JMP Blog
%3CLINGO-SUB%20id%3D%22lingo-sub-753571%22%20slang%3D%22zh-TW%22%20mode%3D%22CREATE%22%3E%C2%BFQu%C3%A9%20es%20SPC%20(control%20estad%C3%ADstico%20de%20procesos)%3F%20Explicaci%C3%B3n%20del%20proceso%20de%20an%C3%A1lisis%20e%20interpretaci%C3%B3n%20de%20datos%20para%20reducir%20la%20variaci%C3%B3n%20del%20proceso.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-753571%22%20slang%3D%22zh-TW%22%20mode%3D%22CREATE%22%3E%3CP%3ELograr%20la%20excelencia%20en%20la%20fabricaci%C3%B3n%20es%20el%20objetivo%20que%20persigue%20toda%20empresa.%20Para%20lograr%20este%20objetivo%2C%20el%20departamento%20de%20calidad%20debe%20trabajar%20continuamente%20para%20identificar%20las%20fuentes%20de%20variaci%C3%B3n%20del%20proceso%20y%20tomar%20las%20medidas%20adecuadas%20para%20controlar%20el%20objetivo.%20En%20la%20era%20cient%C3%ADfica%20moderna%2C%20las%20unidades%20de%20calidad%20ya%20pueden%20comprender%20el%20proceso%20de%20producci%C3%B3n%20a%20trav%C3%A9s%20del%20an%C3%A1lisis%20de%20datos%2C%20lo%20que%20no%20s%C3%B3lo%20puede%20aumentar%20la%20flexibilidad%20de%20la%20producci%C3%B3n%2C%20sino%20tambi%C3%A9n%20garantizar%20que%20los%20productos%20cumplan%20mejor%20con%20los%20requisitos%20del%20cliente.%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId-1792438906%22%20id%3D%22toc-hId-1792525428%22%3E%3CSTRONG%3ETres%20claves%20para%20lograr%20una%20fabricaci%C3%B3n%20inteligente%3C%2FSTRONG%3E%3C%2FH2%3E%0A%3CP%3EC%C3%B3mo%20lograr%20la%20excelencia%20en%20la%20fabricaci%C3%B3n%20basada%20en%20el%20an%C3%A1lisis%20de%20datos%20cient%C3%ADficos%20es%20un%20problema%20al%20que%20se%20enfrenta%20toda%20empresa%20cuando%20requiere%20mejorar%20la%20calidad%20del%20producto.%20A%20trav%C3%A9s%20de%20%3CSPAN%3Ecasos%20industriales%20anteriores%20de%20cooperaci%C3%B3n%20JMP%2C%20podemos%20ver%20que%20%3CFONT%20color%3D%22%23FF6600%22%3E%3CSTRONG%3Elas%20empresas%20deben%20pasar%20por%20tres%20procesos%20clave%20para%20lograr%20la%20excelencia%20en%20la%20fabricaci%C3%B3n%3C%2FSTRONG%3E%3C%2FFONT%3E%20%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E1.%20%3CSPAN%3EA%20trav%C3%A9s%20de%20gr%C3%A1ficos%20de%20control%20y%20an%C3%A1lisis%20de%20la%20capacidad%20del%20proceso%2C%20se%20implementa%20el%20control%20estad%C3%ADstico%20del%20proceso%20(SPC)%3C%2FSPAN%3E%20%3CSPAN%3Epara%20reducir%20la%20variaci%C3%B3n%20del%20proceso%3B%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EEncontrar%20fuentes%20de%20variaci%C3%B3n%20en%20el%20proceso%20de%20medici%C3%B3n%3C%2FSPAN%3E%20%3CSPAN%3Ea%20trav%C3%A9s%20del%20an%C3%A1lisis%20del%20sistema%20de%20medici%C3%B3n%3C%2FSPAN%3E%20(MSA)%3B%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EMediante%20el%20dise%C3%B1o%20de%20experimentos%3C%2FSPAN%3E%20(DOE)%20%3CSPAN%3Ey%20el%20modelado%20predictivo%2C%20se%20determinan%20los%20factores%20que%20afectan%20la%20variaci%C3%B3n%20de%20la%20medici%C3%B3n%3C%2FSPAN%3E%20y%20se%20encuentra%20la%20configuraci%C3%B3n%20%C3%B3ptima%20de%20los%20factores%20para%20hacer%20que%20el%20proceso%20de%20medici%C3%B3n%20sea%20m%C3%A1s%20s%C3%B3lido.%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3ETomemos%20el%20caso%20de%20un%20fabricante%20farmac%C3%A9utico%20para%20ver%20c%C3%B3mo%20implementar%20esta%20%E2%80%9Ctrilog%C3%ADa%20de%20an%C3%A1lisis%20de%20datos%E2%80%9D.%20Primero%2C%20echemos%20un%20vistazo%20a%20c%C3%B3mo%20realizar%20el%20control%20estad%C3%ADstico%20de%20procesos%20(SPC)%20%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId--759718055%22%20id%3D%22toc-hId--759631533%22%3E%3CSTRONG%3EAn%C3%A1lisis%20de%20casos%20pr%C3%A1cticos%3C%2FSTRONG%3E%3C%2FH2%3E%0A%3CH3%20id%3D%22toc-hId-786578775%22%20id%3D%22toc-hId-786665297%22%3E%3CSTRONG%3EAntecedentes%20del%20proceso%3C%2FSTRONG%3E%3C%2FH3%3E%0A%3CP%3EFVM%20%3CSPAN%3EPharmaceuticals%20es%3C%2FSPAN%3E%20un%20fabricante%20farmac%C3%A9utico%20internacional%20que%20se%20especializa%20en%20la%20producci%C3%B3n%20de%20productos%20farmac%C3%A9uticos%20terminados%20de%20alta%20calidad%20en%20tabletas%2C%20c%C3%A1psulas%20y%20l%C3%ADquidos.%20En%20el%20proceso%20farmac%C3%A9utico%2C%20un%20proceso%20de%20fabricaci%C3%B3n%20t%C3%ADpico%20incluye%3A%20%3CSPAN%3Emoler%20el%20ingrediente%20farmac%C3%A9utico%20activo%20(API)%20hasta%20obtener%20un%20polvo%20de%20tama%C3%B1o%20de%20part%C3%ADcula%20uniforme%3C%2FSPAN%3E%20y%20luego%20mezclar%20el%20material%20molido%20con%20otros%20componentes%20para%20aumentar%20el%20volumen%20del%20API%20y%20distribuirlo%20uniformemente.%20Luego%2C%20el%20material%20mezclado%20se%20comprime%20en%20tabletas%20y%20finalmente%20se%20recubre%20para%20mejorar%20la%20vida%20%C3%BAtil%2C%20la%20sensaci%C3%B3n%20en%20la%20boca%20y%20otras%20propiedades.%20Al%20final%20de%20este%20proceso%20se%20registran%20diversos%20par%C3%A1metros%20de%20calidad%20para%20la%20aceptaci%C3%B3n%20del%20lote.