All,
Wondering why this happens. I have an expression where a custom model is created. When I call this once, everything performs as expected, however when I call it more than once, one of the updates in the model generation fails. What surprises me is this does not happen when I update with one column but fails only with a specific column. Any thoughts ?
when its done one column at a time, the data has a chance to completly update before the second one starts.
Try using the dt<<run formulas; trick to force the table to update before starting the next opperation. maybe?
This seemed to be bug in JMP 13.1 .I was unable to recreate it in JMP 14. However, in JMP 13, by reinitialise the namespace, i was able to fix ir
