JMP Blog
%3CLINGO-SUB%20id%3D%22lingo-sub-753571%22%20slang%3D%22zh-TW%22%20mode%3D%22CREATE%22%3EQu'est-ce%20que%20le%20SPC%20(contr%C3%B4le%20statistique%20des%20processus)%26nbsp%3B%3F%20Explication%20du%20processus%20d'analyse%20et%20interpr%C3%A9tation%20des%20donn%C3%A9es%20pour%20r%C3%A9duire%20la%20variation%20du%20processus%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-753571%22%20slang%3D%22zh-TW%22%20mode%3D%22CREATE%22%3E%3CP%3EAtteindre%20l%E2%80%99excellence%20en%20mati%C3%A8re%20de%20fabrication%20est%20l%E2%80%99objectif%20poursuivi%20par%20chaque%20entreprise.%20Pour%20atteindre%20cet%20objectif%2C%20le%20service%20qualit%C3%A9%20doit%20travailler%20en%20permanence%20pour%20identifier%20les%20sources%20de%20variation%20des%20processus%20et%20prendre%20les%20mesures%20appropri%C3%A9es%20pour%20contr%C3%B4ler%20l'objectif.%20%C3%80%20l'%C3%A8re%20scientifique%20moderne%2C%20les%20unit%C3%A9s%20de%20qualit%C3%A9%20peuvent%20d%C3%A9j%C3%A0%20comprendre%20le%20processus%20de%20production%20gr%C3%A2ce%20%C3%A0%20l'analyse%20des%20donn%C3%A9es%2C%20ce%20qui%20peut%20non%20seulement%20augmenter%20la%20flexibilit%C3%A9%20de%20la%20production%2C%20mais%20%C3%A9galement%20garantir%20que%20les%20produits%20r%C3%A9pondent%20mieux%20aux%20exigences%20des%20clients.%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId-1792438906%22%20id%3D%22toc-hId-1792525402%22%3E%3CSTRONG%3ETrois%20cl%C3%A9s%20pour%20r%C3%A9aliser%20une%20fabrication%20intelligente%3C%2FSTRONG%3E%3C%2FH2%3E%0A%3CP%3EComment%20atteindre%20l%E2%80%99excellence%20en%20mati%C3%A8re%20de%20fabrication%20sur%20la%20base%20de%20l%E2%80%99analyse%20de%20donn%C3%A9es%20scientifiques%20est%20un%20probl%C3%A8me%20auquel%20toute%20entreprise%20est%20confront%C3%A9e%20lorsqu%E2%80%99elle%20a%20besoin%20d%E2%80%99am%C3%A9liorer%20la%20qualit%C3%A9%20de%20ses%20produits.%20%C3%80%20travers%20%3CSPAN%3Edes%20cas%20industriels%20pass%C3%A9s%20de%20coop%C3%A9ration%20avec%20JMP%2C%20nous%20pouvons%20constater%20que%20%3CFONT%20color%3D%22%23FF6600%22%3E%3CSTRONG%3Eles%20entreprises%20doivent%20passer%20par%20trois%20processus%20cl%C3%A9s%20pour%20atteindre%20l'excellence%20en%20mati%C3%A8re%20de%20fabrication%3C%2FSTRONG%3E%3C%2FFONT%3E%26nbsp%3B%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E1.%20%3CSPAN%3EGr%C3%A2ce%20%C3%A0%20des%20cartes%20de%20contr%C3%B4le%20et%20%C3%A0%20une%20analyse%20de%20la%20capacit%C3%A9%20du%20processus%2C%20un%20contr%C3%B4le%20statistique%20du%20processus%20(SPC)%20est%20mis%20en%20%C5%93uvre%3C%2FSPAN%3E%20%3CSPAN%3Epour%20r%C3%A9duire%20la%20variation%20du%20processus%26nbsp%3B%3B%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3ETrouver%20des%20sources%20de%20variation%20dans%20le%20processus%20de%20mesure%3C%2FSPAN%3E%20%3CSPAN%3Egr%C3%A2ce%20%C3%A0%20l'analyse%20du%20syst%C3%A8me%20de%20mesure%3C%2FSPAN%3E%20(MSA)%3B%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EGr%C3%A2ce%20au%20plan%20d'exp%C3%A9riences%3C%2FSPAN%3E%20(DOE)%20%3CSPAN%3Eet%20%C3%A0%20la%20mod%C3%A9lisation%20pr%C3%A9dictive%2C%20les%20facteurs%20qui%20affectent%20la%20variation%20des%20mesures%20sont%20d%C3%A9termin%C3%A9s%3C%2FSPAN%3E%20et%20les%20param%C3%A8tres%20optimaux%20des%20facteurs%20sont%20trouv%C3%A9s%20pour%20rendre%20le%20processus%20de%20mesure%20plus%20robuste.%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3EPrenons%20le%20cas%20d%E2%80%99un%20fabricant%20pharmaceutique%20pour%20voir%20comment%20mettre%20en%20%C5%93uvre%20cette%20%C2%AB%20trilogie%20d%E2%80%99analyse%20de%20donn%C3%A9es%20%C2%BB.%20Voyons%20d'abord%20comment%20effectuer%20un%20contr%C3%B4le%20statistique%20des%20processus%20(SPC)%20%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId--759718055%22%20id%3D%22toc-hId--759631559%22%3E%3CSTRONG%3EAnalyse%20de%20cas%20pratiques%3C%2FSTRONG%3E%3C%2FH2%3E%0A%3CH3%20id%3D%22toc-hId-786578775%22%20id%3D%22toc-hId-786665271%22%3E%3CSTRONG%3EContexte%20du%20processus%3C%2FSTRONG%3E%3C%2FH3%3E%0A%3CP%3EFVM%20%3CSPAN%3EPharmaceuticals%20est%3C%2FSPAN%3E%20un%20fabricant%20pharmaceutique%20international%20sp%C3%A9cialis%C3%A9%20dans%20la%20production%20de%20produits%20pharmaceutiques%20finis%20de%20haute%20qualit%C3%A9%20sous%20forme%20de%20comprim%C3%A9s%2C%20de%20capsules%20et%20de%20liquides.%20Dans%20le%20processus%20pharmaceutique%2C%20un%20processus%20de%20fabrication%20typique%20comprend%20%3A%20%3CSPAN%3Ele%20broyage%20de%20l'ingr%C3%A9dient%20pharmaceutique%20actif%20(API)%20en%20une%20poudre%20de%20granulom%C3%A9trie%20uniforme%3C%2FSPAN%3E%20%2C%20puis%20le%20m%C3%A9lange%20du%20mat%C3%A9riau%20broy%C3%A9%20avec%20d'autres%20composants%20pour%20augmenter%20le%20volume%20de%20l'API%20et%20le%20r%C3%A9partir%20uniform%C3%A9ment.%20le%20mat%C3%A9riau%20m%C3%A9lang%C3%A9%20est%20ensuite%20compress%C3%A9%20en%20comprim%C3%A9s%20et%20finalement%20enrob%C3%A9%20pour%20am%C3%A9liorer%20la%20dur%C3%A9e%20de%20conservation%2C%20la%20sensation%20en%20bouche%20et%20d'autres%20propri%C3%A9t%C3%A9s.%20A%20la%20fin%20de%20ce%20processus%2C%20diff%C3%A9rents%20param%C3%A8tres%20de%20qualit%C3%A9%20sont%20enregistr%C3%A9s%20pour%20l'acceptation%20des%20lots.