%3C%2FP%3E%0A%3CP%3ELas%20materias%20primas%20para%20el%20proceso%20anterior%20son%20emulsiones%20concentradas%20que%20contienen%20dos%20compuestos%20org%C3%A1nicos%2C%20que%20son%20proporcionadas%20por%20dos%20proveedores%20(A%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20B%20%3CSPAN%3E)%20al%20mismo%20tiempo.%20La%20compa%C3%B1%C3%ADa%20farmac%C3%A9utica%3C%2FSPAN%3E%20%3CSPAN%3Emonitorea%20la%20calidad%3C%2FSPAN%3E%20%3CSPAN%3Emidiendo%20la%20concentraci%C3%B3n%20(mg%2FL)%20de%20los%20compuestos.%20cromatograf%C3%ADa%20de%20gases%20(GC)%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId--1765578186%22%20id%3D%22toc-hId--1765491664%22%3E%3CSTRONG%3Eproblemas%20de%20situaci%C3%B3n%20actual%3C%2FSTRONG%3E%3C%2FH3%3E%0A%3CP%3ERecientemente%2C%20el%20equipo%20de%20gesti%C3%B3n%20de%20calidad%20descubri%C3%B3%20que%20existen%20grandes%20diferencias%20en%20la%20calidad%20de%20los%20medicamentos.%20A%20trav%C3%A9s%20de%20la%20resoluci%C3%B3n%20de%20problemas%2C%20se%20sospecha%20que%20el%20problema%20probablemente%20provenga%20de%20las%20materias%20primas.%20Con%20este%20fin%2C%20la%20empresa%20ha%20creado%20un%20grupo%20de%20mejora%20de%20la%20calidad%2C%20%3CSTRONG%3Econ%20la%20esperanza%3C%2FSTRONG%3E%20%3CSTRONG%3Ede%20utilizar%3C%2FSTRONG%3E%20%3CSTRONG%3Eherramientas%3C%2FSTRONG%3E%20estad%C3%ADsticas%20%3CSTRONG%3E%2C%20combinadas%20con%20calidad%20por%20dise%C3%B1o%3C%2FSTRONG%3E%20%3CSTRONG%3E(%3C%2FSTRONG%3E%20%3CSTRONG%3EQbD%3C%2FSTRONG%3E%20%3CSTRONG%3E%3CSPAN%3E)%20y%20mediante%20la%20toma%20de%20decisiones%20basada%20en%20datos%2C%20para%20encontrar%20fundamentalmente%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%3CSTRONG%3Euna%3C%2FSTRONG%3E%20%3CSTRONG%3Esoluci%C3%B3n%20sostenible%3C%2FSTRONG%3E%20%3CSTRONG%3Ey%3C%2FSTRONG%3E%20%3CSTRONG%3Edeterminar%20los%20cambios%20clave%20en%20el%20proceso.%20factores%20determinantes%3C%2FSTRONG%3E%20para%20lograr%20en%20%C3%BAltima%20instancia%20el%20objetivo%20de%20%3CSTRONG%3Eoptimizar%20la%20configuraci%C3%B3n%20del%20proceso%3C%2FSTRONG%3E%20.%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId--22767851%22%20id%3D%22toc-hId--22681329%22%3E%3CSTRONG%3EMejorar%20el%20proceso%3C%2FSTRONG%3E%3C%2FH3%3E%0A%3CP%3EPrimero%2C%20el%20equipo%20de%20mejora%20de%20la%20calidad%20realiza%20un%20control%20estad%C3%ADstico%20del%20proceso%20(SPC)%20del%20producto%20%3CSPAN%3E.%3C%2FSPAN%3E%20Comprender%20la%20estabilidad%20del%20proceso%20y%20analizar%20el%20patr%C3%B3n%20de%20cambios%20del%20proceso%20a%20trav%C3%A9s%20de%20gr%C3%A1ficos%20de%20control.%20A%20trav%C3%A9s%20del%20an%C3%A1lisis%20de%20la%20capacidad%20del%20proceso%2C%20eval%C3%BAe%20si%20cumple%20con%20%3CSPAN%3Elos%20plazos%20de%20entrega%20externos%20o%20del%20cliente.%20Ambas%3C%2FSPAN%3E%20herramientas%20apoyan%20una%20mejor%20comprensi%C3%B3n%20de%20los%20procesos%20y%20gu%C3%ADan%20el%20desarrollo%20de%20estrategias%20de%20mejora.%20El%20equipo%20%3CSPAN%3Erecolect%C3%B3%20muestras%20de%20dos%20materias%20primas%20compuestas%20de%20dos%20proveedores%20durante%208%20d%C3%ADas%20y%20las%20import%C3%B3%20al%3C%2FSPAN%3E%20%3CSPAN%3Esoftware%20JMP%2C%20involucrando%20todos%20los%20lotes.%20La%20siguiente%20figura%20(1)%20es%20una%20captura%20de%20pantalla%20de%20parte%20de%20los%20datos.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20590px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20590px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64099i8EF666A1846F6F10%2Fimage-dimensions%2F590x447%3Fv%3Dv2%22%20width%3D%22590%22%20height%3D%22447%22%20role%3D%22button%22%20title%3D%221.png%22%20alt%3D%221.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigura%20%3CSPAN%3E1%3C%2FSPAN%3E%20)%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId-1523528979%22%20id%3D%22toc-hId-1523615501%22%3E%3CFONT%20color%3D%22%23333399%22%3E%3CSTRONG%3ERequisitos%20previos%20para%20el%20an%C3%A1lisis%3A%20comprobar%20si%20los%20datos%20muestran%20normalidad%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FH4%3E%0A%3CP%3ELa%20premisa%20utilizada%20por%20muchas%20herramientas%20estad%C3%ADsticas%20de%20calidad%20es%20que%20los%20datos%20provienen%20de%20una%20distribuci%C3%B3n%20normal%3B%20de%20lo%20contrario%2C%20informar%20los%20resultados%20bas%C3%A1ndose%20en%20la%20media%20y%20la%20desviaci%C3%B3n%20est%C3%A1ndar%20no%20tendr%C3%A1%20sentido.%20Utilice%20el%20%3CSPAN%3Emen%C3%BA%20JMP%2C%20haga%20clic%20en%20%22Analizar%3C%2FSPAN%3E%20%C3%A0%20%3CSPAN%3EDistribuci%C3%B3n%3C%2FSPAN%3E%20%3CSPAN%3E%22%20y%20combine%3C%2FSPAN%3E%20los%20resultados%20de%20%3CSPAN%3Ela%20prueba%20SW%20y%3C%2FSPAN%3E%20%3CSPAN%3Ela%20prueba%20AD%20para%20confirmar%20que%20los%20datos%20de%20los%20dos%20compuestos%20muestran%20una%20distribuci%C3%B3n%20normal%2C%20lo%20que%20indica%20que%20no%20hay%20ning%C3%BAn%20problema.%20Los%20resultados%20se%20muestran%20en%20la%20Figura%20(2)%20a%20continuaci%C3%B3n.%20.