- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
Why is Tables/Concatenate so slow?
Has this ever happened to you?
Sometimes it takes a very long time for Tables/Concatenate to finish merging two tables.
More than a minute for just a few columns and some 100k rows.
What could be the reason?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Why is Tables/Concatenate so slow?
I was wondering if it's because of the character columns - or because of the new compact columns (to compute the logic in the background).
Is it much faster to merge 2x the same table - instead of merging to "different" tables?
no - no - no
dt1 = new table("test",<< add rows(500000));
for(I=1, i<=20, i++,
dt1 << new column ("x", Character, set each value(Hex(random Integer(1000000))));
dt1 << new column ("y", Character,Compact set each value(Hex(random Integer(1000))));
dt2 = dt1 << Subset( All rows, Selected columns only( 0 ) );
t0= hptime();
dt1 << Concatenate( dt1);
time=(hptime()-t0)/1000000;
print("concat same file: ", time);
t0= hptime();
dt1 << Concatenate( dt2);
print("concat 2 files: ", time);
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
You may have noticed the FILES "scripts" - they look quite innocent:
but concerning speed, they can be devastating:
dt1 = new table("test",<< add rows(1), new column ("x", set each value(1)));
t0=hptime();
Nmax=200;
for(i=1, i<100,i++,
filesN = As list(Index(1,Nmax)`);
filelist = transform each({i},filesN,Eval List({"myfile"||Char(i)||".txt", 1, 1}));
Eval (Eval Expr(
dt1 << New Table Script( "Files",Expr(filelist) )
print("add files info: ", time);
t0= hptime();
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
So from time to time, either delete the Files scripts - or merge them into one script *)
This will speed up the Concatenate step by orders of magnitude.
Even more important: if you trigger the Update manually:
With the new Preview Tab, the strange "processing" has to be done EVERY time again and again:
1) when the Concatenate menu opens
2) when tables are added via Add
3) after clicking on OK
This video illustrates the problem - to make it not extremely boring, I sped it up by reducing the for loop to 50:
- Chapters
- descriptions off, selected
- captions settings, opens captions settings dialog
- captions off, selected
- en (Main), selected
This is a modal window.
Beginning of dialog window. Escape will cancel and close the window.
End of dialog window.
This is a modal window. This modal can be closed by pressing the Escape key or activating the close button.
*) almost surprising: the same content in the table scripts - but orders of magnitude faster:
t0=hptime();
Nmax=200;
for(i=1, i<100,i++,
Eval (Eval Expr(
//merge the table scripts
merged Script = dt1 << get script();
dt1 << delete scripts(dt1 << Get Table Script Names);
Eval(eval Expr(dt1 << new table script ("merged",Expr(Name Expr(merged Script)))));
t0= hptime();
print("concat 2 files - merged scripts: ", time);
vs before:
- Chapters
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
according to JMP support, the bad performance is no bug, but as expected: TS-00173141
Comparing all the text in all the script in the tables being concatenated takes a long time. It is a lot of information to compare. It is not surprising that the concatenation is so much slower with the large number of table scripts your example tables have.
