See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
Why is Tables/Concatenate so slow?
Level XII
Has this ever happened to you?
Sometimes it takes a very long time for Tables/Concatenate to finish merging two tables.
More than a minute for just a few columns and some 100k rows.
What could be the reason?
Level XII
Re: Why is Tables/Concatenate so slow?
I was wondering if it's because of the character columns - or because of the new compact columns (to compute the logic in the background).
Is it much faster to merge 2x the same table - instead of merging to "different" tables?
no - no - no
dt1 = new table("test",<< add rows(500000));
for(I=1, i<=20, i++,
dt1 << new column ("x", Character, set each value(Hex(random Integer(1000000))));
dt1 << new column ("y", Character,Compact set each value(Hex(random Integer(1000))));
dt2 = dt1 << Subset( All rows, Selected columns only( 0 ) );
t0= hptime();
dt1 << Concatenate(	dt1);
time=(hptime()-t0)/1000000;
print("concat same file: ", time);
t0= hptime();
dt1 << Concatenate( dt2);
print("concat 2 files: ", time);
Level XII
You may have noticed the FILES "scripts" - they look quite innocent:
but concerning speed, they can be devastating:
dt1 = new table("test",<< add rows(1), new column ("x",  set each value(1)));
t0=hptime();
Nmax=200;
for(i=1, i<100,i++,
filesN = As list(Index(1,Nmax)`);
filelist = transform each({i},filesN,Eval List({"myfile"||Char(i)||".txt", 1, 1}));
Eval (Eval Expr(
dt1 << New Table Script(	"Files",Expr(filelist)	)
print("add files info: ", time);
t0= hptime();
Level XII
So from time to time, either delete the Files scripts - or merge them into one script *)
This will speed up the Concatenate step by orders of magnitude.
Even more important: if you trigger the Update manually:
With the new Preview Tab, the strange "processing" has to be done EVERY time again and again:
1) when the Concatenate menu opens
2) when tables are added via Add
3) after clicking on OK
This video illustrates the problem - to make it not extremely boring, I sped it up  by reducing the for loop to 50:
Concatenate_slow.mp4
Video Player is loading.
Current Time 0:00
Duration 1:22
Loaded: 0%
Stream Type LIVE
Remaining Time 1:22
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    *) almost surprising: the same content in the table scripts - but orders of magnitude faster:
    t0=hptime();
    Nmax=200;
    for(i=1, i<100,i++,
    Eval (Eval Expr(
    //merge the table scripts
    merged Script = dt1 << get script();
    dt1 << delete scripts(dt1 << Get Table Script Names);
    Eval(eval Expr(dt1 << new  table script ("merged",Expr(Name Expr(merged Script)))));
    t0= hptime();
    print("concat 2 files - merged scripts: ", time);
    vs before:
    View more...
    Concatenate_merged__notslow.mp4
    Current Time 0:00
    Duration 0:18
    Loaded: 0%
    Stream Type LIVE
    Remaining Time 0:18
    1x
      • Chapters
      (view in My Videos)
      Level XII
      according to JMP support, the bad performance is no bug, but as expected: TS-00173141
      Comparing all the text in all the script in the tables being concatenated takes a long time.  It is a lot of information to compare.  It is not surprising that the concatenation is so much slower with the large number of table scripts your example tables have.