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20587px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20587px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64100i4A086018827E5D71%2Fimage-dimensions%2F587x429%3Fv%3Dv2%22%20width%3D%22587%22%20height%3D%22429%22%20role%3D%22button%22%20title%3D%222.png%22%20alt%3D%222.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigura%20%3CSPAN%3EII%3C%2FSPAN%3E%20)%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EPor%20supuesto%2C%20tambi%C3%A9n%20%3CSPAN%3Epuede%3C%2FSPAN%3E%20verificar%20%3CSPAN%3Er%C3%A1pidamente%3C%2FSPAN%3E%20los%20tres%20par%C3%A1metros%20%22%20%3CSPAN%3Ed%C3%ADa%3C%2FSPAN%3E%20%22%20%3CSPAN%3E.%3C%2FSPAN%3E%20La%20relaci%C3%B3n%20entre%20%22%20%3CSPAN%3Elote%3C%2FSPAN%3E%20%22%20%3CSPAN%3Ey%3C%2FSPAN%3E%20%22%20%3CSPAN%3Eproveedor%3C%2FSPAN%3E%20%22%20%3CSPAN%3Ecomo%20posibles%20impulsores%20de%20la%20variabilidad%20y%20los%20cambios%20en%20los%20dos%20compuestos%20se%20muestra%20en%20la%20Figura%3C%2FSPAN%3E%20(%20%3CSPAN%3E3%3C%2FSPAN%3E%20)%20%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPor%20ejemplo%2C%20todos%20los%20d%C3%ADas%20se%20utilizan%20lotes%20de%20dos%20proveedores%2C%20pero%20incluso%20para%20lotes%20del%20mismo%20d%C3%ADa%2C%20los%20resultados%20para%20el%20Compuesto%201%20%3CSPAN%3Ey%20el%20Compuesto%3C%2FSPAN%3E%202%20%3CSPAN%3Eson%20muy%20diferentes%3C%2FSPAN%3E%20.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20545px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20545px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64101i369AAC6D9F774B64%2Fimage-dimensions%2F545x199%3Fv%3Dv2%22%20width%3D%22545%22%20height%3D%22199%22%20role%3D%22button%22%20title%3D%223.png%22%20alt%3D%223.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EImagen%20(%20%3CSPAN%3E3%3C%2FSPAN%3E%20)%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId--1028627982%22%20id%3D%22toc-hId--1028541460%22%3E%3CFONT%20color%3D%22%23333399%22%3E%3CSTRONG%3EEl%20segundo%20paso%20del%20an%C3%A1lisis%3A%20comprobar%20si%20hay%20alguna%20variaci%C3%B3n%20en%20los%20datos.%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FH4%3E%0A%3CP%3EDespu%C3%A9s%20de%20completar%20la%20prueba%20de%20normalidad%20y%20el%20an%C3%A1lisis%20del%20histograma%2C%20puede%20utilizar%20la%20plataforma%20%3CSTRONG%3EJMP%3C%2FSTRONG%3E%20Control%20Chart%20Builder%20(%20%3CSTRONG%3EControl%20Chart%20Builder)%20%3CSPAN%3Epara%20explorar%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%3CSTRONG%3Eproblemas%3C%2FSTRONG%3E%20de%20calidad.%20Dado%20que%20existe%20variaci%C3%B3n%20en%20cualquier%20sistema%20y%20proceso%2C%20%3CSTRONG%3Elos%20gr%C3%A1ficos%20de%20control%20pueden%3C%2FSTRONG%3E%20%3CSTRONG%3Ecalcular%3C%2FSTRONG%3E%20%3CSTRONG%3Eautom%C3%A1ticamente%3C%2FSTRONG%3E%20los%20l%C3%ADmites%20de%20control%2C%20lo%20que%20puede%20distinguir%20efectivamente%20la%20variaci%C3%B3n%20causada%20por%20causas%20generales%20y%20causas%20especiales%20en%20la%20variaci%C3%B3n%20del%20proceso%2C%20identificando%20y%20eliminando%20as%C3%AD%20las%20fluctuaciones%20de%20datos%20causadas%20por%20causas%20especiales.%3C%2FP%3E%0A%3CP%3EOtra%20herramienta%20de%20calidad%20com%C3%BAnmente%20utilizada%2C%20%3CSTRONG%3E%3CSPAN%3Eel%20An%C3%A1lisis%20de%20capacidad%20del%20proceso%3C%2FSPAN%3E%20(Capacidad%20del%20proceso)%20%3CSPAN%3E%2C%20puede%20medir%20de%20manera%20efectiva%3C%2FSPAN%3E%3C%2FSTRONG%3E%20c%C3%B3mo%20se%20desempe%C3%B1a%20%3CSTRONG%3Eun%3C%2FSTRONG%3E%20%3CSTRONG%3Eproceso%20en%20comparaci%C3%B3n%20con%20los%20l%C3%ADmites%20de%20especificaci%C3%B3n%20dados%20y%20ayuda%20a%20identificar%20procesos%20de%20bajo%20rendimiento%3C%2FSTRONG%3E%20.%20Los%20l%C3%ADmites%20de%20especificaci%C3%B3n%20utilizados%20en%20los%20c%C3%A1lculos%20los%20establecen%20sistemas%20externos%20o%20seg%C3%BAn%20los%20requisitos%20del%20proceso.%20En%20este%20ejemplo%2C%20%3CSPAN%3Elos%20l%C3%ADmites%20de%20especificaci%C3%B3n%20inferior%20y%20superior%20del%20compuesto%201%20son%3C%2FSPAN%3E%20100%20mg%2Fl%20%3CSPAN%3Ey%3C%2FSPAN%3E%20500%20mg%2Fl%20respectivamente%2C%20y%20%3CSPAN%3Elos%20l%C3%ADmites%20de%20especificaci%C3%B3n%20inferior%20y%20superior%20del%3C%2FSPAN%3E%20%3CSPAN%3Ecompuesto%3C%2FSPAN%3E%202%20son%20300%20mg%2Fl%20%3CSPAN%3Ey%3C%2FSPAN%3E%20600%20mg%2Fl%20%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EUn%3C%2FSTRONG%3E%20%3CSTRONG%3Ebuen%20proceso%20es%3C%2FSTRONG%3E%20%3CSTRONG%3Eaquel%3C%2FSTRONG%3E%20%3CSTRONG%3Eque%20es%20estable%20y%3C%2FSTRONG%3E%20%3CSTRONG%3Eproduce%3C%2FSTRONG%3E%20consistentemente%20%3CSTRONG%3Eun%20producto%20que%20est%C3%A1%20dentro%20de%20los%20l%C3%ADmites%20de%20las%20especificaciones.%3C%2FSTRONG%3E%20Las%20dos%20herramientas%20anteriores%2C%20Control%20Chart%20Builder%20y%20Process%20Capability%2C%20%3CSPAN%3Ese%20utilizan%20a%20menudo%20en%20combinaci%C3%B3n%3C%2FSPAN%3E%20para%20evaluar%20la%20estabilidad%20del%20proceso%20y%20su%20capacidad%20para%20cumplir%20con%20las%20especificaciones%20del%20cliente.