%3C%2FP%3E%0A%3CP%3ELes%20mati%C3%A8res%20premi%C3%A8res%20pour%20le%20processus%20ci-dessus%20sont%20des%20%C3%A9mulsions%20concentr%C3%A9es%20contenant%20deux%20compos%C3%A9s%20organiques%2C%20qui%20sont%20fournies%20par%20deux%20fournisseurs%20(A%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20B%20%3CSPAN%3E)%20en%20m%C3%AAme%20temps.%20La%20soci%C3%A9t%C3%A9%20pharmaceutique%3C%2FSPAN%3E%20%3CSPAN%3Esurveille%20la%20qualit%C3%A9%20en%3C%2FSPAN%3E%20%3CSPAN%3Emesurant%20la%20concentration%20(mg%2FL)%20des%20compos%C3%A9s.%20chromatographie%20en%20phase%20gazeuse%20(GC)%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId--1765578186%22%20id%3D%22toc-hId--1765491690%22%3E%3CSTRONG%3Eprobl%C3%A8mes%20de%20situation%20actuelle%3C%2FSTRONG%3E%3C%2FH3%3E%0A%3CP%3ER%C3%A9cemment%2C%20l'%C3%A9quipe%20de%20gestion%20de%20la%20qualit%C3%A9%20a%20d%C3%A9couvert%20qu'il%20existe%20de%20grandes%20diff%C3%A9rences%20dans%20la%20qualit%C3%A9%20des%20m%C3%A9dicaments.%20Gr%C3%A2ce%20au%20d%C3%A9pannage%2C%20on%20soup%C3%A7onne%20que%20le%20probl%C3%A8me%20provient%20probablement%20des%20mati%C3%A8res%20premi%C3%A8res.%20%C3%80%20cette%20fin%2C%20l'entreprise%20a%20sp%C3%A9cialement%20mis%20en%20place%20une%20%C3%A9quipe%20d'am%C3%A9lioration%20de%20la%20qualit%C3%A9%2C%20%3CSTRONG%3Edans%20l'espoir%20d'utiliser%3C%2FSTRONG%3E%20%3CSTRONG%3Edes%20outils%3C%2FSTRONG%3E%20statistiques%20%3CSTRONG%3E%2C%20combin%C3%A9s%20%C3%A0%20la%20qualit%C3%A9%20d%C3%A8s%20la%20conception%3C%2FSTRONG%3E%20%3CSTRONG%3E(%3C%2FSTRONG%3E%20%3CSTRONG%3EQbD%3C%2FSTRONG%3E%20%3CSTRONG%3E%3CSPAN%3E)%2C%20et%20gr%C3%A2ce%20%C3%A0%20une%20prise%20de%20d%C3%A9cision%20bas%C3%A9e%20sur%20les%20donn%C3%A9es%2C%20pour%20trouver%20fondamentalement%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%3CSTRONG%3Eune%3C%2FSTRONG%3E%20%3CSTRONG%3Esolution%20durable%3C%2FSTRONG%3E%20%3CSTRONG%3Eet%3C%2FSTRONG%3E%20%3CSTRONG%3Ed%C3%A9terminer%20les%20changements%20de%20processus%3C%2FSTRONG%3E%20%3CSTRONG%3E.%3C%2FSTRONG%3E%20%3CSTRONG%3Efacteurs%20cl%C3%A9s%3C%2FSTRONG%3E%20pour%20atteindre%20l'objectif%20d'%20%3CSTRONG%3Eoptimisation%20des%20param%C3%A8tres%20de%20processus%3C%2FSTRONG%3E%20.%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId--22767851%22%20id%3D%22toc-hId--22681355%22%3E%3CSTRONG%3EAm%C3%A9liorer%20le%20processus%3C%2FSTRONG%3E%3C%2FH3%3E%0A%3CP%3ETout%20d'abord%2C%20l'%C3%A9quipe%20d'am%C3%A9lioration%20de%20la%20qualit%C3%A9%20effectue%20un%20contr%C3%B4le%20statistique%20des%20processus%20(SPC)%20du%20produit%20%3CSPAN%3E.%3C%2FSPAN%3E%20Comprenez%20la%20stabilit%C3%A9%20du%20processus%20et%20analysez%20le%20mod%C3%A8le%20de%20changements%20de%20processus%20gr%C3%A2ce%20%C3%A0%20des%20cartes%20de%20contr%C3%B4le.%20Gr%C3%A2ce%20%C3%A0%20l'analyse%20de%20la%20capacit%C3%A9%20du%20processus%2C%20%C3%A9valuez%20s'il%20respecte%20%3CSPAN%3Eles%20d%C3%A9lais%20de%20livraison%20clients%2Fexternes.%20Les%20deux%3C%2FSPAN%3E%20outils%20soutiennent%20une%20meilleure%20compr%C3%A9hension%20des%20processus%20et%20guident%20le%20d%C3%A9veloppement%20de%20strat%C3%A9gies%20d%E2%80%99am%C3%A9lioration.%20L'%C3%A9quipe%20%3CSPAN%3Ea%20collect%C3%A9%20des%20%C3%A9chantillons%20de%20deux%20mati%C3%A8res%20premi%C3%A8res%20compos%C3%A9es%20aupr%C3%A8s%20de%20deux%20fournisseurs%20pendant%208%20jours%20et%20les%20a%20import%C3%A9s%20dans%3C%2FSPAN%3E%20le%20%3CSPAN%3Elogiciel%20JMP%2C%20impliquant%20tous%20les%20lots.%20La%20figure%20suivante%20(1)%20est%20une%20capture%20d'%C3%A9cran%20d'une%20partie%20des%20donn%C3%A9es.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20590px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20590px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64099i8EF666A1846F6F10%2Fimage-dimensions%2F590x447%3Fv%3Dv2%22%20width%3D%22590%22%20height%3D%22447%22%20role%3D%22button%22%20title%3D%221.png%22%20alt%3D%221.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigure%20%3CSPAN%3E1%3C%2FSPAN%3E%20)%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId-1523528979%22%20id%3D%22toc-hId-1523615475%22%3E%3CFONT%20color%3D%22%23333399%22%3E%3CSTRONG%3EConditions%20pr%C3%A9alables%20%C3%A0%20l'analyse%26nbsp%3B%3A%20V%C3%A9rifiez%20si%20les%20donn%C3%A9es%20montrent%20une%20normalit%C3%A9%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FH4%3E%0A%3CP%3ELe%20principe%20utilis%C3%A9%20par%20de%20nombreux%20outils%20statistiques%20de%20qualit%C3%A9%20est%20que%20les%20donn%C3%A9es%20proviennent%20d'une%20distribution%20normale%2C%20sinon%20la%20communication%20des%20r%C3%A9sultats%20bas%C3%A9s%20sur%20la%20moyenne%20et%20l'%C3%A9cart%20type%20n'aura%20aucun%20sens.%20Utilisez%20le%20%3CSPAN%3Emenu%20JMP%2C%20cliquez%20sur%20%C2%AB%26nbsp%3BAnalyser%3C%2FSPAN%3E%20%C3%A0%20%3CSPAN%3EDistribution%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%C2%BB%20et%20combinez%3C%2FSPAN%3E%20les%20r%C3%A9sultats%20des%20%3CSPAN%3Etests%20SW%20et%3C%2FSPAN%3E%20AD%20%3CSPAN%3Epour%20confirmer%20que%20les%20deux%20donn%C3%A9es%20compos%C3%A9es%20montrent%20une%20distribution%20normale%2C%20indiquant%20qu'il%20n'y%20a%20pas%20de%20probl%C3%A8me.%20Les%20r%C3%A9sultats%20sont%20pr%C3%A9sent%C3%A9s%20dans%20la%20figure%20(2)%20ci-dessous.%20.