Simultaneously
Apply attributes and properties (such as formulas) to several columns at once:
  1. Select the column with the attributes that you want to copy.
  2. Select Cols > Standardize Attributes.
  3. Click the Attributes button and select the attribute name that you want to copy to the destination columns.
  4. Click the button next to Format and select the format that you want to use and any additional options.
  5. In the data table, select the destination columns.
  6. In the Standardize Attributes window, click OK.
Selecting the AttributeSelecting the Attribute Selecting the FormatSelecting the Format