%3C%2FP%3E%0A%3CP%3EA%20trav%C3%A9s%20de%20la%20plataforma%20generadora%20de%20%3CSPAN%3Egr%C3%A1ficos%20de%20control%20de%3C%2FSPAN%3E%20JMP%2C%20puede%20obtener%20r%C3%A1pidamente%20los%20resultados%20de%20salida%20en%20la%20Figura%20(%20%3CSPAN%3E4%3C%2FSPAN%3E%20)%20a%20continuaci%C3%B3n.%20El%20lado%20izquierdo%20es%20el%20gr%C3%A1fico%20de%20control%20XBar%26amp%3BR%20%3CSPAN%3Edel%3C%2FSPAN%3E%20%3CSPAN%3Ecompuesto%3C%2FSPAN%3E%201%20%3CSPAN%3Ey%20el%20compuesto%3C%2FSPAN%3E%202%20respectivamente%20%3CSPAN%3E%2C%20y%20el%20lado%20derecho%20es%20el%20resultado%20del%20an%C3%A1lisis%20de%20capacidad%20del%20proceso.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20717px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20717px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64102iC558E09429B8E299%2Fimage-dimensions%2F717x712%3Fv%3Dv2%22%20width%3D%22717%22%20height%3D%22712%22%20role%3D%22button%22%20title%3D%224.png%22%20alt%3D%224.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigura%20(%20%3CSPAN%3E4%3C%2FSPAN%3E%20)%20Resultados%20del%20generador%20%3CSPAN%3Ede%20gr%C3%A1ficos%20de%20control%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId-714182353%22%20id%3D%22toc-hId-714268875%22%3E%3CFONT%20color%3D%22%23333399%22%3E%3CSTRONG%3EEl%20tercer%20paso%20del%20an%C3%A1lisis%3A%20interpretaci%C3%B3n%20de%20datos%20de%20los%20resultados%20del%20an%C3%A1lisis.%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FH4%3E%0A%3COL%3E%0A%3CLI%3EEl%20%3CSPAN%3Egr%C3%A1fico%20XBar%20es%20un%20gr%C3%A1fico%20de%20control%20de%20medias%20con%20lotes%20como%3C%2FSPAN%3E%20subgrupos.%20La%20observaci%C3%B3n%20muestra%20que%20%3CSPAN%3Etodos%20los%20puntos%20del%20Compuesto%201%20caen%20aleatoriamente%20dentro%20del%20rango%20de%20control%20(%C3%A1reas%20verde%3C%2FSPAN%3E%20y%20amarilla).%20Al%20introducir%20la%20regla%20discriminante%2C%20no%20se%20circulan%20ni%20marcan%20puntos%2C%20lo%20que%20significa%20que%20el%20proceso%20est%C3%A1%20%22%20%3CSPAN%3Ebajo%20control%3C%2FSPAN%3E%20%22%20%3CSPAN%3Eo%20es%20estable.%3C%2FSPAN%3E%20%3CSPAN%3EDespu%C3%A9s%20de%20introducir%20la%20regla%20de%20juicio%20para%20el%20compuesto%202%2C%20se%20encontr%C3%B3%20que%20el%20lote%20n%C3%BAmero%3C%2FSPAN%3E%2011%20%3CSPAN%3Ecay%C3%B3%20en%20el%20%C3%A1rea%20roja%3C%2FSPAN%3E%20y%20estaba%20rodeado%20o%20marcado%20con%20un%20c%C3%ADrculo%2C%20lo%20que%20indicaba%20que%20el%20proceso%20estaba%20fuera%20de%20control%20o%20era%20inestable.%3C%2FLI%3E%0A%3CLI%3EEl%20%3CSPAN%3Egr%C3%A1fico%20R%20es%20un%20gr%C3%A1fico%20de%20control%20de%20rango%20con%20lotes%20como%3C%2FSPAN%3E%20subgrupos%20y%20se%20utiliza%20para%20monitorear%20las%20fluctuaciones%20en%20el%20proceso.%20Cada%20punto%20del%20gr%C3%A1fico%20representa%20la%20diferencia%20entre%20los%20valores%20m%C3%A1ximo%20y%20m%C3%ADnimo%20del%20rango%20del%20lote.%20Al%20presentar%20la%20regla%20de%20juicio%2C%20podemos%20ver%20que%20el%20d%C3%A9cimo%20%3CSPAN%3Elote%3C%2FSPAN%3E%20%3CSPAN%3Edel%3C%2FSPAN%3E%20compuesto%201%20y%20%3CSPAN%3Eel%20quinto%20lote%20del%3C%2FSPAN%3E%20compuesto%202%20%3CSPAN%3Eexceden%20los%20l%C3%ADmites%20de%20control%2C%20lo%20que%20indica%20que%20existen%3C%2FSPAN%3E%20algunas%20razones%20especiales%20que%20causan%20fluctuaciones%20en%20el%20proceso.%3C%2FLI%3E%0A%3CLI%3ELa%20parte%20derecha%20son%20los%20resultados%20del%20an%C3%A1lisis%20de%20la%20capacidad%20del%20proceso%2C%20que%20se%20utilizan%20para%20identificar%20procesos%20con%20un%20rendimiento%20deficiente.%20Varios%20indicadores%20de%20capacidad%20com%C3%BAnmente%20utilizados%20para%20evaluar%20incluyen%3A%3COL%3E%3CLI%3E%20Cp%2FPp%20%3CSPAN%3E%3A%20La%20relaci%C3%B3n%20entre%20el%20ancho%20del%20l%C3%ADmite%20de%20especificaci%C3%B3n%20y%20la%20fluctuaci%C3%B3n%20del%20proceso.%3C%2FSPAN%3E%20Cp%20se%20denomina%20capacidad%20potencial%20del%20proceso%20interno%20(o%20de%20corto%20plazo)%20(considerando%20solo%20las%20fluctuaciones%20dentro%20de%20un%20subgrupo)%2C%20y%20Pp%20se%20llama%20capacidad%20potencial%20del%20proceso%20general%20(o%20de%20largo%20plazo)%20(considerando%20las%20fluctuaciones%20en%20todos%20los%20grupos%20en%20su%20conjunto).%20Son%20un%20indicador%20com%C3%BAn%20de%20cu%C3%A1nta%20capacidad%20se%20puede%20lograr%20si%20la%20media%20del%20proceso%20y%20la%20media%20del%20objetivo%20son%20consistentes%3B%3C%2FLI%3E%3CLI%3E%20Cpl%2FPpl%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20se%20utiliza%20para%20comprobar%20la%20capacidad%20de%20un%20proceso%20para%20cumplir%20con%20el%20l%C3%ADmite%20inferior%20de%20especificaciones%3B%3C%2FLI%3E%3CLI%3E%20Cpu%2FPpu%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20se%20utiliza%20para%20comprobar%20la%20capacidad%20de%20un%20proceso%20para%20cumplir%20con%20el%20l%C3%ADmite%20de%20especificaci%C3%B3n%20superior%3B%3C%2FLI%3E%3CLI%3E%20Cpk%2FPpk%20%3CSPAN%3E%3A%20toma%3C%2FSPAN%3E%20el%20%3CSPAN%3Evalor%20m%C3%ADnimo%20de%3C%2FSPAN%3E%20Cpl%2FPpl%20%3CSPAN%3Ey%3C%2FSPAN%3E%20Cpu%2FPpu.