BookmarkSubscribeRSS Feed
kaushik_pushpen
Community Trekker
Feb 22, 2015
how to plot variablity chart of particular layer defined by the user?
Hello all,
I want to set a particular window for the user defined input layer by using following code:
New Window( "Set a Value",
<<Modal,
Text Box("Set the layer"),
layer = Combo Box({"AA","RAA","CS"}),
Button Box( "OK"),
Button Box( "Cancel")
But i don't know how to add variability chart after pressing "OK" .
Please guide me.
The variability script as follows:
Variabilty chart{
     Y(:Name("CD-Value")),
     X(:Name("CD-PIC"),:Axis),
     Analysis Type(Name("choose best analysis(EMS REML Bayesian)")),
     Process Variation(0),
     where(:Mask == eval(layer))
ms
Jun 23, 2011
Re: how to plot variablity chart of particular layer defined by the user?
In your code "layer" refers to the Combo Box() itself, but what you need is a variable to hold the user-selected value. Use << get selected to get the value as a string.
For example:
New Window("Set a Value",
    <<Modal,
    cb = Combo Box({"AA", "RAA", "CS"}),
    Button Box("OK", layer = cb << get selected),
    Button Box("Cancel")
Variability chart(
    X(:Name("CD-PIC"), :Axis),
    where(:Mask == layer)
ian_jmp
Jun 23, 2011
It's easy enough to do what (I think . . . ) you want. But have you considered using a local data filter to let users select the layer on the fly?
NamesDefaultToHere(1);
dt = NewTable("Variability Data",
  AddRows(1000),
  NewColumn("Layer", Numeric, Nominal, Formula(RandomInteger(1,3))),
  NewColumn("Site", Numeric, Continuous, Formula(RandomInteger(1,3))),
  NewColumn("Wafer", Numeric, Continuous, Formula(RandomInteger(1,3))),
  NewColumn("CD", Numeric, Continuous, Formula(RandomNormal(5,1))),
dt << Variability Chart(
  Y( :CD ),
  X( :Site, :Wafer ),
  Analysis Type( "Choose best analysis (EMS REML Bayesian)" ),
  Std Dev Chart( 0 ),
  Automatic Recalc( 1 ),
  Local Data Filter( Mode, Add Filter( columns( :Layer ) ) )
kaushik_pushpen
Community Trekker
Feb 22, 2015
Hello MS,
Thanks for the explanation.
But how to connect variability chart with this New Window, means  I want variability chart after pressing "OK".
pmroz
Jun 23, 2011
You can set a variable to 1 or 0 with the OK and Cancel button:
New Window( "Set a Value", << Modal,
    Panel Box( "Set the layer",
        cb = Combo Box( {"AA", "RAA", "CS"} ), ),
    Panel Box( "Actions",
        H List Box(
            Button Box( "OK",
                runit = 1;
                layer = cb << get selected;
            Button Box( "Cancel", runit = 0 )
If ( runit,
    Variability chart(
        Y( :Name( "CD-Value" ) ),
        X( :Name( "CD-PIC" ), :Axis ),
        Analysis Type( Name( "choose best analysis(EMS REML Bayesian)" ) ),
        Process Variation( 0 ),
        where( :Mask == layer )
kaushik_pushpen
Community Trekker
Feb 22, 2015
Thank you very much
