Analyse columns is a tool which will perform fairly quick pre-determined summary statistics (explained below) for your discrete (nominal/ordinal) and continuous data. It also allows you to perform some quick launch tasks directly from the Analyse Column's window such as delete columns, create scatterplot matrix and add largest nines to missing value codes.
This add-in uses Summary table to calculate most of discrete summary statistics and Distribution platform to calculate continuous summary statistics. These were chosen for their ease of use while scripting and speed.
Examples below are from using Analyse Columns on all columns of JMP's sample data table Probe.
Launch window which allows user to select columns and sampling rate.
Progress bar with functional Cancel button
Main window with Side Panel open.
UI Main window explanation:
1. Same side panel that can be seen in data tables, this can be closed from the triangle on top left corner.
2. Short information about the analyzed data table (rows, column, analyze duration). Clicking on the table name will bring it to front
3. Summary statistics table for Nominal / Ordinal columns
4. Summary statistics for Continuous columns. This also has horizontal scroll bars so remember to scroll to left and right
5. Action buttons
6. Tab pages to change between analysis window and view of the original data table.
See Using JMP > Summarize Your Data > Explanation of Summary Statistics for most of the summary statistics.
See Basic Analysis > Distributions > The Distribution Report > The Summary Statistics Report for more detailed explanation of most of the statistics.
Actions are performed mostly on selected columns. If platform is launched, it will be pre-filled with selected columns.
When Cast Role is pressed following window will open:
This add-in was inspired by the need to quickly get overview of new large data sets (Pandas Profiling is one such existing library).
Run Analyse columns for all columns.
Quickly check if there column which have most values missing
or if values are mostly the same (you can re-order by clicking on header)
Select some of the columns which have most of the values same and use distribution and subset to check what they look like
As values are mostly same, they might not be that useful in further analysis. For demo purposes, we will use Hide&Exclude to remove these from analysis.
Next quick check could be to see, if there are some Continuous columns which should be possibly recoded as Nominal or Ordinal. Again Distribution and Subsets are good quick tools for this (looking for example for version numbers, id numbers and such). These values don't seem to be such values
Next we will check if there are possibly nines used instead of missing values and these seems to be quite a few columns like that
Analyse Columns will look for highest absolute nines and use those as Nines, it won't drop then based on quantiles or such. Some of those seem to have quite interesting situation where there are values larger than Nines. Again, we use distribution and subset to explore them in more detail
Distributions seem quite quite fine:
Next we create subset with those columns and take a closer look. These 9999 rows and missing values seem quite suspicion to me.
For example column 30N1_4X20_HFEPEAK*VA10U has 55 9999 values, doesn't feel completely normal to me. Let's create summary table of that column and order by N Rows.
This would require more knowledge of the process, but if I had to make a guess these are failed measurements / missing values, even though they are not even close to the largest values in the column
For demo purposes we conclude that those are missing values and use Set Nines Missing to exclude them WITHOUT losing data. After we have used Set Nines Missing, we should use Refresh Selected to refresh summary statistics calculations for those columns
Before:
After:
Next we could take a look at first order autocorrelation to see if the data isn't random and has some "row based" dependencies. There are quite a few columns with high autocorrelation, Start Time being obvious. We select some of the high autocorrelation columns and use Time Series to see what is going on
Seems like that there could be some dependencies which is caused by time.
There are still quite a few checks we could do, such as looking for correlations (we should clean outliers first for example with explore outliers) or use Model Driven Multivariate Control Charts to look for interesting patterns but I think we have enough to demonstrate what can be done with Analyse columns for now.
Change Log
24.12.2022 - Removed company logo from UI
Just noticed there is a bug with Continuous Table Box and the values are being shifted by one when using JMP17. Most likely the platforms I'm using for summary statistics have changed from JMP16 -> JMP17. When I have time I'll take a look and try to fix the issue.