%3C%2FLI%3E%3CLI%3E%20Cpk%2FPpk%20%3CSPAN%3Ees%20igual%20a%3C%2FSPAN%3E%201%2C0%20%3CSPAN%3E%2C%20lo%20que%20se%20considera%3C%2FSPAN%3E%20un%20proceso%20apenas%20calificado.%20Por%20supuesto%2C%20algunos%20est%C3%A1ndares%20de%20la%20industria%20requieren%20que%20el%20valor%20m%C3%ADnimo%20%3CSPAN%3Ede%3C%2FSPAN%3E%20Cpk%2FPpk%20sea%201%2C33%20%3CSPAN%3Eo%20incluso%3C%2FSPAN%3E%20superior.%3C%2FLI%3E%3C%2FOL%3E%3C%2FLI%3E%0A%3CLI%3EEl%20%3CSPAN%3Evalor%20actual%20de%20Cpk%20y%3C%2FSPAN%3E%20el%20valor%20de%20Ppk%20%3CSPAN%3Edel%3C%2FSPAN%3E%20compuesto%201%20de%20materia%20prima%20%3CSPAN%3Eson%3C%2FSPAN%3E%200%2C740%20%3CSPAN%3Ey%3C%2FSPAN%3E%200%2C752%20respectivamente%20%3CSPAN%3E%2C%20por%20lo%20que%20el%20proceso%20se%20considera%20no%20calificado.%20El%20compuesto%3C%2FSPAN%3E%202%20%3CSPAN%3Etampoco%20es%20muy%20bueno%2C%3C%2FSPAN%3E%20con%20valores%20de%20Cpk%20%3CSPAN%3Ey%3C%2FSPAN%3E%20Ppk%20de%201%2C005%20%3CSPAN%3Ey%3C%2FSPAN%3E%200%2C746%20%3CSPAN%3Erespectivamente%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId--1837974608%22%20id%3D%22toc-hId--1837888086%22%3E%3CFONT%20color%3D%22%23333399%22%3E%3CSTRONG%3EEl%20cuarto%20paso%20del%20an%C3%A1lisis%3A%20explorar%20las%20fuentes%20de%20variaci%C3%B3n%20desde%20la%20perspectiva%20del%20proveedor%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FH4%3E%0A%3CP%3EArrastre%20el%20proveedor%20a%20la%20parte%20superior%20del%20gr%C3%A1fico%20de%20control%20(%C3%A1rea%20de%20etapa)%20para%20dividir%20el%20gr%C3%A1fico%20de%20control%20por%20proveedor%2C%20como%20%3CSPAN%3Ese%20muestra%3C%2FSPAN%3E%20en%20la%20Figura%20(%20%3CSPAN%3E5%3C%2FSPAN%3E%20)%20a%20continuaci%C3%B3n.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%225.png%22%20style%3D%22width%3A%20710px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225.png%22%20style%3D%22width%3A%20710px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64103i07B82864577DF54D%2Fimage-dimensions%2F710x283%3Fv%3Dv2%22%20width%3D%22710%22%20height%3D%22283%22%20role%3D%22button%22%20title%3D%225.png%22%20alt%3D%225.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigura%20%3CSPAN%3E5%3C%2FSPAN%3E%20)%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EComo%20se%20puede%20ver%20en%20la%20Figura%20(%20%3CSPAN%3E5%3C%2FSPAN%3E%20)%20anterior%20%3CSPAN%3E%2C%20para%20estos%20dos%20compuestos%2C%20seg%C3%BAn%20los%20l%C3%ADmites%20de%20control%20existentes%2C%20aunque%20los%20dos%20compuestos%20proporcionados%20por%20el%20proveedor%3C%2FSPAN%3E%20A%20%3CSPAN%3Eson%20muy%20estables%20(el%20lote%20est%C3%A1%20dentro%20del%20l%C3%ADmite%20de%20control)%2C%20podemos%20encontrar%3A%20Proveedor%20de%20suministro%3C%2FSPAN%3E%20A%20%3CSPAN%3Etiene%3C%2FSPAN%3E%20%3CSPAN%3Euna%20variaci%C3%B3n%20significativamente%20mayor%20entre%20lotes%20que%20el%20proveedor%3C%2FSPAN%3E%20B.%20%3CSPAN%3ELa%20variaci%C3%B3n%20entre%20lotes%20del%20Proveedor%20B%20fue%20relativamente%3C%2FSPAN%3E%20peque%C3%B1a%2C%20pero%20se%20encontr%C3%B3%20que%20%3CSPAN%3Eel%20Compuesto%201%20del%3C%2FSPAN%3E%20Proveedor%20B%20%3CSPAN%3Eexhib%C3%ADa%20una%20variaci%C3%B3n%20por%20causa%20espec%C3%ADfica.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EAdem%C3%A1s%2C%20tambi%C3%A9n%20podemos%20intentar%20utilizar%20un%20gr%C3%A1fico%20de%20control%20multivariante%20basado%20en%20modelos%20(MDMVCC%20%3CSPAN%3E)%20%3CSTRONG%3Ey%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSTRONG%3Eutilizar%3C%2FSTRONG%3E%20%3CSTRONG%3Eel%20an%C3%A1lisis%20de%20componentes%20principales%3C%2FSTRONG%3E%20%3CSTRONG%3E(PCA%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%3CSTRONG%3Epara%20monitorear%20los%20par%C3%A1metros%20de%20m%C3%BAltiples%20procesos%20en%20un%20gr%C3%A1fico%20de%20control%3C%2FSTRONG%3E%20%3CSTRONG%3E.%3C%2FSTRONG%3E%20En%20algunos%20escenarios%2C%20si%20simplemente%20observa%20cada%20proceso%20de%20forma%20independiente%2C%20todos%20parecen%20estables.%20%3CSTRONG%3EA%20trav%C3%A9s%20de%20gr%C3%A1ficos%20de%20control%20multivariados%2C%20puede%20detectar%20la%20inestabilidad%20potencial%20de%20m%C3%BAltiples%20procesos%20al%20mismo%20tiempo%3C%2FSTRONG%3E%20e%20investigar%20en%20profundidad%20la%20contribuci%C3%B3n%20de%20los%20procesos%20individuales%20al%20proceso%20general.%20para%20diagnosticar%20si%20el%20proceso%20es%20estable.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%226.png%22%20style%3D%22width%3A%20703px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%226.png%22%20style%3D%22width%3A%20703px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64104i9830B7482840DC7E%2Fimage-dimensions%2F703x232%3Fv%3Dv2%22%20width%3D%22703%22%20height%3D%22232%22%20role%3D%22button%22%20title%3D%226.png%22%20alt%3D%226.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigura%20(%20%3CSPAN%3E6%3C%2FSPAN%3E%20)%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EEn%20la%20Figura%20(%20%3CSPAN%3E6%3C%2FSPAN%3E%20)%20anterior%20%3CSPAN%3E%2C%20podemos%20ver%20que%20todos%20los%20lotes%20del%20proveedor%3C%2FSPAN%3E%20A%20%3CSPAN%3Eest%C3%A1n%20dentro%20de%20los%20l%C3%ADmites%20de%20control%2C%3C%2FSPAN%3E%20mientras%20que%20para%20el%20proveedor%20B%20%3CSPAN%3E%2C%20podemos%20ver%20claramente%20que%20tres%20lotes%20est%C3%A1n%20fuera%20de%20los%20puntos%20de%20control%20y%20requieren%20atenci%C3%B3n.