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20587px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20587px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64100i4A086018827E5D71%2Fimage-dimensions%2F587x429%3Fv%3Dv2%22%20width%3D%22587%22%20height%3D%22429%22%20role%3D%22button%22%20title%3D%222.png%22%20alt%3D%222.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigure%20%3CSPAN%3EII%3C%2FSPAN%3E%20)%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EBien%20s%C3%BBr%2C%20%3CSPAN%3Evous%3C%2FSPAN%3E%20pouvez%20%C3%A9galement%20v%C3%A9rifier%20%3CSPAN%3Erapidement%3C%2FSPAN%3E%20les%20trois%20param%C3%A8tres%20%22%20%3CSPAN%3Ejour%3C%2FSPAN%3E%20%22%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20La%20relation%20entre%20%22%20%3CSPAN%3Elot%3C%2FSPAN%3E%20%22%20%3CSPAN%3Eet%3C%2FSPAN%3E%20%22%20%3CSPAN%3Efournisseur%3C%2FSPAN%3E%20%22%20%3CSPAN%3Een%20tant%20que%20facteurs%20potentiels%20de%20variabilit%C3%A9%20et%20de%20changement%20dans%20les%20deux%20compos%C3%A9s%20est%20illustr%C3%A9e%20dans%20la%20figure%3C%2FSPAN%3E%20(%20%3CSPAN%3E3%3C%2FSPAN%3E%20)%20%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPar%20exemple%2C%20des%20lots%20provenant%20de%20deux%20fournisseurs%20sont%20utilis%C3%A9s%20chaque%20jour%2C%20mais%20m%C3%AAme%20pour%20des%20lots%20du%20m%C3%AAme%20jour%2C%20les%20r%C3%A9sultats%20pour%20le%20Compos%C3%A9%201%20%3CSPAN%3Eet%20le%20Compos%C3%A9%3C%2FSPAN%3E%202%20%3CSPAN%3Esont%20tr%C3%A8s%20diff%C3%A9rents%3C%2FSPAN%3E%20.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20545px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20545px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64101i369AAC6D9F774B64%2Fimage-dimensions%2F545x199%3Fv%3Dv2%22%20width%3D%22545%22%20height%3D%22199%22%20role%3D%22button%22%20title%3D%223.png%22%20alt%3D%223.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPhoto%20(%20%3CSPAN%3E3%3C%2FSPAN%3E%20)%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId--1028627982%22%20id%3D%22toc-hId--1028541486%22%3E%3CFONT%20color%3D%22%23333399%22%3E%3CSTRONG%3ELa%20deuxi%C3%A8me%20%C3%A9tape%20de%20l'analyse%26nbsp%3B%3A%20v%C3%A9rifier%20s'il%20existe%20une%20variation%20dans%20les%20donn%C3%A9es%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FH4%3E%0A%3CP%3EApr%C3%A8s%20avoir%20termin%C3%A9%20le%20test%20de%20normalit%C3%A9%20et%20l'analyse%20de%20l'histogramme%2C%20vous%20pouvez%20utiliser%20la%20plateforme%20%3CSTRONG%3EJMP%3C%2FSTRONG%3E%20Control%20Chart%20Builder%20(%20%3CSTRONG%3EControl%20Chart%20Builder)%20%3CSPAN%3Epour%20explorer%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%3CSTRONG%3Eles%20probl%C3%A8mes%3C%2FSTRONG%3E%20de%20qualit%C3%A9.%20%C3%89tant%20donn%C3%A9%20que%20des%20variations%20existent%20dans%20tout%20syst%C3%A8me%20et%20processus%2C%20%3CSTRONG%3Eles%20cartes%20de%20contr%C3%B4le%20peuvent%3C%2FSTRONG%3E%20%3CSTRONG%3Ecalculer%3C%2FSTRONG%3E%20%3CSTRONG%3Eautomatiquement%3C%2FSTRONG%3E%20les%20limites%20de%20contr%C3%B4le%2C%20ce%20qui%20permet%20de%20distinguer%20efficacement%20les%20variations%20caus%C3%A9es%20par%20des%20causes%20g%C3%A9n%C3%A9rales%20et%20les%20causes%20sp%C3%A9ciales%20dans%20les%20variations%20de%20processus%2C%20identifiant%20et%20%C3%A9liminant%20ainsi%20les%20fluctuations%20de%20donn%C3%A9es%20caus%C3%A9es%20par%20des%20causes%20sp%C3%A9ciales.%3C%2FP%3E%0A%3CP%3EUn%20autre%20outil%20qualit%C3%A9%20couramment%20utilis%C3%A9%20-%20%3CSTRONG%3E%3CSPAN%3El'analyse%20de%20la%20capacit%C3%A9%20des%20processus%3C%2FSPAN%3E%20(Process%20Capability)%20%3CSPAN%3E%2C%20peut%20mesurer%20efficacement%3C%2FSPAN%3E%3C%2FSTRONG%3E%20les%20performances%20%3CSTRONG%3Ed'un%3C%2FSTRONG%3E%20%3CSTRONG%3Eprocessus%20par%20rapport%20aux%20limites%20de%20sp%C3%A9cification%20donn%C3%A9es%20et%20aide%20%C3%A0%20identifier%20les%20processus%20sous-performants%3C%2FSTRONG%3E%20.%20Les%20limites%20de%20sp%C3%A9cification%20utilis%C3%A9es%20dans%20les%20calculs%20sont%20d%C3%A9finies%20par%20des%20syst%C3%A8mes%20externes%20ou%20en%20fonction%20des%20exigences%20du%20processus.%20Dans%20cet%20exemple%2C%20%3CSPAN%3Eles%20limites%20de%20sp%C3%A9cification%20inf%C3%A9rieure%20et%20sup%C3%A9rieure%20du%20compos%C3%A9%201%20sont%3C%2FSPAN%3E%20respectivement%20de%20100%20mg%2Fl%20%3CSPAN%3Eet%3C%2FSPAN%3E%20500%20mg%2Fl%2C%20et%20%3CSPAN%3Eles%20limites%20de%20sp%C3%A9cification%20inf%C3%A9rieure%20et%20sup%C3%A9rieure%20du%3C%2FSPAN%3E%20%3CSPAN%3Ecompos%C3%A9%3C%2FSPAN%3E%202%20sont%20de%20300%20mg%2Fl%20%3CSPAN%3Eet%3C%2FSPAN%3E%20600%20mg%2Fl%20%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EUn%3C%2FSTRONG%3E%20%3CSTRONG%3Ebon%20processus%20est%3C%2FSTRONG%3E%20%3CSTRONG%3Ecelui%3C%2FSTRONG%3E%20%3CSTRONG%3Equi%20est%20stable%20et%3C%2FSTRONG%3E%20%3CSTRONG%3Eproduit%3C%2FSTRONG%3E%20syst%C3%A9matiquement%20%3CSTRONG%3Eun%20produit%20qui%20se%20situe%20bien%20dans%20les%20limites%20des%20sp%C3%A9cifications.%3C%2FSTRONG%3E%20Les%20deux%20outils%20ci-dessus%2C%20Control%20Chart%20Builder%20%26amp%3B%20Process%20Capability%2C%20%3CSPAN%3Esont%20souvent%20utilis%C3%A9s%20en%20combinaison%3C%2FSPAN%3E%20pour%20%C3%A9valuer%20la%20stabilit%C3%A9%20du%20processus%20et%20sa%20capacit%C3%A9%20%C3%A0%20r%C3%A9pondre%20aux%20sp%C3%A9cifications%20des%20clients.