Level XIII
Why is Tables/Concatenate so slow?
Has this ever happened to you?
Sometimes it takes a very long time for Tables/Concatenate to finish merging two tables.
More than a minute for just a few columns and some 100k rows.
What could be the reason?
Level XIII
Re: Why is Tables/Concatenate so slow?
I was wondering if it's because of the character columns - or because of the new compact columns (to compute the logic in the background).
Is it much faster to merge 2x the same table - instead of merging to "different" tables?
no - no - no
dt1 = new table("test",<< add rows(500000));
for(I=1, i<=20, i++,
dt1 << new column ("x", Character, set each value(Hex(random Integer(1000000))));
dt1 << new column ("y", Character,Compact set each value(Hex(random Integer(1000))));
dt2 = dt1 << Subset( All rows, Selected columns only( 0 ) );
t0= hptime();
dt1 << Concatenate(	dt1);
time=(hptime()-t0)/1000000;
print("concat same file: ", time);
t0= hptime();
dt1 << Concatenate( dt2);
print("concat 2 files: ", time);
Level XIII
You may have noticed the FILES "scripts" - they look quite innocent:
but concerning speed, they can be devastating:
dt1 = new table("test",<< add rows(1), new column ("x",  set each value(1)));
t0=hptime();
Nmax=200;
for(i=1, i<100,i++,
filesN = As list(Index(1,Nmax)`);
filelist = transform each({i},filesN,Eval List({"myfile"||Char(i)||".txt", 1, 1}));
Eval (Eval Expr(
dt1 << New Table Script(	"Files",Expr(filelist)	)
print("add files info: ", time);
t0= hptime();
Level XIII
So from time to time, either delete the Files scripts - or merge them into one script *)
This will speed up the Concatenate step by orders of magnitude.
Even more important: if you trigger the Update manually:
With the new Preview Tab, the strange "processing" has to be done EVERY time again and again:
1) when the Concatenate menu opens
2) when tables are added via Add
3) after clicking on OK
This video illustrates the problem - to make it not extremely boring, I sped it up  by reducing the for loop to 50:
*) almost surprising: the same content in the table scripts - but orders of magnitude faster:
t0=hptime();
Nmax=200;
for(i=1, i<100,i++,
Eval (Eval Expr(
//merge the table scripts
merged Script = dt1 << get script();
dt1 << delete scripts(dt1 << Get Table Script Names);
Eval(eval Expr(dt1 << new  table script ("merged",Expr(Name Expr(merged Script)))));
t0= hptime();
print("concat 2 files - merged scripts: ", time);
vs before:
View more...
Level XIII
according to JMP support, the bad performance is no bug, but as expected: TS-00173141
Comparing all the text in all the script in the tables being concatenated takes a long time.  It is a lot of information to compare.  It is not surprising that the concatenation is so much slower with the large number of table scripts your example tables have.
Level XIII
seems to be fixed in JMP19:
Tiny Traps in Jmp and JSL