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EAdem%C3%A1s%2C%20tambi%C3%A9n%20podemos%20utilizar%20la%20%3CSPAN%3Eplataforma%20de%20evaluaci%C3%B3n%20de%20la%20capacidad%20del%20proceso%3C%2FSPAN%3E%20JMP%20(Process%20Screening)%20%3CSPAN%3Epara%3C%2FSPAN%3E%20combinar%20variaci%C3%B3n%20y%20capacidad%20en%20un%20solo%20resultado%20usando%20gr%C3%A1ficos%20de%20objetivos%20y%20gr%C3%A1ficos%20de%20rendimiento%20del%20proceso%2C%20%3CSTRONG%3Ey%20verificar%20simult%C3%A1neamente%20si%20los%20compuestos%20de%20dos%20proveedores%20son%20estables%20y%20si%20cumplen%20con%20las%20especificaciones%20dadas.%3C%2FSTRONG%3E%20.%20Esta%20plataforma%20es%20especialmente%20adecuada%20para%20escenarios%20de%20inspecci%C3%B3n%20de%20calidad%20que%20requieren%20monitoreo%20de%20procesos%20de%20fabricaci%C3%B3n%20de%20gran%20volumen%20y%20es%20muy%20recomendable.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64105i2A045FCAB0FEC6B3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%227.png%22%20alt%3D%227.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigura%20(%20%3CSPAN%3E7%3C%2FSPAN%3E%20)%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EEl%20cuadro%20de%20capacidad%20del%20proceso%20en%20la%20Figura%20(%20%3CSPAN%3E7%3C%2FSPAN%3E%20)%20anterior%20%3CSPAN%3Eresalta%20dos%20aspectos%20de%20si%20el%20proceso%20est%C3%A1%20en%20buen%20estado%3C%2FSPAN%3E%20%2C%20a%20saber%2C%20el%20%C3%ADndice%20de%20estabilidad%20y%20la%20capacidad%20del%20proceso%20(Ppk%20%3CSPAN%3E).%3C%2FSPAN%3E%20Un%20proceso%20estable%20tendr%C3%A1%20%3CSPAN%3Eun%20%C3%ADndice%20de%20estabilidad%20cercano%20a%201.%3C%2FSPAN%3E%20Cuanto%20mayor%20sea%20%3CSPAN%3Eel%20valor%20del%20%C3%ADndice%20de%20estabilidad%3C%2FSPAN%3E%20%2C%20m%C3%A1s%20inestable%20ser%C3%A1%20el%20proceso.%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ELa%20capacidad%20del%20proceso%3C%2FSTRONG%3E%20%3CSTRONG%3EPpk%20%3CSPAN%3Ees%20un%20par%C3%A1metro%20importante%20para%20medir%20el%20rendimiento%20del%20proceso.%20Cuanto%20mayor%20sea%20el%20valor%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%3CSTRONG%3E%2C%3C%2FSTRONG%3E%20%3CSTRONG%3Emenor%20ser%C3%A1%20la%20tasa%20de%20defectos%20por%20mill%C3%B3n%20de%20productos%3C%2FSTRONG%3E%20.%20El%20proceso%20ideal%20(capaz%20y%20estable)%20se%20muestra%20en%20el%20%C3%A1rea%20sombreada%20en%20verde%20de%20la%20figura%2C%20donde%20Ppk%26gt%3B1%2C0%20%3CSPAN%3Ey%20el%20%C3%ADndice%20de%20estabilidad%3C%2FSPAN%3E%20%26lt%3B1%2C25%20%3CSPAN%3E.%3C%2FSPAN%3E%20Los%20procesos%20incompetentes%20e%20inestables%20se%20encuentran%20en%20el%20%C3%A1rea%20sombreada%20en%20rojo%2C%20donde%20Ppk%26lt%3B1%2C0%20%3CSPAN%3Ey%20el%20%C3%ADndice%20de%20estabilidad%3C%2FSPAN%3E%20%26gt%3B1%2C25%20%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ELos%20gr%C3%A1ficos%20de%20objetivos%20muestran%20el%20cambio%20medio%20normalizado%20por%20especificaci%C3%B3n%20en%20el%20%3CSPAN%3Eeje%3C%2FSPAN%3E%20x%20y%20la%20desviaci%C3%B3n%20est%C3%A1ndar%20normalizada%20por%20especificaci%C3%B3n%20en%20el%20%3CSPAN%3Eeje%3C%2FSPAN%3E%20y%20para%20cada%20proceso%20y%20se%20utilizan%20para%20proporcionar%20r%C3%A1pidamente%20una%20vista%20resumida%20de%20si%20un%20proceso%20est%C3%A1%20dentro%20de%20los%20l%C3%ADmites%20de%20especificaci%C3%B3n.%3C%2FP%3E%0A%3CP%3ELos%20procesos%20estables%20y%20capaces%20se%20muestran%20en%20las%20%C3%A1reas%20sombreadas%20en%20verde%20(pk%26gt%3B2%2C0%20%3CSPAN%3E)%20y%20amarillo%3C%2FSPAN%3E%20(pk%26gt%3B1%2C0%20%3CSPAN%3E)%20de%20la%20figura%2C%20y%3C%2FSPAN%3E%20los%20procesos%20incompetentes%20e%20inestables%20se%20muestran%20en%20el%20%C3%A1rea%20sombreada%20en%20rojo%20(Ppk%26lt%3B1%2C0%20%3CSPAN%3E).%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPara%20el%20Proveedor%20A%20%3CSPAN%3E%2C%20ambos%20procesos%20para%20el%20Compuesto%3C%2FSPAN%3E%201%20%3CSPAN%3Ey%20el%20Compuesto%3C%2FSPAN%3E%202%20%3CSPAN%3Eson%20estables%20pero%20tienen%3C%2FSPAN%3E%20capacidades%20insuficientes.%20Para%20el%20Proveedor%20B%20%3CSPAN%3E%2C%20el%20Compuesto%3C%2FSPAN%3E%202%20%3CSPAN%3Ees%20estable%20pero%20insuficientemente%20capaz%3C%2FSPAN%3E%20%2C%20mientras%20que%20el%20Compuesto%201%20%3CSPAN%3Ees%3C%2FSPAN%3E%20insuficientemente%20capaz%20e%20inestable.%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId-297862737%22%20id%3D%22toc-hId-297949259%22%3E%3CSTRONG%3EConclusiones%20escalonadas%20y%20planes%20de%20mejora%20de%20la%20calidad.