%3C%2FP%3E%0A%3CP%3EGr%C3%A2ce%20%C3%A0%20la%20plateforme%20de%20g%C3%A9n%C3%A9ration%20de%20%3CSPAN%3Ecartes%20de%20contr%C3%B4le%20de%3C%2FSPAN%3E%20JMP%2C%20vous%20pouvez%20obtenir%20rapidement%20les%20r%C3%A9sultats%20de%20sortie%20de%20la%20figure%20(%20%3CSPAN%3E4%3C%2FSPAN%3E%20)%20ci-dessous.%20Le%20c%C3%B4t%C3%A9%20gauche%20est%20la%20carte%20de%20contr%C3%B4le%20XBar%26amp%3BR%20%3CSPAN%3Edu%3C%2FSPAN%3E%20%3CSPAN%3Ecompos%C3%A9%3C%2FSPAN%3E%201%20%3CSPAN%3Eet%20du%20compos%C3%A9%3C%2FSPAN%3E%202%20respectivement%20%3CSPAN%3E%2C%20et%20le%20c%C3%B4t%C3%A9%20droit%20est%20le%20r%C3%A9sultat%20de%20l'analyse%20de%20la%20capacit%C3%A9%20du%20processus.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20717px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20717px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64102iC558E09429B8E299%2Fimage-dimensions%2F717x712%3Fv%3Dv2%22%20width%3D%22717%22%20height%3D%22712%22%20role%3D%22button%22%20title%3D%224.png%22%20alt%3D%224.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigure%20(%20%3CSPAN%3E4%3C%2FSPAN%3E%20)%20R%C3%A9sultats%20du%20g%C3%A9n%C3%A9rateur%20%3CSPAN%3Ede%20cartes%20de%20contr%C3%B4le%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId-714182353%22%20id%3D%22toc-hId-714268849%22%3E%3CFONT%20color%3D%22%23333399%22%3E%3CSTRONG%3ELa%20troisi%C3%A8me%20%C3%A9tape%20de%20l'analyse%26nbsp%3B%3A%20l'interpr%C3%A9tation%20des%20donn%C3%A9es%20des%20r%C3%A9sultats%20de%20l'analyse%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FH4%3E%0A%3COL%3E%0A%3CLI%3ELa%20%3CSPAN%3Ecarte%20XBar%20est%20une%20carte%20de%20contr%C3%B4le%20moyenne%20avec%20des%20lots%20comme%3C%2FSPAN%3E%20sous-groupes.%20L'observation%20montre%20que%20%3CSPAN%3Etous%20les%20points%20du%20compos%C3%A9%201%20se%20situent%20al%C3%A9atoirement%20dans%20la%20plage%20de%20contr%C3%B4le%20(zones%20vertes%3C%2FSPAN%3E%20et%20jaunes).%20En%20introduisant%20la%20r%C3%A8gle%20discriminante%2C%20aucun%20point%20n'est%20encercl%C3%A9%20ou%20marqu%C3%A9%2C%20ce%20qui%20signifie%20que%20le%20processus%20est%20%C2%AB%20%3CSPAN%3Esous%20contr%C3%B4le%3C%2FSPAN%3E%20%C2%BB%20%3CSPAN%3Eou%20stable.%3C%2FSPAN%3E%20%3CSPAN%3EApr%C3%A8s%20avoir%20introduit%20la%20r%C3%A8gle%20de%20jugement%20pour%20le%20compos%C3%A9%202%2C%20il%20a%20%C3%A9t%C3%A9%20constat%C3%A9%20que%20le%20lot%20num%C3%A9ro%3C%2FSPAN%3E%2011%20%3CSPAN%3Etombait%20dans%20la%20zone%20rouge%3C%2FSPAN%3E%20et%20%C3%A9tait%20encercl%C3%A9%20ou%20marqu%C3%A9%2C%20ce%20qui%20indiquait%20que%20le%20processus%20%C3%A9tait%20hors%20de%20contr%C3%B4le%20ou%20instable.%3C%2FLI%3E%0A%3CLI%3ELa%20%3CSPAN%3Ecarte%20R%20est%20une%20carte%20de%20contr%C3%B4le%20de%20plage%20avec%20des%20lots%20comme%3C%2FSPAN%3E%20sous-groupes%20et%20est%20utilis%C3%A9e%20pour%20surveiller%20les%20fluctuations%20du%20processus.%20Chaque%20point%20du%20graphique%20repr%C3%A9sente%20la%20diff%C3%A9rence%20entre%20les%20valeurs%20maximales%20et%20minimales%20de%20la%20plage%20de%20lots.%20En%20introduisant%20la%20r%C3%A8gle%20de%20jugement%2C%20nous%20pouvons%20voir%20que%20le%2010%C3%A8me%20%3CSPAN%3Elot%3C%2FSPAN%3E%20%3CSPAN%3Edu%3C%2FSPAN%3E%20compos%C3%A9%201%20et%20%3CSPAN%3Ele%205%C3%A8me%20lot%20du%3C%2FSPAN%3E%20compos%C3%A9%202%20%3CSPAN%3Ed%C3%A9passent%20les%20limites%20de%20contr%C3%B4le%2C%20ce%20qui%20indique%20qu'il%20existe%3C%2FSPAN%3E%20des%20raisons%20particuli%C3%A8res%20qui%20provoquent%20des%20fluctuations%20du%20processus.%3C%2FLI%3E%0A%3CLI%3ELa%20partie%20de%20droite%20contient%20les%20r%C3%A9sultats%20de%20l'analyse%20de%20la%20capabilit%C3%A9%20des%20processus%2C%20utilis%C3%A9s%20pour%20identifier%20les%20processus%20peu%20performants.%20Plusieurs%20indicateurs%20de%20capacit%C3%A9%20couramment%20utilis%C3%A9s%20pour%20%C3%A9valuer%20comprennent%26nbsp%3B%3A%3COL%3E%3CLI%3E%20Cp%2FPp%20%3CSPAN%3E%3A%20Le%20rapport%20entre%20la%20largeur%20de%20la%20limite%20de%20sp%C3%A9cification%20et%20la%20fluctuation%20du%20processus.%3C%2FSPAN%3E%20Cp%20est%20appel%C3%A9%20capacit%C3%A9%20potentielle%20de%20processus%20interne%20(ou%20%C3%A0%20court%20terme)%20(en%20consid%C3%A9rant%20uniquement%20les%20fluctuations%20au%20sein%20d'un%20sous-groupe)%2C%20et%20Pp%20est%20appel%C3%A9%20capacit%C3%A9%20potentielle%20de%20processus%20globale%20(ou%20%C3%A0%20long%20terme)%20(en%20consid%C3%A9rant%20les%20fluctuations%20dans%20tous%20les%20groupes%20dans%20leur%20ensemble).%20Ils%20constituent%20un%20indicateur%20courant%20de%20la%20capacit%C3%A9%20qui%20peut%20%C3%AAtre%20atteinte%20si%20la%20moyenne%20du%20processus%20et%20la%20moyenne%20cible%20sont%20coh%C3%A9rentes%26nbsp%3B%3B%3C%2FLI%3E%3CLI%3E%20Cpl%2FPpl%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20utilis%C3%A9%20pour%20v%C3%A9rifier%20la%20capacit%C3%A9%20d'un%20proc%C3%A9d%C3%A9%20%C3%A0%20respecter%20la%20limite%20inf%C3%A9rieure%20d'un%20cahier%20des%20charges%20%3B%3C%2FLI%3E%3CLI%3E%20Cpu%2FPpu%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20utilis%C3%A9%20pour%20v%C3%A9rifier%20la%20capacit%C3%A9%20d'un%20processus%20%C3%A0%20respecter%20la%20limite%20sup%C3%A9rieure%20de%20sp%C3%A9cification%20%3B%3C%2FLI%3E%3CLI%3E%20Cpk%2FPpk%20%3CSPAN%3E%3A%20Prendre%3C%2FSPAN%3E%20la%20%3CSPAN%3Evaleur%20minimale%20de%3C%2FSPAN%3E%20Cpl%2FPpl%20%3CSPAN%3Eet%3C%2FSPAN%3E%20Cpu%2FPpu.