Can you share the data table, either as an attached file, or as a screen capture?
I'll upload a cut-down version - it's the same as the original file, but I have just deleted almost all of the variables, just leaving enough to represent two comparisons.
(NB that two of the samples, rows 21 and 22, are excluded from the analysis.)
Can you also share the JMP platform (as a picture)? It might be that you specified the model in a way that confounds some effects.
Yes, I'll give that a go, thanks - hopefully this is what you meant, a screenshot of the relevant options chosen?
![jmp_modelspec.jpg jmp_modelspec.jpg](https://community.jmp.com/t5/image/serverpage/image-id/38193i6ADA9A76C8083489/image-size/large?v=v2&px=999)
NB that for me, the two Y variables shown have different outcomes, in that JMP successfully calculates a P value for one but not the other.
Are the sites acting as a blocking factor, with a random effect? Is that interpretation what you mean by "clear clustering within sites?"
This is not a designed field trial - these are worms from indigenous populations, where we have gone and dug them up. (For fuller reference: we do classify the sites as "control" and "predicted", and I would also be keen to try and model this classification, but for the current question, I am trying to model the relationship for potential pollutants (metal ions) on a per-worm basis, rather than a per-site basis.) The sites are highly distinct from each other, whether you make the classification on the basis of metal ions, or of the worm metabolite concentrations - e.g. clearly visualised by multivariate approaches such as PCA. I definitely don't consider myself expert at all in using mixed effects models - my approach here is based on discussion with colleagues, and I would not be shocked to find that I am trying to do something that is not justified.. NB one of their comments was that assigning random effects is only really meaningful for categorical variables, but JMP does allow one to assign random effects to continuous variables: should I just assume that this is not a good idea?
Summarising, I can get to an answer that works, using PCA and PLS modelling (with cross-validation hold-out sets based on site, using a different package than JMP - maybe I should be looking at some kind of resampling approach for the univariate analyses too??), but I would really like to be able to get the answer to the univariate case as well. There are three reasons:
- I would like to be able to present a univariate analysis alongside the multivariate one.
- Even if I primarily present the multivariate analyses, it is really useful to be able to pull out key variables as potential biomarkers, and analyse these in more detail.
- I want to be able to understand what is going on!
many thanks ...