%3C%2FSTRONG%3E%3C%2FH2%3E%0A%3CP%3EHemos%20utilizado%20sucesivamente%20medios%2C%20gr%C3%A1ficos%20de%20control%20de%20rango%20y%20gr%C3%A1ficos%20de%20control%20multivariado%20para%20monitorear%20la%20calidad%20de%20la%20materia%20prima%20y%20los%20par%C3%A1metros%20clave%20del%20proceso%20de%20los%20proveedores%2C%20y%20exigimos%20a%20los%20proveedores%20que%20tambi%C3%A9n%20utilicen%20estos%20gr%C3%A1ficos%20de%20control%20para%20reducir%20la%20variabilidad%20del%20proceso.%3C%2FP%3E%0A%3CP%3EEn%20teor%C3%ADa%2C%20si%20el%20suministro%20de%20materias%20primas%20es%20inestable%2C%20se%20deber%C3%ADan%20monitorear%20todos%20los%20lotes%20de%20suministro%20y%20aumentar%20la%20frecuencia%20del%20muestreo%20y%20an%C3%A1lisis%20de%20las%20materias%20primas%2C%20pero%20esto%20no%20es%20posible%20actualmente%20porque%20el%20m%C3%A9todo%20de%20an%C3%A1lisis%20por%20cromatograf%C3%ADa%20de%20gases%20(GC%20%3CSPAN%3E)%20existente%20consume%20mucho%20tiempo.%20%2C%20la%20inspecci%C3%B3n%20completa%20no%20podr%C3%A1%20satisfacer%3C%2FSPAN%3E%20las%20necesidades%20de%20producci%C3%B3n.%20Por%20lo%20tanto%2C%20el%20m%C3%A9todo%20de%20an%C3%A1lisis%20r%C3%A1pido%20que%20se%20est%C3%A1%20desarrollando%20actualmente%2C%20la%20cromatograf%C3%ADa%20l%C3%ADquida%20de%20ultra%20alto%20rendimiento%20(UHPLC%20%3CSPAN%3E)%2C%20ser%C3%A1%20el%20foco%20del%20siguiente%3C%2FSPAN%3E%20paso.%20%C2%BFC%C3%B3mo%20lograr%20un%20control%20m%C3%A1s%20r%C3%A1pido%20de%20la%20calidad%20de%20la%20materia%20prima%20mediante%20un%20sistema%20de%20medici%C3%B3n%20de%20cromatograf%C3%ADa%20l%C3%ADquida%20de%20rendimiento%20ultraalto%3F%20Continuaremos%20explorando%20esto%20en%20art%C3%ADculos%20posteriores.%3C%2FP%3E%0A%3CP%3ESi%20est%C3%A1%20interesado%20en%20los%20m%C3%A9todos%20%3CSPAN%3Eestad%C3%ADsticos%3C%2FSPAN%3E%20de%20control%20de%20procesos%20estad%C3%ADsticos%20(SPC)%20de%20este%20art%C3%ADculo%2C%20puede%20descargar%20%3CA%20href%3D%22https%3A%2F%2Fwww.jmp.com%2Fzh_tw%2Fdownload-jmp-free-trial.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3E%3CSPAN%3Ela%20%C3%BAltima%20versi%C3%B3n%3C%2FSPAN%3E%20de%20JMP%3C%2FA%3E%20y%20experimentarlo%20%3CSPAN%3Eusted%3C%2FSPAN%3E%20mismo.%20Obtenga%20m%C3%A1s%20informaci%C3%B3n%20sobre%20los%20conocimientos%20y%20t%C3%A9cnicas%20de%20an%C3%A1lisis%20de%20datos.%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3ELectura%20recomendada%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Blog%2F%25E6%2587%2589%25E7%2594%25A8%25E6%25A1%2588%25E4%25BE%258B-%25E5%259F%25BA%25E6%2596%25BCJMP%25E8%25B3%2587%25E6%2596%2599%25E6%258E%25A2%25E5%258B%2598%25E6%2589%25BE%25E5%2587%25BA%25E5%25B9%25BD%25E9%2596%2580%25E8%259E%25BA%25E6%2597%258B%25E6%25A1%25BF%25E8%258F%258C%25E6%2584%259F%25E6%259F%2593%25E6%2582%25A3%25E8%2580%2585%25E7%259A%2584%25E5%25BD%25B1%25E9%259F%25BF%25E5%259B%25A0%25E5%25AD%2590%2Fba-p%2F625330%3FtrMode%3Dsource%22%20target%3D%22_blank%22%3E%3CSPAN%3ECaso%20de%20aplicaci%C3%B3n%3A%3C%2FSPAN%3E%20%3CSPAN%3Eb%C3%BAsqueda%20de%20factores%20que%20influyen%20en%20pacientes%20con%20infecci%C3%B3n%20por%20Helicobacter%20pylori%20seg%C3%BAn%20la%20exploraci%C3%B3n%20de%20datos%20del%20JMP%3C%2FSPAN%3E%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20style%3D%22font-family%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%22%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Blog%2F%25E8%25A3%25BD%25E7%25A8%258B%25E8%2583%25BD%25E5%258A%259B%25E5%2588%2586%25E6%259E%2590-%25E5%25BF%25AB%25E9%2580%259F%25E7%258D%25B2%25E5%25BE%2597%25E8%25A3%25BD%25E7%25A8%258B%25E5%25A0%25B1%25E5%2591%258A%25E5%2585%25A9%25E5%25A4%25A7-JMP-%25E5%258A%259F%25E8%2583%25BD%2Fba-p%2F609427%22%20target%3D%22_blank%22%3E%3CSPAN%3EAn%C3%A1lisis%20de%20capacidad%20de%20proceso%3A%20obtenga%20r%C3%A1pidamente%20dos%20funciones%20JMP%20principales%20para%20informes%20de%20proceso%3C%2FSPAN%3E%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20style%3D%22font-family%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%22%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Blog%2F%25E6%25A9%259F%25E5%2599%25A8%25E5%25AD%25B8%25E7%25BF%2592-%25E7%25B5%25B1%25E8%25A8%2588%25E5%2588%2586%25E6%259E%2590-%25E4%25B8%25BB%25E6%2588%2590%25E5%2588%2586%25E5%2588%2586%25E6%259E%2590%25E8%2588%2587JMP%25E5%25AF%25A6%25E4%25BD%259C%2Fba-p%2F609432%3FtrMode%3Dsource%22%20target%3D%22_blank%22%3E%3CSPAN%3EAprendizaje%20autom%C3%A1tico%3C%2FSPAN%3E%20%2Fan%C3%A1lisis%20estad%C3%ADstico%3A%20an%C3%A1lisis%20de%20componentes%20principales%20e%20implementaci%C3%B3n%20de%20JMP%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-753571%22%20slang%3D%22zh-TW%22%20mode%3D%22CREATE%22%3E%3CP%3ELograr%20la%20excelencia%20en%20la%20fabricaci%C3%B3n%20es%20el%20objetivo%20que%20persigue%20toda%20empresa.%20Para%20lograr%20este%20objetivo%2C%20el%20departamento%20de%20calidad%20debe%20trabajar%20continuamente%20para%20identificar%20las%20fuentes%20de%20variaci%C3%B3n%20del%20proceso%20y%20tomar%20las%20medidas%20adecuadas%20para%20controlar%20los%20objetivos.