%3C%2FLI%3E%3CLI%3E%20Cpk%2FPpk%20%3CSPAN%3Eest%20%C3%A9gal%20%C3%A0%3C%2FSPAN%3E%201%2C0%20%3CSPAN%3E%2C%20ce%20qui%20est%20consid%C3%A9r%C3%A9%20comme%3C%2FSPAN%3E%20un%20processus%20%C3%A0%20peine%20qualifi%C3%A9.%20Bien%20entendu%2C%20certaines%20normes%20industrielles%20exigent%20que%20la%20valeur%20minimale%20%3CSPAN%3Ede%3C%2FSPAN%3E%20Cpk%2FPpk%20soit%20de%201%2C33%20%3CSPAN%3Eou%20m%C3%AAme%3C%2FSPAN%3E%20plus.%3C%2FLI%3E%3C%2FOL%3E%3C%2FLI%3E%0A%3CLI%3ELes%20%3CSPAN%3Evaleurs%20Cpk%20et%3C%2FSPAN%3E%20Ppk%20actuelles%20%3CSPAN%3Edu%3C%2FSPAN%3E%20compos%C3%A9%20de%20mati%C3%A8re%20premi%C3%A8re%201%20%3CSPAN%3Esont%3C%2FSPAN%3E%20respectivement%20de%200%2C740%20%3CSPAN%3Eet%3C%2FSPAN%3E%200%2C752%20%3CSPAN%3E%2C%20le%20processus%20est%20donc%20consid%C3%A9r%C3%A9%20comme%20non%20qualifi%C3%A9.%20Le%20compos%C3%A9%3C%2FSPAN%3E%202%20%3CSPAN%3En'est%20pas%20non%20plus%20tr%C3%A8s%20bon%2C%3C%2FSPAN%3E%20avec%20des%20valeurs%20Cpk%20%3CSPAN%3Eet%3C%2FSPAN%3E%20Ppk%20%3CSPAN%3Erespectivement%3C%2FSPAN%3E%20de%201%2C005%20%3CSPAN%3Eet%3C%2FSPAN%3E%200%2C746%20%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId--1837974608%22%20id%3D%22toc-hId--1837888112%22%3E%3CFONT%20color%3D%22%23333399%22%3E%3CSTRONG%3ELa%20quatri%C3%A8me%20%C3%A9tape%20de%20l%E2%80%99analyse%26nbsp%3B%3A%20explorer%20les%20sources%20de%20variation%20du%20point%20de%20vue%20du%20fournisseur%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FH4%3E%0A%3CP%3EFaites%20glisser%20le%20fournisseur%20vers%20le%20haut%20de%20la%20carte%20de%20contr%C3%B4le%20(zone%20d'%C3%A9tape)%20pour%20diviser%20la%20carte%20de%20contr%C3%B4le%20par%20fournisseur%2C%20comme%20%3CSPAN%3Ele%20montre%3C%2FSPAN%3E%20la%20figure%20(%20%3CSPAN%3E5%3C%2FSPAN%3E%20)%20ci-dessous.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%225.png%22%20style%3D%22width%3A%20710px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225.png%22%20style%3D%22width%3A%20710px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64103i07B82864577DF54D%2Fimage-dimensions%2F710x283%3Fv%3Dv2%22%20width%3D%22710%22%20height%3D%22283%22%20role%3D%22button%22%20title%3D%225.png%22%20alt%3D%225.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EChiffre%20(%20%3CSPAN%3E5%3C%2FSPAN%3E%20)%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EComme%20le%20montre%20la%20figure%20(%20%3CSPAN%3E5%3C%2FSPAN%3E%20)%20ci-dessus%20%3CSPAN%3E%2C%20pour%20ces%20deux%20compos%C3%A9s%2C%20sur%20la%20base%20des%20limites%20de%20contr%C3%B4le%20existantes%2C%20bien%20que%20les%20deux%20compos%C3%A9s%20fournis%20par%20le%20fournisseur%3C%2FSPAN%3E%20A%20%3CSPAN%3Esoient%20tr%C3%A8s%20stables%20(le%20lot%20est%20dans%20les%20limites%20de%20contr%C3%B4le)%2C%20on%20peut%20trouver%20%3A%20Fournisseur%20d'approvisionnement%3C%2FSPAN%3E%20A%20%3CSPAN%3Epr%C3%A9sente%3C%2FSPAN%3E%20%3CSPAN%3Eune%20variation%20d'un%20lot%20%C3%A0%20l'autre%20nettement%20plus%20importante%20que%20le%20fournisseur%3C%2FSPAN%3E%20B.%20%3CSPAN%3ELa%20variation%20d'un%20lot%20%C3%A0%20l'autre%20du%20fournisseur%20B%20%C3%A9tait%20relativement%3C%2FSPAN%3E%20faible%2C%20mais%20%3CSPAN%3Ele%20compos%C3%A9%201%20du%3C%2FSPAN%3E%20fournisseur%20B%20%3CSPAN%3Epr%C3%A9sentait%20une%20variation%20sp%C3%A9cifique%20%C3%A0%20une%20cause.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EDe%20plus%2C%20nous%20pouvons%20%C3%A9galement%20essayer%20d'utiliser%20une%20carte%20de%20contr%C3%B4le%20multivari%C3%A9e%20bas%C3%A9e%20sur%20un%20mod%C3%A8le%20(MDMVCC%20%3CSPAN%3E)%20%3CSTRONG%3Eet%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSTRONG%3Eutiliser%3C%2FSTRONG%3E%20%3CSTRONG%3El'analyse%20en%20composantes%20principales%3C%2FSTRONG%3E%20%3CSTRONG%3E(ACP%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%3CSTRONG%3Epour%20surveiller%20les%20param%C3%A8tres%20de%20plusieurs%20processus%20dans%20une%20seule%20carte%20de%20contr%C3%B4le%3C%2FSTRONG%3E%20%3CSTRONG%3E.%3C%2FSTRONG%3E%20Dans%20certains%20sc%C3%A9narios%2C%20si%20vous%20observez%20simplement%20chaque%20processus%20ind%C3%A9pendamment%2C%20ils%20semblent%20tous%20stables.%20%3CSTRONG%3EGr%C3%A2ce%20%C3%A0%20des%20cartes%20de%20contr%C3%B4le%20multivari%C3%A9es%2C%20vous%20pouvez%20d%C3%A9tecter%20l'instabilit%C3%A9%20potentielle%20de%20plusieurs%20processus%20en%20m%C3%AAme%20temps%3C%2FSTRONG%3E%20et%20%C3%A9tudier%20en%20profondeur%20la%20contribution%20de%20chaque%20processus%20au%20processus%20global.%20pour%20diagnostiquer%20si%20le%20processus%20est%20stable.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%226.png%22%20style%3D%22width%3A%20703px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%226.png%22%20style%3D%22width%3A%20703px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64104i9830B7482840DC7E%2Fimage-dimensions%2F703x232%3Fv%3Dv2%22%20width%3D%22703%22%20height%3D%22232%22%20role%3D%22button%22%20title%3D%226.png%22%20alt%3D%226.