parsing datetime field
I'm trying to parse a date+time but without success.
a = "11/9/2012 8:58:19 AM";
b = Parse Date(a, "d/m/y h:m:s"); // Returns "."
Is there a way to parse a date+time like this?
10 REPLIES 10
mpb
mpb
Re: parsing datetime field
Not sure why you are having trouble. In 10.0.1 if I run your script with a "show()" added:
show(a, b)
I get this in the Log:
b = 11Sep2012:08:58:19;
Michael
pmroz
It could depend on your locale.  Are you outside of the US?
This might work better for you:
c = informat(a, "d/m/y h:m:s");
I'm  indeed outside US, but I don't understand why that would effect parsing of dates in this way.
With informat(a, "d/m/y h:m:s"); the results are the same (I think that informat and parse date are equivalent?)
b = .;
c = .;
My JMP Pro version is 9.0.3
pmroz
Check out this link:
You may need to replace the slashes with dashes or periods as mentioned by MS in this discussion.
I think my locale the issue, it is set to 24 hour format (13:00) which makes parsing of AM/PM dates not possible...
Show(Informat("11/9/2012 8:58:19 AM", "m/d/y h:m:s"));
Show(Informat("11/9/2012 8:58:19", "m/d/y h:m:s"));
Results in:
Informat("11/9/2012 8:58:19 AM", "m/d/y h:m:s") = .;
Informat("11/9/2012 8:58:19", "m/d/y h:m:s") = 09Nov2012:08:58:19;
It seems there is no way to specify AM/PM in the date format.
For now I can do this ugly hack...
f = function({datetimestring},
    size = length(datetimestring);
    t = left(datetimestring, size - 3);
    d = Parse Date(t, "d/m/y h:m:s");
    If(Right(datetimestring, 2) == "PM", Date Increment(d, "Hour", 12, "actual"), d)
show(f("11/9/2012 8:58:19 AM"));
show(f("11/9/2012 8:58:19 PM"));
11Sep2012:08:58:19;
11Sep2012:20:58:19;
Jeff_Perkinson
The Parse Date() function and Informat() function are aliases of each other and neither requires a second argument.
When no second argument is supplied JMP will try to interpret the string as a date, time or datetime using a variety of formats. This will almost always work.
It certainly does in this case, regardless of the locale setting.
b = Parse Date(a);
09Nov2012:08:58:19
a = "11/9/2012 8:58:19 PM";
b = Parse Date(a);
09Nov2012:20:58:19
-Jeff
ms
Super User (Alumni) ms
Unfortunately there is some spurious locale dependency.
For example, this code give different results depending on locale (but time settings does not matter):
a1 = "11/9/2012 8:58:19 AM";
a2 = "11/9/2012 8:58:19";
a3 = "11-9-2012 8:58:19 AM";
a4 = "11-9-2012 8:58:19";
Show( Parse Date( a1 ), Parse Date( a2 ), Parse Date( a3 ), Parse Date( a4 ) );
//JMP 10.0.1 in OS X 10.8.2 region set to "Sweden", 24 hour time
Parse Date(a1) = .;
Parse Date(a2) = 09Nov2012:08:58:19;
Parse Date(a3) = .;
Parse Date(a4) = 09Nov2012:08:58:19;
//Same computer, but region set to "USA", 24 hour time
Parse Date(a1) = 09Nov2012:08:58:19;
Parse Date(a3) = 09Nov2012:08:58:19;
//Same computer, region set to "UK", 12 hour time
Parse Date(a1) = .;
Parse Date(a3) = .;
//Same computer, region set to "UK", 24 hour time
Parse Date(a1) = .;
Parse Date(a3) = .;
Thanks MS, this makes clear what is going on.
It guess there is no way to specify AM/PM format as the "format" parameter in Parse Date (like %p with strptime in C)?
chrisselley
Interesting
If the datetime is in the form 11SEP2012 8:58:19 AM then this works perfectly
data x;
   a="11SEP2012 8:58:19 AM";
   b=input(a,datetime24.);
   format b datetime19.;
   put b=;
run;
But if the datepart is formatted with /'s 11/9/2012 it falls apart!