%3C%2FP%3E%0A%3CP%3EComprender%20el%20proceso%20de%20fabricaci%C3%B3n%20a%20trav%C3%A9s%20del%20an%C3%A1lisis%20de%20datos%20no%20solo%20puede%20aumentar%20la%20flexibilidad%20de%20la%20producci%C3%B3n%2C%20sino%20tambi%C3%A9n%20garantizar%20que%20los%20productos%20cumplan%20mejor%20con%20los%20requisitos%20del%20cliente.%20C%C3%B3mo%20lograr%20la%20excelencia%20en%20la%20fabricaci%C3%B3n%20basada%20en%20el%20an%C3%A1lisis%20de%20datos%20cient%C3%ADficos%20es%20un%20problema%20al%20que%20se%20enfrentan%20todas%20las%20empresas.%20Este%20art%C3%ADculo%20compartir%C3%A1%20c%C3%B3mo%20%3CSPAN%3Ereducir%20la%20variaci%C3%B3n%20del%20proceso%20en%20la%20gesti%C3%B3n%20de%20calidad%20a%20trav%C3%A9s%20de%20SPC%20desde%20la%20perspectiva%20de%20las%20estad%C3%ADsticas%20de%20ingenier%C3%ADa%20aplicada.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64097iC3CA6CE71C28A30F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%227.png%22%20alt%3D%227.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-753571%22%20slang%3D%22zh-TW%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EIngenier%C3%ADa%20de%20Calidad%20y%20Procesos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
JMP_Taiwan
Level VI
什麼是SPC(統計製程控制)?減少製程變異的分析流程解說與數據解讀
實現卓越製造是每個企業追求的⽬標。為了達到這個⽬標,品質部門必須不斷努⼒識別製程變化的來源,並採取適當的措施來控制⽬標。時至科學化的現代,品質單位已經可以透過數據分析的方式,來理解製程的⽣產過程,不僅可以增加⽣產的靈活性,⽽且能確保產品更好地符合客戶要求。
實現智慧製造的三大關鍵
如何基於科學的數據分析實現卓越製造,更是每家企業在要求提升產品品質時,所面臨到的問題。透過過去JMP合作的產業案例可以看出,企業實現卓越製造需要經歷三個關鍵過程
  1. 1.透過控制圖及製程能力分析,實現統計製程管制 (SPC),減少製程變異;
  2. 透過測量系統分析 (MSA),尋找測量過程中的變異源;
  3. 透過實驗設計(DOE) 及預測建模,確定對測量變異有影響的因⼦,找到因⼦的最佳設置,使測量過程更加穩健。
我們以⼀個醫藥⽣產製造商的案例看看如何實施這「數據分析三部曲」。⾸先,我們先來看看如何進行統計製程管制(SPC)
實戰案例分析
製程背景
FVM製藥公司是⼀家國際藥品製造商,專門⽣產⾼品質的成品配⽅藥,產品類型包括片劑、膠囊和液體。在製藥過程裡,有個典型的製造過程包括:將活性藥物成分(API)研磨成均勻顆粒⼤⼩的粉末,接著將磨碎的材料與其他組分混合,使原料藥體積變⼤並均勻分佈,然後將這種混合材料壓製成片劑,最後進⾏包衣,以提⾼有效期限、⼝感和其他性能。在這個過程結束時,各種品質參數指標都會被記錄,以便批量驗收。
上述過程的原材料是含有兩種有機化合物的濃縮乳劑,由兩個供應商(AB)同時提供,製藥公司透過氣相⾊譜法(GC)測量化合物的濃度(mg/L)來監測品質。
現況問題
最近品質管理團隊發現藥品品質存在很⼤的差異,透過問題排查,懷疑問題有很⼤可能來⾃原料藥。為此,公司專門成立品質改進⼩組,希望藉助統計具,結合品質源於設計法(QbD),透過數據化決策,從根本上找到個可持續的解決確定製程變化的關鍵驅動因素,最終達到優化製程設置的目的。
改善過程
首先,品質改進⼩組進⾏產品的統計製程管制 (SPC)透過控制圖瞭解製程的穩定性並分析過程變化的模式。透過製程能力分析,評定其是否滿⾜顧客/外部交期。兩個⼯具都⽀持更好地理解過程,並指導制定改進策略。團隊對來⾃兩家供應商的兩種化合物原材料,進⾏了為期8天的樣品採集並導入JMP軟件,涉及所有批次,下圖(一)為部分數據截圖。
圖 ()
分析的先決條件:檢視數據是否呈現常態
許多品質統計⼯具使⽤的前提假設是數據來⾃於常態分佈,否則基於平均值和標準差的報告結果就沒有意義。利⽤ JMP選單,點選「分析 (Analyze)à 分佈平臺 (Distribution)」,結合SW檢驗和AD檢驗結果,可以確認兩個化合物數據呈現常態分佈,表示沒有問題,結果如下圖(二)所⽰。
圖()
當然,也可以透過分析 (Analyze) à 分佈平台 (Distribution) 的互動功能(點選某個參數的某個⽔平,其他參數對應部分也會被選中),快速查看三個參數“批次供應商作為可變性潛在驅動因素與兩種化合物的變化關係,如圖()
例如每天都會使⽤來⾃兩個供應商的批次,但即使同⼀天的批次,化合物1和化合物2的結果也差異巨⼤。
圖()
分析第二步驟:檢視數據是否產生變異
完成常態檢定和直⽅圖分析後,就可以使⽤ JMP 控制圖⽣成器平臺(Control Chart Builder)探索品質⽅⾯的問題了。由於變異存在於任何系統和過程當中,控制圖能動計算的控制限,便能有效區分過程變異中⼀般原因和特殊原因產⽣的變異,從⽽識別和消除特殊原因造成的數據波動。
另⼀個常⽤的品質工具 — 製程能力分析 (Process Capability),可以有效衡量個製程與給定的規格限相比表現如何,有助於識別表現不佳的過程。計算時⽤到的規格限,是由外部系統或按過程要求設定的。本例中化合物1的規格下限和上限分別是100mg/l500mg/l,化合物2的規格下限和上限是300mg/l600mg/l
個好的過程是個穩定的過程,並且持續地產出遠在規格限之內的產品。上述兩個⼯具Control Chart Builder & Process Capability便是經常結合使⽤,⽤於評估製程的穩定性以及評估其滿⾜客戶規格要求的能⼒。
透過JMP的控制圖⽣成器平台可以快速得到下圖()的輸出結果,左側分別為化合物1和化合物2XBar&R控制圖,右側為製程能力分析結果。
圖()控制圖⽣成器結果
分析第三步驟:分析結果的數據解讀
  1. XBar圖是以批次為⼦組的均值控制圖。觀察可以發現,化合物1的所有的點都隨機落在控制範圍內(綠⾊和黃⾊區域)。引入判異規則,沒有任何點被圈起來或被標記,這意味著過程是"在控制中"或穩定的。⽽化合物2在引入判異規則後,發現批號11落入紅⾊區域,並被圈起來或打上標記,這表明該過程不受控制或不穩定。
  2. R圖是批次為⼦組的極差控制圖,⽤於監測過程中的波動⼤⼩。圖表上的每個點都代表批次範圍的最⼤值和最⼩值的差值。引入判異規則,可以看到化合物1的第10批產品和化合物2的第5批超出了控制限,說明有⼀些特殊原因造成過程波動變化。
  3. 右側部分則是製程能力分析結果,⽤來識別表現不佳的過程。常⽤來評估的幾個能⼒指標包括:
    1. Cp/Pp:規格限的寬度與過程波動之比。Cp⼜叫內部(或短期)潛在製程能力( 只考慮⼦組內的波動),Pp⼜叫整體(或⻓期)潛在製程能力(考慮所有組整體的波動)。它們是衡量如果過程均值和⽬標均值⼀致,能⼒能夠達到多少的常⽤指標;
    2. Cpl/Ppl⽤于檢查⼀個過程滿⾜規格下限的能⼒;
    3. Cpu/Ppu⽤于檢查⼀個過程滿⾜規格上限的能⼒;
    4. Cpk/Ppk:取Cpl/PplCpu/Ppu的最⼩值。
    5. Cpk/Ppk等於1.0,被認為⼀個勉強合格的過程,當然也有些⾏業準則要求Cpk/Ppk的最⼩值為1.33或甚⾄更⾼。
  4. 當前原料化合物1Cpk值和Ppk值分別為0.7400.752,所以認為該製程不太合格。化合物2也不是很好,Cpk值和Ppk值分別為1.0050.746
分析第四步驟:從供應商角度探索變異來源
把供應商拖到控制圖的頂部(階段區),可按供應商分割控制圖,如下圖 () ⽰。
圖()
從上圖()可以看出,對於這兩種化合物,基於現有控制限,雖然供應商A提供的這兩種化合物都很穩定(批次在控制限度內),但是我們可以發現:供應商A明顯比供應商B有更⼤的批次間變化。供應商B批次間的變化相對比較⼩,但發現供應商B的化合物1表現出特殊原因的變異。
此外,我們也可嘗試使⽤模型驅動的多元控制圖(MDMVCC),主成分分析(PCA)個控制圖中監測多個製程的參數。在某些場景下,如果只是獨立觀察各個製程,似乎都是穩定的,透過多元控制圖可以同時檢測多個過程的潛在不穩定性,深入調查個別過程對整體性的貢獻,以診斷製程是否穩定。
圖()
由上圖()可知供應商A的所有批次都在控制限內,⽽對於供應商B,可以清楚地看到三個批次是失控點,需要關注。
此外,我們還可以透過JMP製程能力篩選平台(Process Screening),利⽤⽬標圖和製程性能圖將變異和能⼒結合到⼀個輸出中,同時查看兩個供應商的化合物是否穩定,是否符合給定規格。此平台尤其適合⼤量製程需要監測的品質檢測場景,非常推薦使用。
圖()
上圖()的製程能力圖突出了過程是否健康的兩個⽅⾯, 即穩定性指標和製程能力(Ppk)。⼀個穩定的過程將有⼀個接近1的穩定性指標。穩定性指數的值越⾼,表明製程越不穩定。
製程能力Ppk是衡量過程表現的重要參數,數值越,對應於每百萬個產品的缺陷率越低。理想的製程(有能⼒的和穩定的)顯⽰在圖中的綠⾊陰影區域,其中Ppk>1.0, 穩定指數<1.25無能⼒的和不穩定的過程在紅⾊陰影區域,其中Ppk<1.0,穩定指數>1.25
⽬標圖為每個過程在 x 軸上顯⽰規格標準化的均值偏移,在 y 軸上顯⽰規格標準化的標準差,⽤於快速提供關於過程是否符合規格限的匯總視圖。
穩定有能⼒的製程顯⽰在圖中的綠⾊(pk>2.0)和黃⾊(pk>1.0)陰影區域,⽆能⼒的和不穩定的過程在紅⾊陰影區域(Ppk<1.0)。
對於供應商A來說,化合物1和化合物2的兩個過程都是穩定的,但能⼒不⾜。對於供應商B來說,化合物2是穩定的,但能⼒不⾜,⽽化合物1既能⼒不⾜⼜不穩定。
階段性結論和品質改善方案
我們接連使⽤了均值、極差控制圖和多元控制圖等方式,來監測供應商的原材料品質和關鍵製程參數,並要求供應商也使⽤這些控制圖來減少製程過程變異。
理論上,如果供應的原材料不穩定,所有供應批次都應該被監測,並增加原材料抽樣分析的頻率,不過⽬前還不能實現,因為現有的氣相⾊譜分析⽅法(GC)非常花時間,全檢將無法滿⾜⽣產的需求。所以⽬前正在開發的快速分析⽅法,超⾼效液相⾊譜法(UHPLC),將是下⼀步⼯作的重點。如何透過超⾼效液相⾊譜測量系統來實現更快的原材料品質監測?我們將在之後的⽂章中繼續探索。
如對⽂中統計製程控制(SPC)統計⽅法感興趣的朋友,歡迎下載最新版JMP ⾃體驗。瞭解更多資料分析知識與技巧。
推薦閱讀:
Last Modified: May 20, 2024 9:39 AM