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EChiffre%20(%20%3CSPAN%3E6%3C%2FSPAN%3E%20)%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3ED'apr%C3%A8s%20la%20figure%20(%20%3CSPAN%3E6%3C%2FSPAN%3E%20)%20ci-dessus%20%3CSPAN%3E%2C%20nous%20pouvons%20voir%20que%20tous%20les%20lots%20du%20fournisseur%3C%2FSPAN%3E%20A%20%3CSPAN%3Esont%20dans%20les%20limites%20de%20contr%C3%B4le%2C%3C%2FSPAN%3E%20tandis%20que%20pour%20le%20fournisseur%20B%20%3CSPAN%3E%2C%20nous%20pouvons%20clairement%20voir%20que%20trois%20lots%20sont%20hors%20des%20points%20de%20contr%C3%B4le%20et%20n%C3%A9cessitent%20une%20attention%20particuli%C3%A8re.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EEn%20outre%2C%20nous%20pouvons%20%C3%A9galement%20utiliser%20la%20%3CSPAN%3Eplateforme%20de%20contr%C3%B4le%20de%20capacit%C3%A9%20de%20processus%3C%2FSPAN%3E%20JMP%20(Process%20Screening)%20%3CSPAN%3Epour%3C%2FSPAN%3E%20combiner%20variation%20et%20capacit%C3%A9%20en%20un%20seul%20r%C3%A9sultat%20%C3%A0%20l'aide%20de%20graphiques%20cibles%20et%20de%20graphiques%20de%20performances%20de%20processus%2C%20%3CSTRONG%3Eet%20v%C3%A9rifier%20simultan%C3%A9ment%20si%20les%20compos%C3%A9s%20de%20deux%20fournisseurs%20sont%20stables%20et%20s'ils%20sont%20conformes%20aux%20sp%C3%A9cifications%20donn%C3%A9es.%3C%2FSTRONG%3E%20.%20Cette%20plateforme%20est%20particuli%C3%A8rement%20adapt%C3%A9e%20aux%20sc%C3%A9narios%20d%E2%80%99inspection%20qualit%C3%A9%20qui%20n%C3%A9cessitent%20la%20surveillance%20de%20processus%20de%20fabrication%20%C3%A0%20grand%20volume%20et%20est%20fortement%20recommand%C3%A9e.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64105i2A045FCAB0FEC6B3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%227.png%22%20alt%3D%227.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EChiffre%20(%20%3CSPAN%3E7%3C%2FSPAN%3E%20)%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3ELe%20tableau%20de%20capacit%C3%A9%20du%20processus%20de%20la%20figure%20(%20%3CSPAN%3E7%3C%2FSPAN%3E%20)%20ci-dessus%20%3CSPAN%3Emet%20en%20%C3%A9vidence%20deux%20aspects%20permettant%20de%20d%C3%A9terminer%20si%20le%20processus%20est%20sain%3C%2FSPAN%3E%20%2C%20%C3%A0%20savoir%20l'indice%20de%20stabilit%C3%A9%20et%20la%20capacit%C3%A9%20du%20processus%20(Ppk%20%3CSPAN%3E).%3C%2FSPAN%3E%20Un%20processus%20stable%20aura%20%3CSPAN%3Eun%20indice%20de%20stabilit%C3%A9%20proche%20de%201.%3C%2FSPAN%3E%20Plus%20%3CSPAN%3Ela%20valeur%20de%20l'indice%20de%20stabilit%C3%A9%3C%2FSPAN%3E%20est%20%C3%A9lev%C3%A9e%2C%20plus%20le%20processus%20est%20instable.%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ECapacit%C3%A9%20du%20processus%3C%2FSTRONG%3E%20%3CSTRONG%3EPpk%20%3CSPAN%3Eest%20un%20param%C3%A8tre%20important%20pour%20mesurer%20les%20performances%20du%20processus.%20Plus%20la%20valeur%20est%20%C3%A9lev%C3%A9e%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%3CSTRONG%3E%2C%3C%2FSTRONG%3E%20%3CSTRONG%3Eplus%20le%20taux%20de%20d%C3%A9fauts%20par%20million%20de%20produits%20est%20faible%3C%2FSTRONG%3E%20.%20Le%20processus%20id%C3%A9al%20(capable%20et%20stable)%20est%20indiqu%C3%A9%20dans%20la%20zone%20ombr%C3%A9e%20verte%20de%20la%20figure%2C%20o%C3%B9%20Ppk%26gt%3B1%2C0%20%3CSPAN%3Eet%20indice%20de%20stabilit%C3%A9%3C%2FSPAN%3E%20%26lt%3B1%2C25%20%3CSPAN%3E.%3C%2FSPAN%3E%20Les%20processus%20incomp%C3%A9tents%20et%20instables%20se%20trouvent%20dans%20la%20zone%20ombr%C3%A9e%20en%20rouge%2C%20o%C3%B9%20Ppk%26lt%3B1%2C0%20%3CSPAN%3Eet%20indice%20de%20stabilit%C3%A9%3C%2FSPAN%3E%20%26gt%3B1%2C25%20%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ELes%20trac%C3%A9s%20d'objectif%20affichent%20le%20d%C3%A9calage%20moyen%20normalis%C3%A9%20par%20les%20sp%C3%A9cifications%20sur%20l'%20%3CSPAN%3Eaxe%3C%2FSPAN%3E%20des%20x%20et%20l'%C3%A9cart%20type%20normalis%C3%A9%20par%20les%20sp%C3%A9cifications%20sur%20l'%20%3CSPAN%3Eaxe%3C%2FSPAN%3E%20des%20y%20pour%20chaque%20processus%20et%20sont%20utilis%C3%A9s%20pour%20fournir%20rapidement%20une%20vue%20r%C3%A9capitulative%20indiquant%20si%20un%20processus%20se%20situe%20dans%20les%20limites%20des%20sp%C3%A9cifications.%3C%2FP%3E%0A%3CP%3ELes%20processus%20stables%20et%20capables%20sont%20repr%C3%A9sent%C3%A9s%20dans%20les%20%3CSPAN%3Ezones%20ombr%C3%A9es%3C%2FSPAN%3E%20vertes%20(pk%26gt%3B2%2C0%20%3CSPAN%3E)%20et%20jaunes%3C%2FSPAN%3E%20(pk%26gt%3B1%2C0%20)%20de%20la%20figure%2C%20et%20les%20processus%20incomp%C3%A9tents%20et%20instables%20sont%20repr%C3%A9sent%C3%A9s%20dans%20la%20zone%20ombr%C3%A9e%20rouge%20(Ppk%26lt%3B1%2C0%20%3CSPAN%3E).%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPour%20le%20fournisseur%20A%20%3CSPAN%3E%2C%20les%20deux%20processus%20pour%20le%20compos%C3%A9%3C%2FSPAN%3E%201%20%3CSPAN%3Eet%20le%20compos%C3%A9%3C%2FSPAN%3E%202%20%3CSPAN%3Esont%20stables%20mais%20ont%20des%20capacit%C3%A9s%20insuffisantes%3C%2FSPAN%3E%20.%20Pour%20le%20fournisseur%20B%20%3CSPAN%3E%2C%20le%20compos%C3%A9%3C%2FSPAN%3E%202%20%3CSPAN%3Eest%20stable%20mais%20insuffisamment%20performant%3C%2FSPAN%3E%20%2C%20tandis%20que%20le%20compos%C3%A9%201%20%3CSPAN%3Eest%20%C3%A0%20la%20fois%3C%2FSPAN%3E%20insuffisamment%20performant%20et%20instable.