galits
Intraclass Correlation in JMP
I have test-retest data of the same measure on the same subjects.
I would like to calculate the intra-class correlation between the test and retest, but could not find anything in the documentation or in the forum.
Any idea how this can be done?
Thanks!
Galit
ms
Super User (Alumni) ms
Re: Intraclass Correlation in JMP
In JMP 10 ICC is listed in EMP-results obtained by the Measurement Systems Analysis platform (Analyze/Quality and Process/...). Look in the documentation (Help/Books/Quality and Reliability Methods) on page 125.
ICC can also be calculated from the mean squares obtained from the Fit Model platform.
ms
