hupin
change the Grapg Builder label value to 2 or 1 decimal ?
for Graph builder : see below the picture, possible to change the label value to 2 or 1 decimal ?
thanks
Hu Pin
gueset
Re: change the Grapg Builder label value to 2 or 1 decimal ?
Try changing the value in the dataset. That is, go to the table, right click on the column that you are graphing, select "Column Info", and modify the Format.
Cheers.
none1
Its possible to make changes for the Graph, just play aroung with the Axis seettings.
Celina
Thanks, I've been searching how to fix the decimal for label on the graph for few days... but now I got the solution. :)
Level XIII
To change the format of the labels, you can use Label format in the settings of the Bar Plot:
Level XIII
To change the position and orientation via the GUI, please vote here:
Graphbuilder: option to rotate - and position - labels