%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId-297862737%22%20id%3D%22toc-hId-297949233%22%3E%3CSTRONG%3EConclusions%20progressives%20et%20plans%20d'am%C3%A9lioration%20de%20la%20qualit%C3%A9%3C%2FSTRONG%3E%3C%2FH2%3E%0A%3CP%3ENous%20avons%20successivement%20utilis%C3%A9%20des%20moyens%2C%20des%20cartes%20de%20contr%C3%B4le%20de%20gamme%20et%20des%20cartes%20de%20contr%C3%B4le%20multivari%C3%A9es%20pour%20surveiller%20la%20qualit%C3%A9%20des%20mati%C3%A8res%20premi%C3%A8res%20et%20les%20param%C3%A8tres%20cl%C3%A9s%20du%20processus%20des%20fournisseurs%2C%20et%20exigeons%20que%20les%20fournisseurs%20utilisent%20%C3%A9galement%20ces%20cartes%20de%20contr%C3%B4le%20pour%20r%C3%A9duire%20la%20variabilit%C3%A9%20des%20processus.%3C%2FP%3E%0A%3CP%3EEn%20th%C3%A9orie%2C%20si%20les%20mati%C3%A8res%20premi%C3%A8res%20fournies%20sont%20instables%2C%20tous%20les%20lots%20d'approvisionnement%20devraient%20%C3%AAtre%20surveill%C3%A9s%20et%20la%20fr%C3%A9quence%20d'%C3%A9chantillonnage%20et%20d'analyse%20des%20mati%C3%A8res%20premi%C3%A8res%20augment%C3%A9e%2C%20mais%20cela%20n'est%20actuellement%20pas%20possible%20car%20la%20m%C3%A9thode%20d'analyse%20par%20chromatographie%20en%20phase%20gazeuse%20(GC%20%3CSPAN%3E)%20existante%20prend%20beaucoup%20de%20temps.%20%2C%20une%20inspection%20compl%C3%A8te%20ne%20pourra%20pas%20r%C3%A9pondre%3C%2FSPAN%3E%20aux%20besoins%20de%20production.%20Par%20cons%C3%A9quent%2C%20la%20m%C3%A9thode%20d%E2%80%99analyse%20rapide%20en%20cours%20de%20d%C3%A9veloppement%2C%20la%20chromatographie%20liquide%20%C3%A0%20ultra%20haute%20performance%20(UHPLC%20%3CSPAN%3E)%2C%20sera%20au%20centre%20de%20la%20prochaine%3C%2FSPAN%3E%20%C3%A9tape.%20Comment%20acc%C3%A9l%C3%A9rer%20le%20contr%C3%B4le%20de%20la%20qualit%C3%A9%20des%20mati%C3%A8res%20premi%C3%A8res%20gr%C3%A2ce%20%C3%A0%20un%20syst%C3%A8me%20de%20mesure%20par%20chromatographie%20liquide%20ultra-haute%20performance%26nbsp%3B%3F%20Nous%20continuerons%20%C3%A0%20explorer%20cela%20dans%20les%20articles%20suivants.%3C%2FP%3E%0A%3CP%3ESi%20vous%20%C3%AAtes%20int%C3%A9ress%C3%A9%20par%20les%20m%C3%A9thodes%20%3CSPAN%3Estatistiques%3C%2FSPAN%3E%20de%20contr%C3%B4le%20statistique%20des%20processus%20(SPC)%20pr%C3%A9sent%C3%A9es%20dans%20cet%20article%2C%20vous%20pouvez%20t%C3%A9l%C3%A9charger%20%3CA%20href%3D%22https%3A%2F%2Fwww.jmp.com%2Fzh_tw%2Fdownload-jmp-free-trial.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3E%3CSPAN%3Ela%20derni%C3%A8re%20version%3C%2FSPAN%3E%20de%20JMP%3C%2FA%3E%20et%20en%20faire%20l'exp%C3%A9rience%20%3CSPAN%3Epar%3C%2FSPAN%3E%20vous-m%C3%AAme.%20Apprenez-en%20davantage%20sur%20les%20connaissances%20et%20les%20techniques%20d%E2%80%99analyse%20des%20donn%C3%A9es.%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3ELecture%20recommand%C3%A9e%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Blog%2F%25E6%2587%2589%25E7%2594%25A8%25E6%25A1%2588%25E4%25BE%258B-%25E5%259F%25BA%25E6%2596%25BCJMP%25E8%25B3%2587%25E6%2596%2599%25E6%258E%25A2%25E5%258B%2598%25E6%2589%25BE%25E5%2587%25BA%25E5%25B9%25BD%25E9%2596%2580%25E8%259E%25BA%25E6%2597%258B%25E6%25A1%25BF%25E8%258F%258C%25E6%2584%259F%25E6%259F%2593%25E6%2582%25A3%25E8%2580%2585%25E7%259A%2584%25E5%25BD%25B1%25E9%259F%25BF%25E5%259B%25A0%25E5%25AD%2590%2Fba-p%2F625330%3FtrMode%3Dsource%22%20target%3D%22_blank%22%3E%3CSPAN%3ECas%20d'application%26nbsp%3B%3A%3C%2FSPAN%3E%20%3CSPAN%3ERecherche%20de%20facteurs%20d'influence%20chez%20les%20patients%20atteints%20d'une%20infection%20%C3%A0%20Helicobacter%20pylori%20sur%20la%20base%20de%20l'exploration%20des%20donn%C3%A9es%20JMP%3C%2FSPAN%3E%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20style%3D%22font-family%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%22%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Blog%2F%25E8%25A3%25BD%25E7%25A8%258B%25E8%2583%25BD%25E5%258A%259B%25E5%2588%2586%25E6%259E%2590-%25E5%25BF%25AB%25E9%2580%259F%25E7%258D%25B2%25E5%25BE%2597%25E8%25A3%25BD%25E7%25A8%258B%25E5%25A0%25B1%25E5%2591%258A%25E5%2585%25A9%25E5%25A4%25A7-JMP-%25E5%258A%259F%25E8%2583%25BD%2Fba-p%2F609427%22%20target%3D%22_blank%22%3E%3CSPAN%3EAnalyse%20de%20la%20capabilit%C3%A9%20des%20processus%26nbsp%3B%3A%20obtenez%20rapidement%20deux%20fonctions%20JMP%20majeures%20pour%20les%20rapports%20de%20processus%3C%2FSPAN%3E%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20style%3D%22font-family%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%22%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Blog%2F%25E6%25A9%259F%25E5%2599%25A8%25E5%25AD%25B8%25E7%25BF%2592-%25E7%25B5%25B1%25E8%25A8%2588%25E5%2588%2586%25E6%259E%2590-%25E4%25B8%25BB%25E6%2588%2590%25E5%2588%2586%25E5%2588%2586%25E6%259E%2590%25E8%2588%2587JMP%25E5%25AF%25A6%25E4%25BD%259C%2Fba-p%2F609432%3FtrMode%3Dsource%22%20target%3D%22_blank%22%3E%3CSPAN%3EMachine%20learning%3C%2FSPAN%3E%20%2Fanalyse%20statistique%26nbsp%3B%3A%20analyse%20en%20composantes%20principales%20et%20mise%20en%20%C5%93uvre%20de%20JMP%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-753571%22%20slang%3D%22zh-TW%22%20mode%3D%22CREATE%22%3E%3CP%3EAtteindre%20l%E2%80%99excellence%20en%20mati%C3%A8re%20de%20fabrication%20est%20l%E2%80%99objectif%20poursuivi%20par%20chaque%20entreprise.%20Pour%20atteindre%20cet%20objectif%2C%20le%20service%20qualit%C3%A9%20doit%20travailler%20en%20permanence%20pour%20identifier%20les%20sources%20de%20variation%20des%20processus%20et%20prendre%20les%20mesures%20appropri%C3%A9es%20pour%20contr%C3%B4ler%20les%20objectifs.