formulations and their effects
Hi- I made 9 different chemical formulations using 6 ingredients (adding different wt% of each). I make a certain amount (g) of byproduct for each of the 9 formulations, the amount dependent upon how we formulate (ratios added). What would be the best way to analyze and make sense of the data? Ideally want to determine the best formulation to give the minimum amount of byproduct. I appreciate the help.
Tade
10 REPLIES 10
Re: formulations and their effects
thank you everyone. Very helpful. The problem was the experiment was not JMP design and had some trouble finding an adequate model.
