DirtyDataCoLLC
Windows 11 crashes JMPpro 16
Is anyone else having problems with windows 11. I'm struggling to make it through two hours without crashing JMP. I have 64g of RAM and the best possible set up from DELL. I spent way too much for this computer. Any advice would be appreciated!
Robert Williams
DirtyDataCoLLC
Re: Windows 11 crashes JMPpro 16
The problem is fixed. I used your (jeff's) advice given on DEC 10, 2021 02:22 PM.
Disable hardware acceleration preference. Navigate to File ► Preferences ► Windows Specific ► Enable hardware accelerated graphics. Deselect the preference and then click Apply and restart JMP.
Thank you!
Robert Williams
Jeff_Perkinson
I'm sorry that you're having difficulty. The fastest way to resolve this is to contact Tech Support at support@jmp.com or by phone at +1.800.450.0135. They can help diagnose and figure out what might be causing the problem.
-Jeff
DirtyDataCoLLC
Thank you!
Robert Williams