%3C%2FP%3E%0A%3CP%3EComprendre%20le%20processus%20de%20fabrication%20gr%C3%A2ce%20%C3%A0%20l'analyse%20des%20donn%C3%A9es%20peut%20non%20seulement%20augmenter%20la%20flexibilit%C3%A9%20de%20la%20production%2C%20mais%20%C3%A9galement%20garantir%20que%20les%20produits%20r%C3%A9pondent%20mieux%20aux%20exigences%20des%20clients.%20Comment%20atteindre%20l'excellence%20en%20mati%C3%A8re%20de%20fabrication%20sur%20la%20base%20de%20l'analyse%20des%20donn%C3%A9es%20scientifiques%20est%20un%20probl%C3%A8me%20auquel%20chaque%20entreprise%20est%20confront%C3%A9e.%20Cet%20article%20explique%20comment%20%3CSPAN%3Er%C3%A9duire%20la%20variation%20des%20processus%20dans%20la%20gestion%20de%20la%20qualit%C3%A9%20gr%C3%A2ce%20au%20SPC%20du%20point%20de%20vue%20des%20statistiques%20d'ing%C3%A9nierie%20appliqu%C3%A9e.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64097iC3CA6CE71C28A30F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%227.png%22%20alt%3D%227.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-753571%22%20slang%3D%22zh-TW%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EIng%C3%A9nierie%20Qualit%C3%A9%20et%20Proc%C3%A9d%C3%A9s%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
JMP_Taiwan
Level VI
什麼是SPC(統計製程控制)?減少製程變異的分析流程解說與數據解讀
實現卓越製造是每個企業追求的⽬標。為了達到這個⽬標,品質部門必須不斷努⼒識別製程變化的來源,並採取適當的措施來控制⽬標。時至科學化的現代,品質單位已經可以透過數據分析的方式,來理解製程的⽣產過程,不僅可以增加⽣產的靈活性,⽽且能確保產品更好地符合客戶要求。
實現智慧製造的三大關鍵
如何基於科學的數據分析實現卓越製造,更是每家企業在要求提升產品品質時,所面臨到的問題。透過過去JMP合作的產業案例可以看出,企業實現卓越製造需要經歷三個關鍵過程
  1. 1.透過控制圖及製程能力分析,實現統計製程管制 (SPC),減少製程變異;
  2. 透過測量系統分析 (MSA),尋找測量過程中的變異源;
  3. 透過實驗設計(DOE) 及預測建模,確定對測量變異有影響的因⼦,找到因⼦的最佳設置,使測量過程更加穩健。
我們以⼀個醫藥⽣產製造商的案例看看如何實施這「數據分析三部曲」。⾸先,我們先來看看如何進行統計製程管制(SPC)
實戰案例分析
製程背景
FVM製藥公司是⼀家國際藥品製造商,專門⽣產⾼品質的成品配⽅藥,產品類型包括片劑、膠囊和液體。在製藥過程裡,有個典型的製造過程包括:將活性藥物成分(API)研磨成均勻顆粒⼤⼩的粉末,接著將磨碎的材料與其他組分混合,使原料藥體積變⼤並均勻分佈,然後將這種混合材料壓製成片劑,最後進⾏包衣,以提⾼有效期限、⼝感和其他性能。在這個過程結束時,各種品質參數指標都會被記錄,以便批量驗收。
上述過程的原材料是含有兩種有機化合物的濃縮乳劑,由兩個供應商(AB)同時提供,製藥公司透過氣相⾊譜法(GC)測量化合物的濃度(mg/L)來監測品質。
現況問題
最近品質管理團隊發現藥品品質存在很⼤的差異,透過問題排查,懷疑問題有很⼤可能來⾃原料藥。為此,公司專門成立品質改進⼩組,希望藉助統計具,結合品質源於設計法(QbD),透過數據化決策,從根本上找到個可持續的解決確定製程變化的關鍵驅動因素,最終達到優化製程設置的目的。
改善過程
首先,品質改進⼩組進⾏產品的統計製程管制 (SPC)透過控制圖瞭解製程的穩定性並分析過程變化的模式。透過製程能力分析,評定其是否滿⾜顧客/外部交期。兩個⼯具都⽀持更好地理解過程,並指導制定改進策略。團隊對來⾃兩家供應商的兩種化合物原材料,進⾏了為期8天的樣品採集並導入JMP軟件,涉及所有批次,下圖(一)為部分數據截圖。
圖 ()
分析的先決條件:檢視數據是否呈現常態
許多品質統計⼯具使⽤的前提假設是數據來⾃於常態分佈,否則基於平均值和標準差的報告結果就沒有意義。利⽤ JMP選單,點選「分析 (Analyze)à 分佈平臺 (Distribution)」,結合SW檢驗和AD檢驗結果,可以確認兩個化合物數據呈現常態分佈,表示沒有問題,結果如下圖(二)所⽰。
圖()
當然,也可以透過分析 (Analyze) à 分佈平台 (Distribution) 的互動功能(點選某個參數的某個⽔平,其他參數對應部分也會被選中),快速查看三個參數“批次供應商作為可變性潛在驅動因素與兩種化合物的變化關係,如圖()
例如每天都會使⽤來⾃兩個供應商的批次,但即使同⼀天的批次,化合物1和化合物2的結果也差異巨⼤。
圖()
分析第二步驟:檢視數據是否產生變異
完成常態檢定和直⽅圖分析後,就可以使⽤ JMP 控制圖⽣成器平臺(Control Chart Builder)探索品質⽅⾯的問題了。由於變異存在於任何系統和過程當中,控制圖能動計算的控制限,便能有效區分過程變異中⼀般原因和特殊原因產⽣的變異,從⽽識別和消除特殊原因造成的數據波動。
另⼀個常⽤的品質工具 — 製程能力分析 (Process Capability),可以有效衡量個製程與給定的規格限相比表現如何,有助於識別表現不佳的過程。計算時⽤到的規格限,是由外部系統或按過程要求設定的。本例中化合物1的規格下限和上限分別是100mg/l500mg/l,化合物2的規格下限和上限是300mg/l600mg/l
個好的過程是個穩定的過程,並且持續地產出遠在規格限之內的產品。上述兩個⼯具Control Chart Builder & Process Capability便是經常結合使⽤,⽤於評估製程的穩定性以及評估其滿⾜客戶規格要求的能⼒。
透過JMP的控制圖⽣成器平台可以快速得到下圖()的輸出結果,左側分別為化合物1和化合物2XBar&R控制圖,右側為製程能力分析結果。
圖()控制圖⽣成器結果
分析第三步驟:分析結果的數據解讀
  1. XBar圖是以批次為⼦組的均值控制圖。觀察可以發現,化合物1的所有的點都隨機落在控制範圍內(綠⾊和黃⾊區域)。引入判異規則,沒有任何點被圈起來或被標記,這意味著過程是"在控制中"或穩定的。⽽化合物2在引入判異規則後,發現批號11落入紅⾊區域,並被圈起來或打上標記,這表明該過程不受控制或不穩定。
  2. R圖是批次為⼦組的極差控制圖,⽤於監測過程中的波動⼤⼩。圖表上的每個點都代表批次範圍的最⼤值和最⼩值的差值。引入判異規則,可以看到化合物1的第10批產品和化合物2的第5批超出了控制限,說明有⼀些特殊原因造成過程波動變化。
  3. 右側部分則是製程能力分析結果,⽤來識別表現不佳的過程。常⽤來評估的幾個能⼒指標包括:
    1. Cp/Pp:規格限的寬度與過程波動之比。Cp⼜叫內部(或短期)潛在製程能力( 只考慮⼦組內的波動),Pp⼜叫整體(或⻓期)潛在製程能力(考慮所有組整體的波動)。它們是衡量如果過程均值和⽬標均值⼀致,能⼒能夠達到多少的常⽤指標;
    2. Cpl/Ppl⽤于檢查⼀個過程滿⾜規格下限的能⼒;
    3. Cpu/Ppu⽤于檢查⼀個過程滿⾜規格上限的能⼒;
    4. Cpk/Ppk:取Cpl/PplCpu/Ppu的最⼩值。
    5. Cpk/Ppk等於1.0,被認為⼀個勉強合格的過程,當然也有些⾏業準則要求Cpk/Ppk的最⼩值為1.33或甚⾄更⾼。
  4. 當前原料化合物1Cpk值和Ppk值分別為0.7400.752,所以認為該製程不太合格。化合物2也不是很好,Cpk值和Ppk值分別為1.0050.746
分析第四步驟:從供應商角度探索變異來源
把供應商拖到控制圖的頂部(階段區),可按供應商分割控制圖,如下圖 () ⽰。
圖()
從上圖()可以看出,對於這兩種化合物,基於現有控制限,雖然供應商A提供的這兩種化合物都很穩定(批次在控制限度內),但是我們可以發現:供應商A明顯比供應商B有更⼤的批次間變化。供應商B批次間的變化相對比較⼩,但發現供應商B的化合物1表現出特殊原因的變異。
此外,我們也可嘗試使⽤模型驅動的多元控制圖(MDMVCC),主成分分析(PCA)個控制圖中監測多個製程的參數。在某些場景下,如果只是獨立觀察各個製程,似乎都是穩定的,透過多元控制圖可以同時檢測多個過程的潛在不穩定性,深入調查個別過程對整體性的貢獻,以診斷製程是否穩定。
圖()
由上圖()可知供應商A的所有批次都在控制限內,⽽對於供應商B,可以清楚地看到三個批次是失控點,需要關注。
此外,我們還可以透過JMP製程能力篩選平台(Process Screening),利⽤⽬標圖和製程性能圖將變異和能⼒結合到⼀個輸出中,同時查看兩個供應商的化合物是否穩定,是否符合給定規格。此平台尤其適合⼤量製程需要監測的品質檢測場景,非常推薦使用。
圖()
上圖()的製程能力圖突出了過程是否健康的兩個⽅⾯, 即穩定性指標和製程能力(Ppk)。⼀個穩定的過程將有⼀個接近1的穩定性指標。穩定性指數的值越⾼,表明製程越不穩定。
製程能力Ppk是衡量過程表現的重要參數,數值越,對應於每百萬個產品的缺陷率越低。理想的製程(有能⼒的和穩定的)顯⽰在圖中的綠⾊陰影區域,其中Ppk>1.0, 穩定指數<1.25無能⼒的和不穩定的過程在紅⾊陰影區域,其中Ppk<1.0,穩定指數>1.25
⽬標圖為每個過程在 x 軸上顯⽰規格標準化的均值偏移,在 y 軸上顯⽰規格標準化的標準差,⽤於快速提供關於過程是否符合規格限的匯總視圖。
穩定有能⼒的製程顯⽰在圖中的綠⾊(pk>2.0)和黃⾊(pk>1.0)陰影區域,⽆能⼒的和不穩定的過程在紅⾊陰影區域(Ppk<1.0)。
對於供應商A來說,化合物1和化合物2的兩個過程都是穩定的,但能⼒不⾜。對於供應商B來說,化合物2是穩定的,但能⼒不⾜,⽽化合物1既能⼒不⾜⼜不穩定。
階段性結論和品質改善方案
我們接連使⽤了均值、極差控制圖和多元控制圖等方式,來監測供應商的原材料品質和關鍵製程參數,並要求供應商也使⽤這些控制圖來減少製程過程變異。
理論上,如果供應的原材料不穩定,所有供應批次都應該被監測,並增加原材料抽樣分析的頻率,不過⽬前還不能實現,因為現有的氣相⾊譜分析⽅法(GC)非常花時間,全檢將無法滿⾜⽣產的需求。所以⽬前正在開發的快速分析⽅法,超⾼效液相⾊譜法(UHPLC),將是下⼀步⼯作的重點。如何透過超⾼效液相⾊譜測量系統來實現更快的原材料品質監測?我們將在之後的⽂章中繼續探索。
如對⽂中統計製程控制(SPC)統計⽅法感興趣的朋友,歡迎下載最新版JMP ⾃體驗。瞭解更多資料分析知識與技巧。
推薦閱讀:
Last Modified: May 20, 2024 9:39 AM
